HP 17-cn0152ng part U201 Q300 broken
  • Harry2k1
    • Apr 2025
    • 7
    • Deutschland
    A USB device has caused a short circuit and a component on the mainboard 17N-8L-TGL Was destroyed. The component is labeled U201 Q300. What type of component is this?
    Can I replace it?
    What else could be affected if a USB port and the speakers no longer work?
  • mon2
    • Dec 2019
    • 14631
    What are silk screened markings on the board?
    The large connector @ CN200 is likely keyboard?
    The burnt part may be a USB loadswitch in a SOT23-5 package. Share more pics of the board.
    • Harry2k1
      • Apr 2025
      • 7
      • Deutschland
      Thank you very much. Here are a few more photos.
      • mon2
        • Dec 2019
        • 14631
        Here are some suggestions:
        1) Confirm if the large cable @ CN200 are linked to the keyboard.
        2) Locate the replacement keyboard on the internet. Often, the same replacement part will be compatible with other models from the same vendor, HP.
        3) Then hunt for the alternate HP models for which there may be schematics available. That is, we can learn from the available schematics on the pinout for this same keyboard cable (assuming it is a keyboard).
        4) Then using a multimeter, you can trace this SOT23-5 device and hunt as to where it travels onto this connector. To me, this device is used to power perhaps the backlight of the keyboard but need your feedback as to where this CN200 travels on the board. USB port damage are often linked to USB load switches.
        • m1ch43lzm
          • Mar 2019
          • 748
          • Peru
          Hi Harry2k1 mon2 , it looks to me like that white ribbon cable goes to a USB daughterboard on the left side from 1st picture on post #3, the keyboard connector is under the battery
          Looks like it's a USB load switch, Harry2k1 can you post a clear picture of the ic near right side usb port? (circled in red, second picture), it might be similar IC
          On the attached image, remove the IC (make sure you shield the plastic connectors, otherwise they will melt), then measure voltage at the red lilne
          You can find those ICs near USB ports on donor boards
          • Harry2k1
            • Apr 2025
            • 7
            • Deutschland
            Thank you for your help.Here is the photo of the other IC (circled in red)
            m1ch43lzm You're right. The cable goes to the USB module.
            • m1ch43lzm
              • Mar 2019
              • 748
              • Peru
              Found it: APL3553IBI-TRG from the marking 53I* (uppercase i )
              2A, active high, SOT23-5 USB power distribution switch
              Datasheet attached
              Many replacement options available from different vendors
              • mon2
                • Dec 2019
                • 14631
                Great find! To me, it looked like '5313' not '53I3'.
                • Harry2k1
                  • Apr 2025
                  • 7
                  • Deutschland
                  Thank you so much! Super good
                  • m1ch43lzm
                    • Mar 2019
                    • 748
                    • Peru
                    TPS2001DDBV is a suitable replacement
                    • edugimeno
                      Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                      by edugimeno
                      Hi There!
                      I'm trying to help my friend who owns a restaurant be just bought.
                      He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                      It's stuck using, I guess, the 2 sided tape that comes with the strip
                      The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                      09-05-2024, 09:34 AM
                    • G-Sting
                      iPad Pro A1876 SHORT Part Identify Help Needed
                      by G-Sting
                      So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                      So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                      i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                      SO My main concern is what part should i order what should i search the name for ?
                      on Ipad...
                      05-15-2025, 09:30 AM
                    • Yanleb
                      Panasonic part number in service manuals
                      by Yanleb
                      In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
                      This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
                      For an example, look at the attached PDF.
                      Do you have a way to cross reference the Panasonic part number with the actual part number?
                      Thanks....
                      07-03-2023, 08:16 PM
                    • a460guy
                      LG 60PN5300 Broken hdmi Exploded part id help!
                      by a460guy
                      Picked up this 60" LG today that has a broken hdmi port and and exploded diode? Maybe? Looks like i can fix the port but the other part that got very hot, quick, i dunno.. anyone know what part or parts, im missing ? please advise......
                      04-24-2021, 08:07 PM
                    • chth96
                      Is it possible bridging tiny broken trace
                      by chth96
                      When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                      cutting tiny trace.
                      This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                      Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                      But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                      12-03-2022, 11:32 PM
