Does anyone here have a complete schematic diagram (with board layout) of iPhone 11 Pro Max? I cannot afford to pay for boardviewer subscription so i'm hoping anyone would like to share. thank you!
Request: COMPLETE Schematic Diagram of iPhone 11 Pro Max
by michael83Hello everyone,
i request a schematic diagram for a board LA-L591P
The problem on this board is that i don't have 3.3 volt on pin 8 on UC6,is only 1.45.
Somebody try to reflash the UC6 chip to remove password and after that laptop is on no power state.
I try to put 3.3 volt from 3v stby,the laptop powers on but remains still's on logo.
i flash both spi flash with original bin and still does' boot.
Thanks in advance for all suggestion....-
by ebj423Hi! I am having a problem with my pc (https://www.badcaps.net/forum/showthread.php?t=106976). The nearest schematic I can find is for b75m-a but I just found out that it has a very different SIO(nct5535d 64pin) compared to mine(nct6779d 128pin) and therefore I cannot use it as a basis for troubleshooting and tracing my mobo's ckt. I have downloaded the pinout of nct6779d and I will be able to identify pin designations but I won't be able to easily trace its connectons w/out the ckt diagram. I am too afraid to use my tester probes on the almost hairline thin pins of my sio for fear of shorting...
06-03-2022, 12:26 AM -
schematic diagram for Asus m-07A13U4-4421
by titimimohello Guys Titi here ,
hope you are ok,i am looking for help,any one with schematic of IB250CX schematic diagram( lenovo M710e)
mine has an ic above sata has removed and i can't guess the number or if it was a regulator
please if you know let me know the type of this chip
computer work except to recognize hdd or ssd disk ,normally i can't install windows even if disk shows up or run windows
thanks-
by Kirve"Hello friends. My Asus X556U laptop is not charging, not turning on, etc. I wanted to repair the motherboard, partly for learning purposes. One of the capacitors is giving a 24V output, and one of the MOSFET pins is also giving a 24V output, and honestly, this surprises me. I think I need to replace the capacitor, but I don’t know the capacitance value. I tried searching for a motherboard schematic but couldn’t find anything. Can you help me find the schematic or diagram?"
- Loading...
