Please Help Identify The Burned Component 820-2565-A DC-IN magsafe
  • kodox
    • Jul 2017
    • 322
    • Indonesia
    no green/orange light on charger and it has 12.67V on PPBUS_G3H & 3.38V on PP3V42_G3H but not power on
  • mon2
    • Dec 2019
    • 14216
    The 3v42 power rail should be 3v42.
    Clean the MagSafe contacts with ipa (alcohol) using Q-tips to remove carbon build up, dirt, etc. Then test again. Use only the original power adapter.
    • kodox
      • Jul 2017
      • 322
      • Indonesia
      thank's for info
      i did all the cleaning, using original charger but same result. but when i accidentally touch the screw hole on dc in board to metal parts on the motherboard, green light on charger turned on but won't power on
        SMDFlea commented
        Editing a comment
        Added "820-2565-A DC-IN magsafe" to thread title
    • mon2
      • Dec 2019
      • 14216
      Confirm the voltage to ground at L6995 = PP3V42_G3H (should be 3v42 here).
      This flowchart should help:
      https://logi.wiki/index.php/G3_to_S3..._and_Broadwell
      • kodox
        • Jul 2017
        • 322
        • Indonesia
        thank's for info, but the owner decided to take the unit before i start continue diagnose using those flowchart
        for SMDFlea it wasn't thinked to me someone would asked what kind of board in question after seeing attached picture, but thank's for correcting it
        • magneh
          Motorbike PCB - burned Diodes ( PJ78) - help to identify identical or equivalent
          by magneh
          Hello everyone
          Got a motorbike PCB that had 3 burned diodes.
          The smaller ones have the marking PJ78 GS1M
          And one larger one PJ78 GEX
          Can someone help me identify them so I can be able to replace with same or equivalent?
          Photos attached
          Apreciate !
          Thank you...
          05-19-2025, 07:38 AM
        • deep000
          Burned Voltage Regulator in Monitor – How to Identify and Repair?
          by deep000
          My computer monitor ASUS VP249H stopped working, and smoke came out of it.
          I opened it and found that a voltage regulator had burned out.
          The problem is that I can't identify its reference.
          I searched online for schematics or photos of similar boards that people are selling, but without success (no schematics, bad quality of the board or lack of the reference when it's a good quality 😅).
          How can I find its reference, and do you think it's repairable?
          Monitor: Asus VP249H
          Board reference: 0171 - 2271 - 6083
          09-08-2024, 01:13 PM
        • cinkoxid
          Atorch UD18 DC adapter Burned smd component. I can't identify it
          by cinkoxid
          Hi guys,
          I wanted to test a DC adapter and I plugged it into my device and then I immediately smelled the cooked component. I cheked the adapter again and I discovered that it's not a DC but a 24V AC adapter
          I took apart my tester and I think I found which component burned but I can't identify it for sure and I'm not sure where could i buy a replacement part which is the same or has similar features.
          I attached a few pictures of the component. I think it's a voltage regulator but some of the markings on the component are burned.
          Name of the...
          01-30-2023, 09:43 AM
        • smic717394
          MSI Optix MPG27CQ half screen working. Identify burned component
          by smic717394
          I have a MSI Optix MPG27CQ screen to fix, only half screen is working, I found a burned chip on the right buffer board (S270DP01V00_HF_SR) but I can't read the model. Can anybody help?...
          04-08-2025, 05:53 AM
        • kodox
          Toshiba Portege Z30-A - Burned Chip Identify
          by kodox
          received unit with no power at all, pluged bench PSU and not consuming any amperage, measurement shows that 19V only reaching first mosfet & gate voltage only 6V.
          visual inspection found that it has burned chip, marking code wasn't too clear under microscope, i guess it's "A C C I". the chip is located under huge diode with UCQ1QA03 marking on it, since i don't find any schematic or boardview for this model, wandering that someone had similiar board and kindly measure what voltage comeout from the inductor connected to that chip or maybe knew what model number of the chip...
          09-15-2023, 09:38 PM
