iPhone 13 pro resistor value request
  • cool-oase
    • Jan 2019
    • 12
    Hi everybody,
    i am looking for the value of a resistor, that got missing on an iPhone 13 pro.
    I attached a picture, where the resistor is marked.
    maybe someone of you has a spareboard and can measure the value?
    Thank you very much :-)
  • ksysa
    Request: COMPLETE Schematic Diagram of iPhone 11 Pro Max
    by ksysa
    Does anyone here have a complete schematic diagram (with board layout) of iPhone 11 Pro Max? I cannot afford to pay for boardviewer subscription so i'm hoping anyone would like to share. thank you!
    07-24-2025, 04:04 PM
  • jinu_j
    by jinu_j
    Hi
    05-03-2025, 10:51 PM
  • mikey5791
    by mikey5791
    Hi to all forum members,
    12-26-2024, 04:55 AM
  • inflex
    iPhone 11, 820-01523 pdf / bv request
    by inflex
    Looking for the PDF schematic and component placement files for the 820-01523 ( iPhone 11 ), I have a BRD but all the namings are generic so I need a schematic + component-placement image so I can update the information to produce a proper fleshed out boardview
    08-23-2024, 06:03 AM
  • MidnightRoller
    Can a resistor lose resistance after hot air?
    by MidnightRoller
    I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
    I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
    02-02-2022, 11:46 PM
