How to read the BIOS chip XMC 25RU128CHIQ
This topic has been answered.
  • Loki_Fido
    Forever NOOB
    • Mar 2025
    • 176
    • Japan
    Hi folks
    I am using CH341a to read this BIOS chip XMC 25RU128CHIQ and the CH341 doesn't know anything about this.
    I found this BIOS on 2 different laptops and tried to read them both with my CH341a and nothing.
    - HP Pavilion Aero 13
    - Lenovo Yoga 6 13ALC7
    I know these are 1.8v BIOS, so i used the 1,8v adapter.
    Using the adapter and not using the adapter, makes no difference.
    I used my CH341a on other types of BIOS chips and it works fine. But when it comes to this BIOS chip, it doesn't know what to do.
    Does it have do with the driver for the CH341A?
    Anyone got any idea?
    Any help is appreciated.
  • Answer selected by Loki_Fido at 03-21-2025, 08:54 PM.
    SMDFlea
    • 23917
    Post #12 https://www.badcaps.net/forum/troubl...03#post3565103
      • 23917
      • Loki_Fido
        Forever NOOB
        • Mar 2025
        • 176
        • Japan
        Originally posted by SMDFlea
        You beautiful bastard, you're right. It worked.
        Thanks a million bud
        • DynaxSC
          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
          by DynaxSC
          Hi
          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
          08-04-2025, 12:20 PM
        • hotcrossedbuns999
          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
          by hotcrossedbuns999
          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
          3. I could only locate two chips that look like bios chips. Could someone verify this
          01-03-2025, 12:32 PM
        • Berun
          HP EliteDesk 800 G6 mini - BIOS Chip (GD25B127DSIG) replacement after epic fail :D
          by Berun
          Hello All,
          I tried to read the the BIOs chip(GD25B127DSIG) on the mainbord of an HP EliteDesk 800 G6 mini, because the BIOs had an Admin Lock and I got the "HP Endpoint Security Problem" Screen at every startup which is not very useful when I want to use the PC as a Compute Unit for my home media system somewhere in the cellar, so it should perform a restart without any interactions.
          I only have the CH341APro Programmer available and did the 3V hardware Mod on it before I tried to read the BIOS chip.
          I read the Chip on board 8 times (with power...
          04-09-2026, 06:24 AM
        • BMCappelletti
          Asus Chromebox CN62 - wrong chip put on BIOS reader
          by BMCappelletti
          Long story short:
          - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
          - gave the computer to his son a couple years later
          - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
          - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
          (seems like the story was not that short)
          He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
          01-08-2025, 07:27 PM
        • TopPop
          Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
          by TopPop
          Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
          I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
          12-14-2025, 09:40 PM
