Macbook Pro 13" A1989
  • 247it
    • Mar 2023
    • 22
    Hi all, I picked up a MacBook pro 13" with a A1989 mainboard, it suffered a little liquid damage around the CPU power section,
    USB C switches to 20V 0.17 amps, this rises to .6 amps, stays that way for 30 seconds or more, then drops to 0 amps, 20V is maintained, fans spin at full speed for 1 second then the cycle starts over, CPU warms up slightly, mosfets U7210 heats to 38C and U7220 briefly heats and then goes cold at the start of the cycle,
    Could anyone point me to some posts on what voltages to check and where / how to check for shorts and the places to often check?
    Many Thanks for your help.
  • mon2
    • 14239
    MacBook Pro A1989 - Repair Wiki
    • 247it
      • Mar 2023
      • 22
      Thanks mon2, ill work my way through
      • 247it
        • Mar 2023
        • 22
        Everything checks out fine, no shorts and voltages are all stable, I saw a post of yours MacBook A1989 missing rails PP3V3_S5 and PP1V8_S5 - Badcaps​ my trackpad is very liquid damaged, im guessing this could be the problem?
        • mon2
          • 14239
          Suggest to test with a known good unit. You can try Mobile Sentrix (UK) who recently opened up a branch in the UK. They have been solid to supply Aliexpress type of pricing and products. Best is that they will allow returns as well. Alternatively, you can try Amazon and return it if the part is not required.
          • 247it
            • Mar 2023
            • 22
            Thanks for the advice, Amazon have them for £20, the main board ribbon is also toast, one of the pads has rotted to nothing
            • mon2
              • 14239
              Ouch. Amazon also is selling the replacement cable? Great if they do.
              • 247it
                • Mar 2023
                • 22
                Hi mon2, thanks for your help,
                I managed to get a like new track pad and ribbon for £10, not too bad, i also picked up a drilled but tidy doner board for £13, so have some spares, I have replaced the U9000 chip as i poorly reflowed it a year ago (last time i worked on the mac) but still the same,
                its a long shot but you may know what the below means,
                Power meter starts at 5V then jumps to 20V - current climbs to 600ma and stays stable for a while, then the amps jump to 800ma, reset then happens immediately, meter reads 0 amps 20V and the cycle starts again, any idea what happens at 800ma?
                • mon2
                  • 14239
                  Someone is heating up and then all power cycles. Remove all power. Meter in resistance mode. Measure the resistance to ground on each and every inductor on the board. Report any suspects. A thermal camera will help to check who or what is thermally throbbing on the board.
                  • 247it
                    • Mar 2023
                    • 22
                    Lowest coil resistance to ground is 6 Ohms, highest is .5M, does that seem like CPU is ok?
                    three things get warm,
                    CPU heat sink,
                    U7210 @ 40C, (replaced it, still warms up)
                    U7270 briefly (1sec) warms while CPUSA_DRVH is at 4.4 volts (replaced U7270 also)
                    • 247it
                      • Mar 2023
                      • 22
                      So, im thinking a something starting or a power rail being created into a short is causing a protection condition, im not seeing heat because the protection is very rapid, so would anyone know what power rails to check further down the line that would cause a complete power cycle? if i can find the rail i may be able to inject an appropriate voltage and current to identify the short, or is this a bit simplistic.
                      • ErinV
                        MacBook Pro A1989 820-00850-A not powering on
                        by ErinV
                        Hey everyone!
                        I have a MacBook Pro A1989 with a 820-00850-A board that recently stopped working. I used it overnight to charge my phone, in the morning it didn't turn on, I assumed flat battery but now won't charge and doesn't start at all.
                        I have fully dissassembled it, when disconnected the battery reads at 0.012V. Even with the battery disconnected the laptop doesn't boot.
                        The diode voltages around all 4 CD3215's seem fine.
                        For all CD3215 (UB300, UB400, U3100 and U3200) I read just above 5V on PP20V_USBC_TA_VBUS, 3.3V on PP3V3UPC_TA_LDO, 1.8V...
                        09-30-2024, 10:21 PM
                      • Madoy104
                        Macbook Pro A1989 - No image, working fine with external monitor
                        by Madoy104
                        I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
                        08-15-2024, 10:01 AM
                      • Fisher8865
                        MacBook Pro A1990 stuck at 5v .592 amps
                        by Fisher8865
                        Hi guys
                        I have a MacBook Pro A1990 that takes 4.9 Volts and .592 to .615 amps on one port. The other port on the left side power cycles with about the same amount of volts an amps but quickly power cycles. The same thing happens on the other side but opposite. So on the left side the bottom port stays on and on the right side it's the top one. I think it is a CD3215 chip but I am not sure how to test it or where to get one. I have checked for voltage at ppbus_g3h and it has 12.6 V which is also on fuses f7000 and f7001 I checked pp1v2_s3 and it has 1.2 V then...
                        05-30-2024, 07:36 PM
                      • PITERPENY
                        Macbook A1989, 820-00850, won't boot. 20V, 0A.
                        by PITERPENY
                        Today I have a MacBook A1989 at work 820-00850. When assembled, the laptop switches to 20 volts but the consumption is 0.00 ampere. if the motherboard is on the table then the consumption of all ports is 5 volts and0.35 amperes and does not go to 20 volts only if you assemble a MacBook.
                        Here are some measurements, maybe someone can tell what the problem is.
                        The initial problem was a burnt out induction coil L8504 (replaced).
                        When connected to another MacBook, it constantly hangs in dfu and cannot install updates, something is wrong.
                        here are some measurementsmotherboard...
                        01-16-2024, 02:19 PM
                      • Nikan.e
                        MacBook A1989 repair / no CPU voltage no boot signs
                        by Nikan.e
                        Hello everyone.
                        I have recently obtained a MacBook Pro A1989 model with a touch bar and Apple ID. Unfortunately, it does not want to start up.
                        No CPU Voltage.
                        U7800 Does produce voltages.
                        T2 Chip warming up very very little.
                        I do have voltages like 1.8, 0.9, 3.3, 2.5 volts, etc., present. I did not find any short circuits. Unfortunately, the device has no touch ID/start button. So, I have used the debug jumper to put the device into DFU mode. - It is getting recognized as a Macintosh while not in DFU mode and as Apple (DFU) while in DFU mode....
                        11-24-2023, 11:55 PM
