ASUS ROG GL552VW REV 2.0 Unable to power ON
    Hi All,
    • I bought faulty ROG recently from my friend hope that I can fix it by myself since it more thrill to repair it. Model ASUS ROG GL552VW REV 2.0. Refer picture below. I fix few faulty laptop some of that success because of faulty caps. But for this ROG, I'm stuck. From power sequence, 19V, 3V5V is present.
    • The power present is from No 1 until 17 (PM_RSMRST#) during power button is being push. But at No 18 (PM_SUSC#, no signal SLP_S4# coming from PCH. And no signal so on.
      Signal available mostly 3.3V
    1. +3VA
    2. PS_ON
    3. +3VA_EC
    4. EC_RST#
    5. 3VADSW_ON
    6. 3VA_DSW_PWRGD
    7. DPWROK_EC
    8. PM_SLP_SUS#
    9. VSUS_ON
    10. 5VSUS_ON
    11. 3VSUS_PWRGD
    12. PM_RSMRST#
    13. SUSWARN#
    14. ME_AC_PRESENT
    15. PM_SUSACK#
    16. PWR_SW#
    17. PM_PWRBTN#
    • I've check for short and trace the line, it's ok. Diode mode 0.5. I just change the BIOS which is from this forum too, also no sign of life.
    • Power Supply showing 20V, 0.012A, during power on is only 0.016A. Use thermal camera only the LAN IC is a bit hot 30DegC. All coil reading seem ok. Appreciate your Pro's help me here. I feel really stuck.😥
Name:	WhatsApp Image 2025-02-04 at 11.23.01_2dc7df14.jpg
ID:	3563610 Click image for larger version
Name:	WhatsApp Image 2025-02-04 at 11.23.00_cf9ab5f0.jpg
ID:	3563611 Click image for larger version
Name:	WhatsApp Image 2025-02-04 at 11.23.00_2dc52801.jpg
    Is the battery charging?
    If not, it might be the 32.7khz Crystal.
    You need a signal analyser or an oscilloscope to Check it.
      pc_okay,
      Yes battery able to charge with 16V. Refer pictures
      What I've done so far, took out the LAN ic, still no sign. PSU show 0.000A. Trace all the line, no short for PM_SUSC# and SLP_S4#. Reflow the PCH HM170, still the same. Advice Any other things need me to check. My oscilloscope still otw from China😥
Name:	WhatsApp Image 2025-02-05 at 11.58.30_fd5d20bc.jpg
ID:	3564464 Click image for larger version
Name:	WhatsApp Image 2025-02-05 at 11.58.32_388523d0.jpg
ID:	3564465 Click image for larger version
Name:	WhatsApp Image 2025-02-05 at 11.58.31_e322576b.jpg
ID:	3564466 Click image for larger version
Name:	WhatsApp Image 2025-02-05 at 11.58.30_a822a768.jpg
        +12V present?
          @mcplslg123 mean voltage from battery? from the coil show 16V
            No. I mean +12V rail working?
            Have u checked powergood signals?
              For +12V signal is not available since it coming from power No (20) SUSC_EC#, and before SUSC_EC# is (19) PM_SUSB# and PM_SUSC# which is i'm stuck now. The +12V rail is ok no short. 3VSUS_PWRGD and +5VSUS_PWRGD is available.
