Dell Inspiron 1520 bad graphic card or something else?
  • ahmetozay
    • Jul 2013
    • 73
    • turkey
    Hi friends, i have this dell inspiron 1520 with Nvidia Geforce 8600M GT. When i turn on the laptop everything is ok even on welcome screen, after passing welcome screen there are bad square pixels on the screen. i changed the screen also reballed the nvidia chip but its all same bad square pixels. i send a video of the laptop as attachment. What do you think the problem is. Thanks
    http://www.youtube.com/watch?v=UkUnRgR_1f4
  • lezsimply
    The Wanderer
    • 657
    • Philippines
    Re: Dell Inspiron 1520 bad graphic card or something else?
    How about on external monitor?
    • spleenharvester
      • Mar 2010
      • 921
      Looks like bad VRAM to me.
      Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
      • ahmetozay
        • Jul 2013
        • 73
        • turkey
        Same on the external monitor
        • ahmetozay
          • Jul 2013
          • 73
          • turkey
          do you recommend to reball all video rams or do you know a way to find out which one is defected?
          • spleenharvester
            • Mar 2010
            • 921
            Back when I used to reflow graphics cards I would press down on each VRAM chip to see if the video-out changed at all. Obviously very difficult to do if there are heatsinks involved, though.
            That repeated pattern is very typical of VRAM failure.
            • ahmetozay
              • Jul 2013
              • 73
              • turkey
              is there a test software like memtest to test the vrams?
              • spleenharvester
                • Mar 2010
                • 921
                http://www.majorgeeks.com/files/deta...ress_test.html
                No idea how reliable it is.
                • ahmetozay
                  • Jul 2013
                  • 73
                  • turkey
                  Thank you, i am going to give it a try and feedback here.
                  • ahmetozay
                    • Jul 2013
                    • 73
                    • turkey
                    the software did not find any errors also i found another one called OCCT http://files.extremeoverclocking.com/file.php?f=214 , also found no errors. Any other recommendations?
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      Try just reflowing all the VRAM chips. They should not require reballing.
                      A working TV? How boring!
                      • spleenharvester
                        • Mar 2010
                        • 921
                        Definitely worth trying a reflow. Though the VRAM chips I reflowed back in the day never lasted more than a few weeks before failing again.
                        • senchire
                          • Dec 2012
                          • 190
                          • Bosnia
                          They are easy to reball anyway.
                          • Journeyman
                            • May 2012
                            • 5
                            is there a step by step for those of us without specialized equipment.
                            I've tried the "at home" reflow methods with poor results. I'd be interested to reball if it can be done without expensive equipment.
                            • ahmetozay
                              • Jul 2013
                              • 73
                              • turkey
                              i tried reflowing and the result is same, reballing is the only choice but it would be nice to know which one to reball because there are 8 vrams have to reball one by one until it fixed
                              • ravi_1617
                                YY Solutions
                                • Jan 2012
                                • 348
                                • India
                                have a close look all the vram from side u may see some solder balls crushed and came out solder would be there reball it
                                • Th3_uN1Qu3
                                  Believe in
                                  • Jul 2010
                                  • 6031
                                  You won't find a step by step guide because it differs for everyone and the tools they have access to.
                                  I have been doing fine for 2+ years using what used to be a toaster as a preheater (free), a controller to go with it ($5-$10) to build your own), and a regular temperature controlled hot air SMD rework station ($100).
                                  What I also needed to buy were a few BGA nozzles of different sizes ($15-$18 each) for the hot air station, and of course, flux, solder balls, stencils and fine tweezers. Oh, and the vacuum pen thingy to lift chips. And you will of course need a stand to hold the hot air wand in place above the chip, that's left for you to cobble together out of whatever you have on hand.
                                  I already had 2 decent ($100 range) multimeters with temperature probes so i did not need to buy thermometers. Get some Omega thermocouples if you can though, the regular size ones that come with multimeters are annoying to place and they sometimes knock parts off the board when you're not careful.
                                  All in all, you can put together a usable BGA rework machine under $500, which will pay for itself quickly once you learn how to use it, but the most important part is you need to have lots of spare dead boards to practice on. I got the hang of it after 20 or so, but some people break 50 or more boards before they get it right, even with a professional machine. YMMV.
                                    DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                                    This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                    09-12-2024, 03:36 PM
                                    DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                                    This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                    09-12-2024, 03:30 PM
                                    09-12-2024, 03:28 PM
                                    DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                    This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                    DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
