Macbook pro A2779 820-02841 No Power 5V
  • saisoni20
    • Feb 2022
    • 118
    Hi everyone
    I Have MacBook pro A2779 820-02841 no power. All type-c Ports are reading 5V 0A.
    I have checked each coil and cap no shoring on board.
    PPDCIN_AON - 0v
    PPDCIN_AON_CHGR_R - 0v.
    Is there any possibilities that all CD3217s are bad?
  • mon2
    • Dec 2019
    • 14996
    Review the fuse @ F5601.
    • saisoni20
      • Feb 2022
      • 118
      continuity okay and 0V
      • mon2
        • Dec 2019
        • 14996
        Be sure the usb-c connector paddle board is firmly seated onto the logic board socket. If you have 5v showing on usb-c meter then it should travel onto the logic board and the fuse.
        Suggest to use the low cost usb-c tail tester by Qianli. Available from Mobile Sentrix Canada for under $20. Can quickly test each of the usb-c pins and also acts like a meter.
        • saisoni20
          • Feb 2022
          • 118
          All 3 ports are looking ok.
          • fricosu007
            Macbook pro A2779 820-02841-A 5v stuck
            by fricosu007
            Hello !
            got stuck with a macbook pro a2779 / 820-02841-A having a short on pp5v_s2_main, found the issue, it was the UC260 who got toasted, i replaced if from a donor board, now pp5vs2_sw oscilates between 2v and 4v but never steady on 5v, no more short, could be the u5200 ? I cannot find what ic is making the 5v for S2 rail … power line is at 5v/0.1amp drow, ppvin_p5vs2 is 12v steady … please help !...
            09-20-2025, 05:50 AM
          • envym
            MacBook Pro 2018 with Activation Lock
            by envym
            Hi everyone!
            I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
            I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
            06-27-2025, 08:54 AM
          • Flasman90
            Macbook Pro DFU Restore Issues
            by Flasman90
            I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
            - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
            - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
            08-30-2025, 10:27 AM
          • spidertnt
            MacBook 14" M2 820-02841 no power A2779
            by spidertnt
            MacBook 14" M2 820-02841 A2779
            no power / no magsafe light
            No damage at all
            P3V8AON short to ground less than 1ohm
            found CT610 capacitor for the touchID area was short now fixed
            I used 820-02443 board view and schematic
            just sharing
            09-28-2023, 11:25 AM
          • tobeend
            Bypass mdm macbook m2 ventura
            by tobeend
            1. RESET MACOS WITH IPSW
            a. Power off MacBook, press and hold the power button to enter Recovery
            b. Open Disk Utility, remove Macintosh HD
            c. Reboot, connect to the network to Activate Mac.
            d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
            d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
            e. Release the other keys, but keep holding the Power key for another 10 seconds
            f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
            05-26-2023, 07:18 AM
