Lenovo V15 g2 ALC no backlight
  • djob1981
    • Jul 2019
    • 16
    • england
    Got no backlight on this laptop, checked fv1 fuse was bad so replaced it with a new one and replaced the shorted cap next to it and l aso replaced the lcd cable as pin3 on the cable was burned. I now get 20v at those pins and get an image on ther laptop screen but still no backlight.checked fa2 fuse and is fine but gets no volts(unsure if this is right) and has a 0.33v drop to ground when testing ..
    Anyone got ideas where else i should look
  • djob1981
    • Jul 2019
    • 16
    • england
    also tried 3 screens same issue
    • tomodachi
      • Apr 2012
      • 610
      • Turkey
      Did you make sure +LCDVDD voltage is present ?
      • djob1981
        • Jul 2019
        • 16
        • england
        uv1 has no voltage on input side with just charger plugged in and board out of laptop
        • djob1981
          • Jul 2019
          • 16
          • england
          When turned on pin 1 on uv1 fluctuates, pin 4 get 3.3, pin 5 has 1.8v, pin 3 is 3.3v
          • djob1981
            • Jul 2019
            • 16
            • england
            fa2 fuse gets a solid 3.3v when turned on and fv1 20v
            • rogfanther
              • Jul 2006
              • 458
              • Brazil
              Measure resistance to GND on pin 5
              • djob1981
                • Jul 2019
                • 16
                • england
                i get 94.5k on pin 5 of uv1
                • PWiKua
                  • Apr 2019
                  • 7
                  • georgia
                  did you find solution? i have exact same problem. i even changed EC chip and problem not fixed.
                  • mon2
                    • Dec 2019
                    • 14667
                    Link a schematic (if available). Post inside of the schematic forum if required.
                    Share the voltage to ground of each pin on the UV1 load switch that is used by the backlight.
                    • PWiKua
                      • Apr 2019
                      • 7
                      • georgia
                      here is shcematics and boarview that i got. its bit different but same board.
                      ic is SY6288C20AAC. my board has no displey nor HDMI output. every rail turns on as supose to.
                      i tried bunch of Bios but nothings change. there is no EN signal on UV1. board do not have UC3 but have UC4 and its also not enabled what i remember. i'll check everythin again
                      • mon2
                        • Dec 2019
                        • 14667
                        What are the silk screen markings of the actual board you are attempting to repair? What is the current draw of the board?
                        • PWiKua
                          • Apr 2019
                          • 7
                          • georgia
                          its HV461&hv561 NM-D522 Rev:2.0
                            • 21907
                            The boardview has already been posted. Please post your schematic in this thread topic where other members will be able to find it -> https://www.badcaps.net/forum/troubl...-and-boardview
                            • PWiKua
                              • Apr 2019
                              • 7
                              • georgia
                              On UV1
                              1. +LCDVDD - 0V - 9.1M
                              2. GND
                              4. ENVDD - 0.002v (sometimes) - 10k
                              5. +3VS - 3.3V - 10k
                              on UC4
                              1. GND
                              2. CPU_EDP_PWM - 0v - 100K
                              3. GND
                              4. PANEL_PWM - 0v - 98.6k
                              5. +3VS - 3.3v - 10k
                              also when i started working on it there FV1 fuse was blown
                              • mon2
                                • Dec 2019
                                • 14667
                                Have you attempted the bios images found on internet on Vina site? They came up in the search engine.
                                Any sign of life if you remove the memory modules (assuming they are removable). Does the logic board complain?
                                Measure the resistance to ground on each leg of FV1 (without power to the board). Checking for a short condition.
                                • PWiKua
                                  • Apr 2019
                                  • 7
                                  • georgia
                                  resistance on FV1, both side its 40K
                                  about memory. i'm using only soldered memory. also tried many bios versions from different sources. non of them worked
                                  • PWiKua
                                    • Apr 2019
                                    • 7
                                    • georgia
                                    also i did not mentioned that cpu power mosfets getting much hotter then actual CPU
                                    • mon2
                                      • Dec 2019
                                      • 14667
                                      Likely the CPU is dead but suggestion is to replace each CPU linked mosfet AND their drivers.
                                      • PWiKua
                                        • Apr 2019
                                        • 7
                                        • georgia
                                        OK thanks for help <3
