A2442 TOUCHID NOT WORKING
  • macabook
    • Sep 2024
    • 30
    • France
    I have an issue with a Mac A2442 , that had initially a short circuit on Q5800 after replacement it turn on without any other issue, only finger print not working. I follower the post " MacBook Pro M1 2021 A2442 Touch ID stopped working" by measuring in diode mode all SPI seems ok, but when checking for voltage i notice something strange regarding PP1V2_S2.
    The chips UT620, UT520, UT540 are powered by PP1V2_S2 (according schematic and board view), this voltage is missing, and when I check continuity with PP1V2_S2 rail, found that it is not connected to it. Compared on another similar board same thing.
    Is it a schematic error ? I doubt that trace issue can happen in both (the other one has a CPU issue).
    I am missing also the TOUCHID_PWR_EN that comes from CPU, it shows 1.2V sometimes for few seconds​.
    So I am little bit lost now, is it a trace issue or CPU not having all condition to trigger the enable ?
  • mon2
    • Dec 2019
    • 14664
    Check the voltage to ground on L8280 = PP1V2_S2 (BUCK8).
    • macabook
      • Sep 2024
      • 30
      • France
      PP1V2_S2 (BUCK8) is present, when I mesure were it should be it is there, UT620, UT520, UT540 PP1V2_S2​ not present and TOUCHID_PWR_EN not present
      As I mentioned the mac is working fine, only the fingerprint is not. I did a DFU restore didn't solve it
      • mon2
        • Dec 2019
        • 14664
        What is the 820-**** number of your logic board? There are 2 versions of this chassis.
        • macabook
          • Sep 2024
          • 30
          • France
          It’s 820-02098
          • mon2
            • Dec 2019
            • 14664
            Remove all power. Meter in resistance mode. Touch your meter probes together and you should have ~0R ohms.
            Now check the resistance from CT540 (see attached) to either side of L8280 coil.
            From the schematic and BV, there must be ~0R ohms resistance between these 2 points of interest.
            Otherwise, you have a PCB trace break and UT540 is not being powered.
            Click image for larger version  Name:	power_rail.png Views:	0 Size:	104.3 KB ID:	3614453
            • macabook
              • Sep 2024
              • 30
              • France
              I am getting mega ohm measurements between L8280 CT540​ and on UT620, UT520.
              it sound like trace breaking, but how is it possible to have the exact same resistance measurement and diode mode measurement on a another 820-02098 board ??
              • macabook
                • Sep 2024
                • 30
                • France
                I just figured out that it is a board delamination issue of the segment between UG400 and UT540. The resistance go to zero just by pressing down this area.
                Seems that it is very sensitive in this area because I have took out and back UG400 on both boards for troubleshooting purpose.
                thanks mon2 for your help.
                • macabook
                  • Sep 2024
                  • 30
                  • France
                  Just for update, soldering a jumper wire to the nearest PP1V2_​S2 ( pin 2 Non stuff UG280) and pin 1 RT621 solved the problem, fingerprint is now working fine.
                  thanks again
                  • mon2
                    • Dec 2019
                    • 14664
                    Interesting. Good case and closure.
                    • modtool
                      Macbook Pro 14 2021 - A2442 - 820-02098-A - Internal display not turning on but MacOS working good
                      by modtool
                      Dear collegues,
                      the owner of this machine brought it to me saying that suddenly one day the display didn't turn on anymore, he tought that all the machine was damaged but it turned out that the MacOS starts good and stays on, and that connecting it to an external display it works without problems.
                      If you take a look into general settings, you can also see that the internal retina display is recognized as connected by the main board but for an unknown reason it doesn't turn it on.
                      I've tried to put a bright light towards the screen but I can't see anything, any shadows or apple...
                      05-08-2024, 05:50 AM
                    • obelix24
                      Macbook Air 2020 (a2179) - touch id not working
                      by obelix24
                      Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
                      I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
                      02-09-2025, 12:57 PM
                    • MMH3
                      Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
                      by MMH3
                      i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
                      Never ever i experienced problems with that.
                      Now i have one 5050sff machine, where this jumper isnt working at all.
                      I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
                      The history of the machine is that i used it in my office...
                      03-23-2025, 09:28 PM
                    • DynaxSC
                      GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                      by DynaxSC
                      I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                      There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                      The board is generally working now, all PCIe ports are working, Windows installs normally.
                      However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                      The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                      03-10-2025, 12:27 PM
                    • ugamazing
                      by ugamazing
                      12-17-2024, 07:05 PM
