HP 15-dy0013dx doesn't Power On, Power LED Bilinking, needs help for trouble shooting
    Hello Every Genuis
    I have a laptop from my friend, model is "HP 15-dy0013dx" , Logic Board model is DA00P5MB6D0 REV MODEL: 0P5
    this Laptop come with a BIOS Warning issue, the Keyboard CAPS LED Blinking 3 times slow, 2 times fast , don't remember exactly, someting like this, has a Meaning , also Fan will run
    but I googled, people says this Meaning EC have a issue to read BIOS, so I use CHA314A programmer to read and write (wrote the same content file read from BIOS), after I flashed the BIOS, the CAPS LED doesn't blink anymore
    symptom changed, after Press Power Button, Power LED Bilinking repeatly but slow, longer than a second, looks like EC powered on ,and faild, and try to power on again, only this action, FAN not run
    I purchaged a Programmed EC from aliexpress, replaced, same issue
    and I downloaded BIOS file from here, even I used Clean ME bios which I build , same issue
    Other Person's BIOS file write to FLash, same issue
    I dont have a current meter, can't tell how much is the current, but pretty sure no Shortage , just Power LED Bilinking
    help me with any clue, thanks Guys
    I know this place is a good place, will keep updates for this Laptop in this thread!
    Thanks Again
    If you desolder bios take a Clear picture of the area maybe you move something or maybe you have a Bad solder on your chip.
      Have you tried with a different ram ? if you still have a copy of your original bios dump try to verify it before soldering it back on the mother board
      else request or search for a bios on the forum and try that
        my Solder skills are pretty good, use NeoProgrammer to read and write and verify BIOS Chip working good, no issue
          I don't have other ram ,but this laptop have two rams , and I removed both ram to test, dont need a ram presents before BIOS warning i believe
          the problem is now the laptop even dont have a speaker Warning or Caps Lock Bilinking warning , or even the CPU Fan doen't run
            I forget AC Adapter in Company this weekend, i use battery tested again
            With batter installed, before I pressed the Power Button, i got some voltage
            VIN 12V88
            +3VPCU 3V39
            +BAT_RTC 3V21
            after Pressed Power Button
            EC ITE_5570
            S5_ON 3V3 when Power LED On
            +3VL_EC 3V3
            +3VL_ECACC 3V3
            +1.8V_DEEP_SUS 1V8 when Power LED On Resistance Good
            SLP_S3# 0V Resistance Good
            SLP_S4# 0V Resistance Good
            i believe the CPU not even reached to S4 Level, still have some issue before quit from S4, let alone S3
            I checked EC around,
            > Thermal Signal was good
            > LID signal was good
            When I cloded the LID , the Power-Off-Power sequence sitll running, I believe the issue was in early stage
              If you miss SLP4 & 3 check presence:
              • DSWROK_EC
              • RSMRST#
              • EC_RTC_RS
              • RTC Crystal
              PS: i'm sure too you don't break the BIOS chip but you may have move some resistance or whatever around bios chip
                • DSWROK_EC 0v
                • RSMRST# 3v3
                • EC_RTC_RESET YES, from Low -> HIGH
                • RCT Crystal YES , WAVE Good, 33K
                  According Schematic Page 2, VIN and S5_ON generates 4 Power signals +3VPCU , +3VS5 , +5VPCU and +5VS5
                  those voltage all Presents well
                    Delted
                      also ,there is NO CLK_24M_KBC
                      if NO 24M Clock to EC causes NO SUSON signal from EC, that make sense
                      anyone can tell is SUSON depends on EC firmware?
                      also CLKRUN# alwasy LOW, which means EC didn't work!
                        I'm pretty sure SUS_ON need SLP_S4 to start.
                        CLKRUN# => is low ON, this signal is supposed to be low on normal operation.
                        CLK_24M_KBC low maybe a problem, check both side of R1203 if it's present?
                        Check DNBSWON# too.
                        I'm pretty sure you PCH you need DSWROK_EC to start the SLP_S4.
