Lenovo Thinkpad Yoga X1 Gen 6 no charging
  • Andreasbest
    • Aug 2014
    • 1196
    • Hellas ( Greece )
    Hello.
    I received a yoga 6th gen ( nm-d341 ) that is not charging, tried both charging and thuderbolt ports but no charge, i don't see any physical damage on them, in fact they look like new.
    When i use charged battery works great, i updated to latest bios as i saw a warning from lenovo regarding urgent update to fix charge problems and also updated ME firmware, no luck.
    What do you suggest?
    schematics and boardview: https://www.badcaps.net/forum/troubl...tic#post102868
    Thank you in advance!
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Someone with 1000+ posts and still no measurements shared?
    • Andreasbest
      • Aug 2014
      • 1196
      • Hellas ( Greece )
      I never managed to understand schematics reading. i'm going with boardview, just tell me what to measure.
      • pc_okay
        • May 2022
        • 243
        • FRANCE
        Check Vsys18 voltage first without battery.
        • rediii
          h???, spurrrn
          • Mar 2018
          • 499
          • somewhere in europe
          Originally posted by Andreasbest
          Hello.
          also check this:
          https://www.badcaps.net/forum/troubl...6-series-fault
          • Andreasbest
            • Aug 2014
            • 1196
            • Hellas ( Greece )
            I managed to get some bench time today.
            The motherboard has no visible burned components neither heat indication.
            I measure 3.3v on C9718 and 5v on F43.
            I check on F7 for vsys18 but nothing there too.
            What do you think?
            update:tried to measure Q263 and just desolder like it was never soldered. The contacts underneath seem dirty, i'll try to clen them and resolder it.
            update #2: after i solder back Q623 with fresh solder, flux and low velocity hot air i get many 3.3v and 5v voltages but still no power up with charger.
            update #3: when i connected the battery i saw power and charge, all working now.
            • Andreasbest
              • Aug 2014
              • 1196
              • Hellas ( Greece )
              Repair complete.
              As stated on another thread the problem is on these 2 components, they get extremely hot and solder breaks.
              • mon2
                • Dec 2019
                • 14659
                Thanks Andreasbest for your update. The LGA packaging was just a horrible idea by someone. Can only imagine how many units of the same are tossed away from the same fault.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Sourcing them is not easy in every location and are expensive as well.
                  • Andreasbest
                    • Aug 2014
                    • 1196
                    • Hellas ( Greece )
                    They told me that gen 2 T14x have also the same fault, we will have a lot of work the next years with these components.
                    Warranties just expired.
                    • rediii
                      h???, spurrrn
                      • Mar 2018
                      • 499
                      good to know, so i was right. keep in mind, that you might cool them with a thick thermal pad.
                      • Andreasbest
                        • Aug 2014
                        • 1196
                        • Hellas ( Greece )
                        I thought about it too but there is no metal over them to absorb the heat.
                        One idea was to buy thermal glue and put a small piece of copper in top of them.
                        I'll try, there is no other way to cool them.
                        • rediii
                          h???, spurrrn
                          • Mar 2018
                          • 499
                          that's a good idea, too.
                          • Cavallonzio
                            • Mar 2025
                            • 4
                            • Italy
                            Hi, does anyone know the value for the capacitor above q263? it's blown on my laptop but i dont know the value to use to replace it
                            • mon2
                              • Dec 2019
                              • 14659
                              Is it C3037?
                              • Cavallonzio
                                • Mar 2025
                                • 4
                                • Italy
                                Is it C3037?
                                exactly, so I need to replace it with a 10 μF 25V capacitor, am I right?
                                • pc_okay
                                  • May 2022
                                  • 243
                                  • FRANCE
                                  Yes With 0603 physical size.
                                  • Cavallonzio
                                    • Mar 2025
                                    • 4
                                    • Italy
                                    I've replaced C3037, but it still doesn't boot. I can charge the batter (my smart plug reports 60W drawn) the amber light turns on when plugged in, but it just doesn't boot, no fan spinning, nothing. What can I check on the board?
                                    • Andreasbest
                                      • Aug 2014
                                      • 1196
                                      • Hellas ( Greece )
                                      Have you tried RTC reset?
                                      Remove all power sources: charger, main battery and rtc battery and hold power button for 30 secs, then connect charger and see if powers on.
                                        Lenovo ThinkPad ThinkPad X1 Titanium Yoga Gen 1 Notebook Yoga Specification for Upgrade or Repair
                                        This specification for the Lenovo ThinkPad ThinkPad X1 Titanium Yoga Gen 1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad X1 Titanium Yoga Gen 1 boardview and ThinkPad X1 Titanium Yoga Gen 1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                        09-07-2024, 04:10 AM
                                        Lenovo ThinkPad ThinkPad X13 Yoga Gen 2 (Intel) Notebook X Specification for Upgrade or Repair
                                        This specification for the Lenovo ThinkPad ThinkPad X13 Yoga Gen 2 (Intel) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad X13 Yoga Gen 2 (Intel) boardview and ThinkPad X13 Yoga Gen 2 (Intel) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                        09-07-2024, 05:00 AM
                                        Lenovo ThinkPad Yoga 260 Ultrabook Yoga Specification for Upgrade or Repair
                                        This specification for the Lenovo ThinkPad Yoga 260 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 260 boardview and Yoga 260 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                        09-06-2024, 06:48 AM
