Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
  • BMCappelletti
    • Nov 2021
    • 152
    • Brasil
    Hi everyone.
    Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
    Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
    Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a blank screen), chose another boot option (goes to a blank screen). So no luck with that.
    Tried different USB boot devices, same blank screen. Different M.2 drives (all detected in BIOS), no luck either.
    Disconnected peripherals from the board, no luck. Also tried with only battery, or only AC. Did a BIOS reset. Remove RAM stick, so it would force a BIOS reset, cause it detected a different RAM configuration. And it did detect. But also no luck.
    It seems to me a BIOS issue, but can't confirm that.
    Did anyone have this issue before? How was it fixed?
    Thanx a lot.
  • BMCappelletti
    • Nov 2021
    • 152
    • Brasil
    In addition to that:
    - tried PXE boot, with same issue. Just a blank screen.
    - changed start up option on BIOS from quick to diagnostics. It first shows information as BIOS version, processor, memory, etc. Then it show the message "ThinkVantange Active Protection sensor diagnostics start".
    It does not show any errors, but that message just flashes on the screen and nothing happens.
    Unfortunately it's not possible to disable that on BIOS to check if that could be an issue.
    I don't have a WSON8 adapter here to backup the BIOS and ask someone to check it for errors, so I'll need some days to get one.
    Still ideas on what else to try are valid.
    Thank you.
    • rddube
      Aspiring Expert
      • Jun 2013
      • 954
      Sounds to me like a corrupt BIOS, so I would get a CH341 adapter, reflash the BIOS (you can probably get a dump here on Badcaps) and I think you should be back in business. Make sure if there are more than 1 bioses to flash both. Let us know.
      Take a look here https://www.badcaps.net/forum/troubl...kpad-e14-gen-3 or here https://www.badcaps.net/forum/troubl...nkpad-e14-bios
      • BMCappelletti
        • Nov 2021
        • 152
        • Brasil
        Yep. I bought a WSON8 adapter, as I did not have any. Will receive it tomorrow.
        Thanx for the links.
        Will report back here.
        • rddube
          Aspiring Expert
          • Jun 2013
          • 954
          So what happened ?
          • BMCappelletti
            • Nov 2021
            • 152
            • Brasil
            So what happened ?
            Delivery was delayed. Will probably receive it this afternoon.
            Will post here when I try it.
            • rddube
              Aspiring Expert
              • Jun 2013
              • 954
              Did you get your programmer?
              • BMCappelletti
                • Nov 2021
                • 152
                • Brasil
                I had already a programmer. A EZP2019+, but I didn't have the adapter for SOP8. I got it, but EZP software was not able to detect the BIOS chip. It's a Winbond 74M25JWEIQ. I was able to read the chip and write a new one selecting W25Q256 chip model. But the new file (and the original one) is not working. I only get a fan spin (and then stop) and a steady white light around the power button. It does not boot.
                So either I have a problema with the BIOS chip or the programmer I have is not suitable for this.
                • BMCappelletti
                  • Nov 2021
                  • 152
                  • Brasil
                  I'm back to the original "To interrupt normal startup, press Enter" screen, after writing the BIOS again using CH431 device and the .bin file extracted from the Lenovo installer.
                  So it does not seem to be a BIOS issue after all.
                  I'm attaching the original BIOS here, if someone want to take a look.
                • exe557
                  • Jan 2021
                  • 24
                  Is the cmos battery ok? I had a fully depleted one on an E490 and it got also stuck. Try without the CMOS battery
                  • BMCappelletti
                    • Nov 2021
                    • 152
                    • Brasil
                    I tried without it. No luck. Same behaviour.
                    What I found odd is that it does not boot from any device, even though I used the extracted BIOS from the Lenovo website.
                    That tells me that something else is wrong on the laptop and preventing the laptop to see that those devices are bootable. Or preventing to use them for that, because they show just fine in BIOS.
                    • rddube
                      Aspiring Expert
                      • Jun 2013
                      • 954
                      I'm attaching the original BIOS here, if someone want to take a look.​
                      Ok, so read this thread https://www.badcaps.net/forum/troubl...nkpad-e14-bios - go in the same section and upload your original bios and ask someone to Clean the ME.
                      • BMCappelletti
                        • Nov 2021
                        • 152
                        • Brasil
                        It's AMD.
                        • rddube
                          Aspiring Expert
                          • Jun 2013
                          • 954
                          It's AMD.
                          So ? Doesn't matter. You want to fix it or just abandon? Cleaning the ME of a Bios has nothing to do with the CPU brand or type.
                          • BMCappelletti
                            • Nov 2021
                            • 152
                            • Brasil
                            I thought ME region would be something only on Intel CPUs, for some reason.
                            Anyway... a friend wanted the screen to replace on another device. He ended up buying me the whole thing. So I don't have it anymore.
                            Thanx anyway.
                              • 21968
                              Thanx anyway.
                              ME Firmware is only for Intel CPU`s.
                              • BMCappelletti
                                • Nov 2021
                                • 152
                                • Brasil
                                So I was not that wrong.
                                Thanx for confirmg it.
                                • mindoverflow
                                  ASUS GTX 1650 Gpu.Initialize Interrupt request line stuck asserted
                                  by mindoverflow
                                  hello,
                                  there is an asus gtx1650 which displays fine in windows but if i run a benchmark test it displays artifacts and the driver crashes after a second or two.
                                  I changed pads and thermal paste.
                                  I run mats test but it is reporting 0 errors.
                                  I then tried to run the mods version 400.271_1650 test, it first ran and stopped with a 'breakpoints limit reached after 5 retries' error and the fans went full speed.
                                  After a reboot, I tried to run the test again, but now the test fails and says "ERROR: Couldn't clear GPU's interrupt...
                                  02-09-2022, 03:22 PM
                                • Stunt
                                  Hp Laptop Stuck on Hp protected by hp sure start screen
                                  by Stunt
                                  Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                  I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                  I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                  Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                  screen that's it and stuck there. I left it until the following day and i still...
                                  09-02-2025, 01:51 PM
                                  LENOVO ThinkCentre M920 + ThinkCentre Tiny-in-One (TIO) 24 Gen3 ThinkCentre M i5-8500T Specification for Upgrade or Repair
                                  This specification for the LENOVO ThinkCentre M920 + ThinkCentre Tiny-in-One (TIO) 24 Gen3 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M920 + ThinkCentre Tiny-in-One (TIO) 24 Gen3 boardview and ThinkCentre M920 + ThinkCentre Tiny-in-One (TIO) 24 Gen3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                                  09-12-2024, 01:58 PM
                                • edugimeno
                                  Te systems tv stuck in startup logo
                                  by edugimeno
                                  Hi there!
                                  This tv set (TD systems) is posted for sale with this issue.
                                  Stuck in boot up logo
                                  Is this something that can be fixed easily like an USB fw upgrade?
                                  Or does it need any specific hardware programming adapter?
                                  Thanks in advance!!...
                                  06-27-2023, 09:02 AM
                                • Instafixx
                                  Macbook A2179 820-01958
                                  by Instafixx
                                  Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
                                  The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
                                  I checked the Power Sequences below and found this -
                                  Once a valid external power source (Charger or battery) is connected, the following rails will come online.
                                  PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
                                  PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
                                  05-20-2023, 05:19 AM
