MacBook Pro A1708 pink screen and flickering
  • dbuergi
    • Jul 2024
    • 123
    • Deutschland
    a friend brought me his A1708. Apple store told him that the screen needs to be replaced for 400 € but they didn't even open it to check anything.
    Since this model is not known for flexgate issues is there anything else i can check or is this also a faulty display flex?
    Btw external screen works fine.
  • mon2
    • Dec 2019
    • 14177
    Dustgate:
    https://m.youtube.com/watch?v=Z7peZU2KlkI
    • dbuergi
      • Jul 2024
      • 123
      • Deutschland
      Thank you,i already checked this area but after cleaning i don't see any cracks or pinches. Can this be also a fault behind the apple bezel on the display?
      Did you repair this fault?
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 667
        I would replace the screen, these screens are pretty cheap to find now on eBay. You could easily pull a working one from a dead board.
        sigpic
        MEOWING IN THE IMPOSSIBLE UNIVERSE!
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
        • jimjoe123
          LCD TV Green/Pink screen problem
          by jimjoe123
          I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
          Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
          Then each time...
          02-23-2020, 01:29 AM
        • Ado02
          Lenovo Thinkpad X1 Gen 10 - Flickering Screen
          by Ado02
          We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the Intel® Iris® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
          The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
          12-16-2024, 02:33 PM
        • MagJ_
          MacBook Air M1 A2337 Screen Replacement - keeping TrueTone
          by MagJ_
          Hello Everybody,
          I have a cracked screen and want to fix it. Usually, TrueTone will be gone as long as one does not prune open the screen and exchange only the LCD. However, I have seen the following Youtube video https://www.youtube.com/watch?v=MBNqhp6p_ZM, Solve MacBook M1 Pro screen true tone issue from the channel Master Liu, where only two chips called "display control chip" and "code chip" are swapped over to the new screen. I know, it is for the MacBookPro version. Though, I had the hope that it could work similarly for the MacBook Air as well.
          10-09-2024, 02:51 PM
