ASUS G513QY No power
  • tommy97
    • Mar 2023
    • 165
    i'm having a asus with no power, found shorted mosfet next to the battery connector marked: q6/400 (0N ALB17PF), while mosfet is removed laptop switches on. I've tried to find this dual mosfet however no result.
  • mon2
    • 14657
    Post a clear pic of this mosfet.
    • tommy97
      • Mar 2023
      • 165
        • 21841
        FDPC5018SG https://www.badcaps.net/forum/troubl...45#post1488245
        • tommy97
          • Mar 2023
          • 165
          Thanks, problem resolved.
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • Thomas Smith
            Asus Tuf gaming fx506l no power, mosfet does not open
            by Thomas Smith
            Hello everyone, I have an ASUS FX506LI laptop that does not turn on, and I need help diagnosing the issue. Here is what I have checked so far:
            Initial Symptoms:
            • The laptop has no power at all (no LEDs, no fan spin).
            • No 3.3V or 5V present on the board.
            • The power button (NBSWON#) reacts but only changes from 0V to 0.5-0.11V.
            Power Rail Checks:
            1. Charger input (FETs PKCH2BB)
              • Drain: 20V, Source: 0V, Gate: 0V (FETs not switching).
            2. BQ24780S Charger IC:
              • VCC and ACDET are present.
              • ACN / ACP, ACDRV, BATDRV, LODRV, HIDRV, ACOK, SRN, SRP – all 0V.
              • Shunt resistor has 10Ω to ground.
            03-30-2025, 03:38 AM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • ShadowAi
            ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
            by ShadowAi
            Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
            Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
            After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
            03-15-2024, 10:46 AM
