identify component
  • karlox
    • Dec 2017
    • 138
    • México
    identify component
    Help identify this regulator, Thanks
  • mon2
    • Dec 2019
    • 14662
    From which board? Share a pic of the board location to confirm the function of this part.
    It *may* be the TI TPS562208DDCR but need to check if you have the horizontal bar markings.
    https://www.aliexpress.com/item/1005005824041595.html
    https://www.ti.com/product/TPS562208.../TPS562208DDCR
    • karlox
      • Dec 2017
      • 138
      • México
      Thank you, if that's it... thank you very, very much
      • mon2
        • Dec 2019
        • 14662
        Suggest to apply alcohol to the top surface to clean off the flux / top side. Then compare the SMD markings of the TPS part with the 2208 markings. Do you also have the bars on the surface? Hard to tell from the posted pic.
        • karlox
          • Dec 2017
          • 138
          • México
          The bars are in a different position, is it important? From the data sheet I reviewed TPS562208DDCR, it is viable because the circuit is supplied by 12v 1a
          • mon2
            • Dec 2019
            • 14662
            This is the same part (TPS562208DDCR) from TI.
            I would replace it and source the original from:
            TI.COM website ; often they supply free samples if you sign up for an account
            Digikey
            Mouser
            Arrow
            Use Aliexpress only if you must since this part is available through normal distribution.
            • karlox
              • Dec 2017
              • 138
              • México
              Digikey
              Mouser
              Arrow
              Sorry, but since you managed to identify it, it took me all morning searching through data sheets and diagrams before asking for help here.
              • deep000
                Burned Voltage Regulator in Monitor – How to Identify and Repair?
                by deep000
                My computer monitor ASUS VP249H stopped working, and smoke came out of it.
                I opened it and found that a voltage regulator had burned out.
                The problem is that I can't identify its reference.
                I searched online for schematics or photos of similar boards that people are selling, but without success (no schematics, bad quality of the board or lack of the reference when it's a good quality 😅).
                How can I find its reference, and do you think it's repairable?
                Monitor: Asus VP249H
                Board reference: 0171 - 2271 - 6083
                09-08-2024, 01:13 PM
              • Stunt
                Help me identify this chip the markings is AKLG 302
                by Stunt
                Hi i need somebody to help me identify this chip the markings is AKLG 302. It's on Hp Pavilion 14-am 245 G5 6050A2823301-MB-A02 motherboard
                06-19-2023, 12:30 PM
              • electroelef
                identify and buy a voltage regulator, Audj833
                by electroelef
                I am trying to identify and buy a voltage regulator.
                The casing is somewhere between SOT563 and SOT963.
                So it's 6-pin. Lenght of the capsule is about 1.2mm and the width 1mm.
                Codes on the capsules are:
                AUDJ833 or AUDM633 or AUDK897. All codes are used in the same model of device as a voltage regulator from +5v down to +3v3 so they should be interchangeable.
                pin2 is ground
                pin3 is Vin +5v
                pin6 is Vout +3v3
                pin4 is connected through an L to pin6
                I spent quite a while looking for a replacement to buy.
                Any help...
                07-20-2022, 06:47 AM
              • digitalDNA
                Failed to identify SMD component with markings 81 and 947 and package SOT-89
                by digitalDNA
                I can't identify a component labeled Q1 on the main board of a redundant server PSU from Etasis, product name EFRP-465
                ICs on the board have labels with prefixes U, so we have U1, U2, etc. The mysterious component is labeled Q1, so it must be a transistor (BJT)/MOSFET/etc.
                I have attached the image for Q1.
                I have searched multiple SMD reference websites without being able to identify the component.
                Here is some important information from the board::
                1. Pin 2 and the tab are connected to GND (after unsoldering Q1,...
                10-07-2022, 04:47 PM
              • taurtnt
                Help identifying AMCH073 regulator or finding a compatible replacement
                by taurtnt
                I’m trying to identify a step-down regulator marked AMCH073. It’s used on the PEX power rail of a graphics card. I can’t find any datasheet or info online.
                Here’s what I’ve observed:
                • It has a QFN-16 footprint, similar to NB670.
                • Pins 1, 2, 15, 16 are connected together and go to the inductor, so likely SW (switch node).
                • Pin 9 is connected to GND, which doesn’t match NB670 (where pin 9 is SW).
                • Pin 8 also seems to be tied to the same GND plane.
                • The chip only says AMCH073, no manufacturer logo or other markings....
                08-24-2025, 03:06 PM
