Macbook pro A2779 820-02841-A 5v stuck
  • fricosu007
    • Feb 2016
    • 48
    • romania
    Hello !
    got stuck with a macbook pro a2779 / 820-02841-A having a short on pp5v_s2_main, found the issue, it was the UC260 who got toasted, i replaced if from a donor board, now pp5vs2_sw oscilates between 2v and 4v but never steady on 5v, no more short, could be the u5200 ? I cannot find what ic is making the 5v for S2 rail … power line is at 5v/0.1amp drow, ppvin_p5vs2 is 12v steady … please help !
  • mon2
    • 16551
    Remove all power. What is the exact resistance to ground in ohms at pp5vs2_sw?
    • fricosu007
      • Feb 2016
      • 48
      • romania
      It’s 400kohm and dropping
      • mon2
        • 16551
        The resistance is ok.
        What is the exact netname for pp5vs2_sw? This label does not appear in my schematic. Use only the exact name as in the schematics.
        • fricosu007
          • Feb 2016
          • 48
          • romania
          sorry for late replay, been away for some time but issue is still on my desk ..
          P5VS2_SW from UC260 which i found burnt and replaced
          • ryogadan78
            MacBook Air A1932 EMC 3184 - gets stuck in a loop, even when trying to install the OS from a USB drive
            by ryogadan78
            Hi everyone, I’ve got this MacBook Air with a problem that seemed simple but is driving me crazy. When I press the power button, I see the Apple logo for a few seconds, then it switches off and gets stuck in a loop. I’ve tried booting the MacBook into Internet Recovery, entered my Wi-Fi password, and it runs for about 14 minutes with the progress bar, but then it shuts down, restarts and gets stuck in a loop again (this time within Internet Recovery). I tried booting the system from a USB stick, but after selecting the Big Sur installation, it restarts after a few seconds.
            If...
            05-12-2026, 04:25 AM
          • Boardview and Schematic Bot
            Apple MacBook Pro 13 M1 820-02020-A 820-02020 Boardview and Schematic
            Apple MacBook Pro 13 M1 820-02020-A boardview 820-02020 V1.0 Boardview
            Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB
            Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB Physical scanning image
            Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB Location map...
            06-20-2026, 10:11 AM
          • jiraiyaishere
            MacBook Pro A2779 Non Genuine Display Replacement Confusion
            by jiraiyaishere
            I bought a screen replacement from AliExpress to repair a Macbook A2779 screen for my friend that from what I am guessing had a tear in the display ribbon cable.
            When the MacBook Pro boots up, the webcam light on the new screen seems to flash about 3 times for a period of 2 seconds for each flash. It also does it again when logging in and then it did it one time randomly about 2 minutes after logging in...
            Does anybody recognise this behaviour/know what the reason is? I have messaged the seller but judging by the quality of what I received (very long...
            05-26-2026, 01:34 PM
          • Bmet
            MacBook Pro 13 inch A2238 M2 stuck on 5V
            by Bmet
            I have a MacBook Pro 13 inch A2238 M2 and it was stuck 5V with 0 amps. I measured some important lines and I found a short on PP3V8_AON_MPMU_ISNS_VIN, I tried injecting 1v and I saw heat coming from the mPMU so I removed the pmu thinking that was the problem. I don't know why I didn't check the other side of the border but there it was, a shorted cap. I replaced the cap and the short was gone, so I reballed the PMU and put it on again but voltage was still stuck at 5V and the current was fluctuating between 0 and 0.45 amps. I checked under the thermal camera and I saw the mPM...
            04-02-2025, 05:02 PM
          • mflame
            MacBook Pro 15" 2018 Touch Bar, 820-01041 , USB-C no power on, stuck before S5
            by mflame
            Symptoms
            • Board does not start, no fan, no boot.
            • USB-C charger monitor shows 20 V, near 0 A draw.
            Main voltage rails (adapter plugged)
            • PPDCIN_G3H: 20 V
            • PPBUS_G3H: ~12.0 to 12.6 V
            • PP3V3_G3H: 3.3 V
            • PP5V_G3S: 5.1 V
            • PP3V3_G3S_X: 3.3 V
            • PP1V8_G3S: 1.8 V
            • PP1V8_SLPS2R: 1.8 V
            • PP2V5_NAND_SSD0: 2.5 V (U9080 TPS62180 is warm/hot on thermal cam)
            • PPBUS_G3H_SSD0_SNS: 12.6 V
            • SSD0_VR_P2V5_EN_R: 1.8 V
            Power sequence state
            • PMU signals present:
              • PMU_COLD_RESET_L: 1.8 V
              • SOC_COLD_RESET_L:
            01-03-2026, 07:49 AM
