Macbook pro A2779 820-02841 No Power 5V
  • saisoni20
    • Feb 2022
    • 111
    Hi everyone
    I Have MacBook pro A2779 820-02841 no power. All type-c Ports are reading 5V 0A.
    I have checked each coil and cap no shoring on board.
    PPDCIN_AON - 0v
    PPDCIN_AON_CHGR_R - 0v.
    Is there any possibilities that all CD3217s are bad?
  • mon2
    • 14047
    Review the fuse @ F5601.
    • saisoni20
      • Feb 2022
      • 111
      continuity okay and 0V
      • mon2
        • 14047
        Be sure the usb-c connector paddle board is firmly seated onto the logic board socket. If you have 5v showing on usb-c meter then it should travel onto the logic board and the fuse.
        Suggest to use the low cost usb-c tail tester by Qianli. Available from Mobile Sentrix Canada for under $20. Can quickly test each of the usb-c pins and also acts like a meter.
        • saisoni20
          • Feb 2022
          • 111
          All 3 ports are looking ok.
          • envym
            by envym
            Hi everyone!
            06-27-2025, 08:54 AM
          • spidertnt
            MacBook 14" M2 820-02841 no power A2779
            by spidertnt
            MacBook 14" M2 820-02841 A2779
            no power / no magsafe light
            No damage at all
            P3V8AON short to ground less than 1ohm
            found CT610 capacitor for the touchID area was short now fixed
            I used 820-02443 board view and schematic
            just sharing
            09-28-2023, 11:25 AM
          • tobeend
            Bypass mdm macbook m2 ventura
            by tobeend
            1. RESET MACOS WITH IPSW
            a. Power off MacBook, press and hold the power button to enter Recovery
            b. Open Disk Utility, remove Macintosh HD
            c. Reboot, connect to the network to Activate Mac.
            d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
            d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
            e. Release the other keys, but keep holding the Power key for another 10 seconds
            f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
            05-26-2023, 07:18 AM
          • rotceh_dnih
            Macbook pro A2779 820-02841 Schematic
            by rotceh_dnih
            My customer "Only spilled a coffee on it" and now it "Just doesn't turn on?"
            Anyways now I need A2779 820-02841 board view and Schematic's if or when anyone gets their hands on them.
            I've only just got it so I've disconnected battery and see some minor junk on some filter caps near the USB-C port on the sdcard side but yet to pull the board out to observe Schrodinger's MacBook.
            04-19-2023, 07:38 AM
          • SarcasticOP
            General question about MacBook power rails for repair.
            by SarcasticOP
            I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
            • PPBUS_G3H (12.6V-12.8V)
              • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
            • PP3V42_G3H (3.42V)
              • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
            • PPVRTC_G3H (3.3V)
              • This
            12-12-2024, 05:50 PM
