Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
  • code share
    • Apr 2025
    • 4
    • Denmark
    I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
    Here's what I've tried so far:
    • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
    • Booted successfully on AC power only with the battery disconnected
    • Visual inspection of the battery — no swelling, burn marks, or connector damage
    • Battery model: L18M3P73, rated 11.52V, 4213mAh
    • Planning to test it with a multimeter soon (waiting on one to arrive)
    Symptoms suggest the battery may be deeply discharged or dead, but I want to confirm before replacing it. It doesn't have a test button or indicator LEDs. If anyone knows which pins to probe for voltage testing, or if there's a known issue with this battery model, I'd appreciate the insight.
    Any help diagnosing this or confirming if the battery is truly dead would be awesome.
    Thanks in advance!
  • mon2
    • Dec 2019
    • 14307
    Suggest to test with a known good battery. Perhaps source one from Amazon. Return it if it is not required. Wait on the multimeter to test the related parts onboard.
    Would you have the schematics for this unit? Are there any silk screened markings on the board to identify the model #? So far, unable to locate a schematic for this unit.
    Is it 'FT490'?
    • code share
      • Apr 2025
      • 4
      • Denmark
      Thanks for the suggestion! I was hoping for a "standard" method to check just the battery when not attached to the laptop. E.g. if I using the Multimeter can confirm its dead then I don't have to investigate further.
      Regarding schematics a quick search gave this:
      https://laptop-schematics.com/view/12463/
      but seems I have to pay for it - besides the screenshots.
      • mon2
        • Dec 2019
        • 14307
        schematics & board view files are posted here:
        https://www.badcaps.net/forum/troubl...rdview-request
        • code share
          • Apr 2025
          • 4
          • Denmark
          Probably a stupid question but when looking at that file I read:
          T490/T590 Logic Schematics
          but maybe its the same as my p43s?
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • huzo
            HP ELITE X2 1013 G3 weird battery issue
            by huzo
            Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
            01-31-2025, 12:09 AM
          • survivalbloke
            Acer Predator Helios 300 - will not power up if battery is CONNECTED
            by survivalbloke
            This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
            06-25-2025, 12:20 PM
          • platinumsteel
            Macbook Pro 13'' 2017 A1708 Won't power on with battery connected.
            by platinumsteel
            Hi guys i have a 820-00840 that works fine and boots up as long a battery is not connected. I initially thought it was a bad battery so i went ahead and bought a new battery for it and slapped it in yesterday and realize that the same fault exists. When i screw in the battery and connect the little battery strip and i press the power button it will not power on.At that time If i connect the charger i get fan spin for 10 seconds then stops but the machine won't power on.If i disconnect the little battery strip and re-plug the charger the machine boots as normal.It's not the battery connector strip...
            03-03-2023, 10:17 AM
          • flat-earther
            how to prevent a connected charger from draining battery when not charging?
            by flat-earther
            I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
            So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
            but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
            So the battery is backfeeding the charger and being drained.
            How can I prevent...
            08-07-2025, 01:04 PM
