2021 MacBook Pro 14" M1 Blown Cap Near PMIC
  • mgrharry
    • Sep 2016
    • 211
    • usa
    Got a 2021 14" MacBook Pro M1 here that died suddenly. No signs of liquid damage. However there was a strong burned smell. Upon removing and flipping the board I found a burned cap C9400 near PMIC U9300. Photos attached. Should I just proceed with replacing U9300 and some of the surrounding caps? Also, I don't have any donor boards from this generation of MacBooks, maybe could locate a compatible cap from an older touchbar model?
  • mgrharry
    • Sep 2016
    • 211
    • usa
    I think this should be compatible: https://www.mouser.com/ProductDetail...6jASrGIQ%3D%3D
    Thoughts?
    • mon2
      • Dec 2019
      • 14191
      On the bottom side plate there should be an A**** laser marking. What is this number?
      On your board, you should have a 820-**** number on the PCB (usually in copper covered in black solder mask) - if available, what are these details? Each will help to determine the exact board you have.
      Also, unable to view the posted photos in the first post.
      • mgrharry
        • Sep 2016
        • 211
        • usa
        Not sure what happened to the photos, they were loading before. Here are some imgur links:
        https://i.imgur.com/wawkeqC.jpeg
        https://i.imgur.com/y6n1gw6.jpeg
        Macbook is model A2442. The logic board number is 820-02098-07
        Thanks!
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 667
          Those CAPS are power caps, I would replace all the suspected CAPS that are blown. Test each cap that doesn't look blown, remove the blown cap and test for short to ground, see if the Line is still shorted after you remove the bad cap. If it is still shorted trace back to that long on the schematic and find what areas are connected. I suspect this would be an easy fix.
          sigpic
          MEOWING IN THE IMPOSSIBLE UNIVERSE!
          • arahban
            Apple MacBook A2442 faulty PMIC - Question about possible replacement
            by arahban
            Hello Gentlemen,
            I am working on an apple MacBook A2442 board pn 820-02098-A with a visible short on the PMIC U7700 MVK-PLUS as per the schematics
            I have a donner board from apple macbook pro m1 A2338 PN 820-02020 and I saw that the PMIC U8100 TMLT46B0-JPE could be a possible replacement for the U7700
            Can you please help me confirm if the U7700 can be replaced with U8100 ?
            APL1098 is it the same as APL1096
            Thank you very much in advanced
            Ahmad
            12-23-2023, 05:25 AM
          • envym
            MacBook Pro 2018 with Activation Lock
            by envym
            Hi everyone!
            I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
            I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
            06-27-2025, 08:54 AM
          • tobeend
            Bypass mdm macbook m2 ventura
            by tobeend
            1. RESET MACOS WITH IPSW
            a. Power off MacBook, press and hold the power button to enter Recovery
            b. Open Disk Utility, remove Macintosh HD
            c. Reboot, connect to the network to Activate Mac.
            d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
            d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
            e. Release the other keys, but keep holding the Power key for another 10 seconds
            f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
            05-26-2023, 07:18 AM
          • dellxps15
            macbook a1707 15 inch trackpad dead. blown fuse identification
            by dellxps15
            hi all, got this macbook with dead trackpad. after some investigation i found that fuse is bwlown. it's marked with a K on it. anyone kjnow it's value ? it is a 0402 package.
            another problem is: i tried another trackpad that was working fine, but the feedback sensor was not. all volts are present, but the click mechanism isnt .
            04-30-2024, 10:48 AM
          • SarcasticOP
            General question about MacBook power rails for repair.
            by SarcasticOP
            I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
            • PPBUS_G3H (12.6V-12.8V)
              • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
            • PP3V42_G3H (3.42V)
              • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
            • PPVRTC_G3H (3.3V)
              • This
            12-12-2024, 05:50 PM
