GH5JJ TLA-K701 no charging no power no acdet
  • opethfan
    • Feb 2015
    • 81
    • Italia
    hi
    i'm not skilled with laptop repair, i need some helps:
    i don't have ACDET on PU1802 and in consequence i don't have ACDRV
    please check pictures
  • mon2
    • Dec 2019
    • 14114
    Confirm the voltage on each of the 3 resistors on ACDET (highlighted in yellow).
    Red meter probe on the resistor; black meter probe to ground. DC volts (20v or higher scale).
    Report each measurement.
    • opethfan
      • Feb 2015
      • 81
      • Italia
      • mon2
        • Dec 2019
        • 14114
        Remove all power. Meter in resistance mode. Measure the resistance from pin #2 (where you measured 0V) to ground. What is the resistance in ohms?
        • mon2
          • Dec 2019
          • 14114
          Ok - see attached. This should explain your case with a solution.
          Summary: Your ADAPDET pin on the power adapter is not supplying the ground (0V) to properly announce the ACDET voltage. See the explanation below and confirm each measurement.
          To test, take a piece of wire and touch one side of the wire to ground. Other side of the wire to PQ101 pin #2 (be sure you review where pin #2 on this mosfet is located).
          By shorting / pulling the gate voltage to GROUND (0V), PQ101 will turn OFF. Then you will have a valid voltage on ACDET.
          Click image for larger version  Name:	adapter1.png Views:	0 Size:	48.5 KB ID:	3607803
          Click image for larger version  Name:	acdet2.png Views:	0 Size:	57.5 KB ID:	3607804
          • Sametbey
            • Jan 2021
            • 229
            • Turkey
            Can you check these three points? You can compare the voltage values.
            I'm not happy to be so strong. because it's not humanly
            • opethfan
              • Feb 2015
              • 81
              • Italia
              ACDET now is 2.6v but still no power
              • opethfan
                • Feb 2015
                • 81
                • Italia
                I have only:
                pin 28 - 19v
                pin 6 - 2.5v
                pin 24 - 5.9v
                pin 25 - 5.9v
                other pins are all 0 volts
                • DeXXter
                  • Aug 2023
                  • 91
                  • Chile
                  Check REGN, the 6v ldo on the charger, if this is not present you have a faulty BQ, also check if it gets hot, this ic should be quite cold.
                  • opethfan
                    • Feb 2015
                    • 81
                    • Italia
                    REGN 6V is present
                    the BQ is new, i changed for first some days ago
                    • Sametbey
                      • Jan 2021
                      • 229
                      • Turkey
                      PJP101 power jack is important. BQ24780's 15 pin BatPres and REGEN are important. Measurements were taken with and without battery. Can you check?
                      • opethfan
                        • Feb 2015
                        • 81
                        • Italia
                        I don't have the battery because this board is sent from another repair shop and he sent just the board
                        • Scoff
                          HP Probook 470 G4 - Power and Charging Problem
                          by Scoff
                          Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                          Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                          07-03-2023, 09:28 AM
                        • PantherDave
                          by PantherDave
                          Hi all!
                          05-29-2024, 02:01 PM
                        • rob_hen
                          Dell XPS 13 9370 Laptop, No power, not charging
                          by rob_hen
                          Hello!
                          This is my first post for help, and I am quite newer to board repair, so bear with me.
                          I have this board here (LA-E671P), with no power, and doesn't charge. No lights come on when plugged in.
                          After visual inspection of the board, U22 is obviously blown up. This is the for backlight, and there is no shorts present after removing the chip and replacing.
                          There is 3 USB C ports to power this board, USB 1 gives 20V, while 2 and 3 only give 5V.
                          My observations using USB 1 at 20V (0.075A draw on Ammeter, slowly drops from 0.136A)...
                          05-01-2025, 09:20 PM
                          Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
                          by sam_sam_sam
                          I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
                          https://www.ebay.com/itm/116497313155?var=416785404161
                          Here are some of the description from the eBay seller
                          The main parameters:
                          1. Product name: High-power non-isolated DC boost module power supply.
                          2. Product model: 100A2000W.
                          3. Input voltage: DC12V-60V.
                          4. Input current: 100A (maximum)....
                          05-18-2025, 09:45 AM
