HP pavilion DV6
  • senchire
    • Dec 2012
    • 190
    • Bosnia
    HP pavilion DV6
    Hello folks, got this baby few day's ago.
    Turned on but had no post, so I assumed that the GPU (as usual) is gone. I heated it for 20sec on 200C (with my hot air gun), and voila I had post.
    After that I went to reball it, lifted etc... And bang now I get 1 sec turn on and turn's off.
    Assuming that the reball screwed the GPU I see only to order a new one. What are your thoughts?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3593
    • slovakia
    Re: HP pavilion DV6
    yes, check for short on its power rails to be sure
    • techman1025
      • Jun 2014
      • 497
      Re: HP pavilion DV6
      Hi rework don't work when gpu fails it a dead chip problem is the die of the chip it needs to be replaced. We use the heat test just to comfirm if it's bad and we had some cases it could run for up to three months but it never a fix problem is the chip from 2008 to 2009 mostly . Test temp should be 100c 200c is to high it will cause solder bridging causing short so lift chip and clean check resistance at main coils for CPU core you will see short gone then replace done and it will last be leave me doing these repairs a long time rework only works good on south bridge and north bridge on newer chips only
      Techman1025
      • senchire
        • Dec 2012
        • 190
        • Bosnia
        Re: HP pavilion DV6
        Well I wouldn't agree with you at all, specially on the part "rework only works good on SB and NB", as 90% nvidia won't fail on rework just won't last long.
        Solder bridging can never happen with 20 sec even at 300C (of course I use heat test just to see will I get post, but frankly with these ATI's you are better of replacing them right away).
        I also work longer time, but till now I didn't had 216-0728014 dyeing on me. All in all I'll order a new one later this weak and replace it.
        • sopik78
          • Nov 2013
          • 517
          • Czech Republic
          Re: HP pavilion DV6
          First of all write exact model of DV6, it could be anything. Schematics would help.
          • senchire
            • Dec 2012
            • 190
            • Bosnia
            Re: HP pavilion DV6
            DV6-1107el DAUT1AMB6D0 REV : D, true everything could happen. I am "globalizing" the problem to the GPU unit because the heat test showed me that when its heated its working. Taking that into account and that I only did a reball on it could mean that while reworking the GPU went bad.
            But if you have any suggestion I am ready to try and fix this problem.
            • sopik78
              • Nov 2013
              • 517
              • Czech Republic
              Re: HP pavilion DV6
              In most cases it's not a problem of GPU but NB, probably 215-0674034 here. Try reball or change and you"l see. First of all try to measure power for NB and GPU, possibly faulty MOSFET
              • sopik78
                • Nov 2013
                • 517
                • Czech Republic
                Re: HP pavilion DV6
                Check this schematics, in this case could be problem with PQ41 or PQ42 (had some boards with similar problem before)
                • dycc
                  Vision
                  • Nov 2011
                  • 625
                  • Côte d'Ivoire
                  Re: HP pavilion DV6
                  when you got right tools ,discussion don't take place
                  • senchire
                    • Dec 2012
                    • 190
                    • Bosnia
                    Re: HP pavilion DV6
                    Had 3 DV6 coming this year all with GPU problems, but will try also to reball the NB (or better change them both).
                    I'll check more deeply the MB after a short vacation on which I am currently .
                    But looking at these tools you think if I had them that I would be here on forums asking for help (mostly because you would be deep in the business and had a lot of exp) .
                    Lets get back to real life and my cheap multi meter :P.
                    • dycc
                      Vision
                      • Nov 2011
                      • 625
                      • Côte d'Ivoire
                      Re: HP pavilion DV6
                      lol
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3593
                        • slovakia
                        Re: HP pavilion DV6
                        Oh man i wanna this machine sooooooooooo much
                        • senchire
                          • Dec 2012
                          • 190
                          • Bosnia
                          Re: HP pavilion DV6
                          I am in the same boat, sadly my budget isn't quite for that :P. Anyway is there any "cheap" solution like this?
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3593
                            • slovakia
                            Re: HP pavilion DV6
                            Only if u have on stock some RADAWAY or RAD-X/fallout/
                            • dj_ricoh
                              • 2073
                              Re: HP pavilion DV6
                              are you talking about actual Fallout 3?
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3593
                                • slovakia
                                Re: HP pavilion DV6
                                or new vegas
                                  HP Pavilion Pavilion Desktop - 570-a079w Pavilion 570 J4205 Specification for Upgrade or Repair
                                  This specification for the HP Pavilion Pavilion Desktop - 570-a079w can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-a079w boardview and Pavilion Pavilion Desktop - 570-a079w schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                  09-12-2024, 03:44 PM
                                  HP Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) Pavilion 550 i5-6400 Specification for Upgrade or Repair
                                  This specification for the HP Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) boardview and Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                  HP Pavilion Pavilion Desktop - 570-p030na Pavilion 570 i3-7100 Specification for Upgrade or Repair
                                  This specification for the HP Pavilion Pavilion Desktop - 570-p030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p030na boardview and Pavilion Pavilion Desktop - 570-p030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                  HP Pavilion Pavilion Wave Desktop - 600-a059na Pavilion i5-6400T Specification for Upgrade or Repair
                                  This specification for the HP Pavilion Pavilion Wave Desktop - 600-a059na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Wave Desktop - 600-a059na boardview and Pavilion Pavilion Wave Desktop - 600-a059na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                  HP Pavilion Wave Pavilion Wave Desktop - 600-a030na Pavilion Wave i3-6100T Specification for Upgrade or Repair
                                  This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a030na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
