LA-E921P no power
  • ictc
    • May 2015
    • 46
    • Italy
    LA-E921P no power
    Hi, this board does not power on, Vin present on PQ303 drain but on its gate ACDRV_CHGR is around max 2,6V unstable. No short in most of the power rail caps and shunts, pq303 and pq304 not shorted as well. VCC on pin 28 of pu301 present, ACPRN_CHGR also present 6v stable. No Short on caps around pu301 and +19V_CHG. What could preventing the pu301 from boosting acdrv to 25V?
  • mon2
    • 13992
    What is the voltage to ground of ACDET on the charger IC?
    Each resistance check on a mosfet must be hundreds of k ohms or higher else the mosfet is most likely defective. Flux & remove PQ304 from the circuit and power up again. What is the ACDRV voltage to ground now after this mosfet is removed?
    • ictc
      • May 2015
      • 46
      • Italy
      Apologies, I mistakenly wrote 2.6V, while the actual measured value, with and without the MOSFET, oscillates between 0.26V and 0.57V. I apologize for reporting an incorrect value. Removing the second mosfet the ACDRV rise finally to it's default value. Diode mode measurment on PR335 and PR304 gives 0,4V I think there is no short on that side, should I blame just the mosfet?Iìm also measuring 0,5V drop between source and drain in both direction on that mosfet that means is leaking in some way. I'll try to replace it and get back.
      • ictc
        • May 2015
        • 46
        • Italy
        I replaced the MOSFET with a working one (I can now read the diode voltage drop in one direction only), but the ACDRV_CHGR voltage dropped again. I suspect that something is triggering the charger IC to stop providing that voltage whenever it receives feedback from a source unknown to me.
        • mon2
          • 13992
          Remove all power. Meter in resistance mode. Measure the resistance between ACP and ACN pins directly on the charger IC. We are testing the full resistance path of the current sense leg of the main power rail. Again, no power to the board during this testing.
          • Sephir0th
            • Oct 2020
            • 1262
            You should not replace parts on your own from here since this adds unknown factors this way which will make the repair even more complicated.
            And if you replace something anyway, you need to state exactly what component make/model you have replaced with what component make/model.
            When a Mosfet doesn't show continuity between Source and Drain or Source and Gate then it is fine in 99% of the cases. It must be something else.
            Second, you were asked for ACDET voltage. Please share the voltage.
            If VCC, ACDET, REGN & current sensing checks out, nothing obvious visually to notice and there is no short to GND at +19VB then it is most likely a dead charging controller.
            FairRepair on YouTube
            • ictc
              • May 2015
              • 46
              • Italy
              Resistance between ACP and ACN pins is 0.16Ω. ACDET remains steady at 2.6V (within specifications), REGN still 6V but ACDRV drops when the second MOSFET is connected. Could this be due to a feedback or protection mechanism within the BQ24780 being triggered?
              The original MOSFET was a B04N03 (BVDSS: 30V, RDSON(MAX): 4.0mΩ, ID: 75A), which was replaced by a 3N1R8 (BVDSS: 30V, RDS(ON): 1.89mΩ, ID: 165A). The replacement MOSFET has better overall specs, and I'm not concerned for this kind of application about the higher gate capacitance of the AP3N1R8MT (~3800 pF).
              By the way, I initially wrongly thought the original MOSFET was leaking, (hoping for an easy and fast resolution) but after further testing, it appears to be fine and soldered back in its position. Should I blame than just the controller or should I better consider
              • A short circuit or overload downstream after the second MOSFET.
              • Instability in the sensing or feedback loop, especially on ACN/ACP
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Is the 19V line pulsing as measured on CLR?(both dc-in fets soldered).
                • ictc
                  • May 2015
                  • 46
                  • Italy
                  Yes, the 19V line is pulsing. It appears just unstable, fluctuating between 5.5V and 6.5V, but using the DMM's min/max function, it shows a pulsing range from 0.168V to 6.66V.
                  • mon2
                    • 13992
                    Remove all power. Meter in resistance mode. Measure the resistance to ground of the same 19v line. What is the exact measurement in ohms? No power to the board during this test.
                    • ictc
                      • May 2015
                      • 46
                      • Italy
                      Measured after the CSR, the resistance starts at approximately 20 MΩ and then decreases very slowly, resembling a capacitance discharge. It drops to 14.566 Ω before starting to increase again. If I disconnect one lead, the measurement restarts, suggesting to me that some active components might be influencing the reading.
                      • mon2
                        • 13992
                        Are the units correct? ~15 ohms??
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Check VCC resistor again for exact 10 ohms. Measure voltage on both ends of this resistor.
                          To me it seems like VCC resistor is out of value.
                          • ictc
                            • May 2015
                            • 46
                            • Italy
                            15000 ohms.. I meant 15K, sorry for the mistake
                            • ictc
                              • May 2015
                              • 46
                              • Italy
                              The VCC resistor measures 10 ohms. The voltage is present on both side but not steady, oscillating between 14.2 and 14.4 volts
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                VCC must be stable 19V for charging ic to function. Remove the 10 ohms resistor from mb and measure resistance to GND on both ends of this resistor pads.
                                Check the dual diode that feeds this VCC resistor
                                • ictc
                                  • May 2015
                                  • 46
                                  • Italy
                                  Removed PR312 and measured the resistance to ground. From diode PD301 side it is 2.9M and on the IC PU301 side is 1.7M. The dual diode also seems fine to me, about 0,28V of voltage drop in diode mode on both diode.
                                  • mon2
                                    • 13992
                                    Is it a stable voltage if the dual diode is removed? Then the charger IC is not being powered and the raw adapter voltage will be present at Vin of the dual diode.
                                    • ictc
                                      • May 2015
                                      • 46
                                      • Italy
                                      Not at all. +19V_VIN is 19.5V as it should be, but the output of the dual diode is still not stable, fluctuating sometimes between 20.7V and 22.9V. I also noticed that on the +19VB pin of the same diode, the voltage is sometimes 0V and other times randomly varies between 2.3V and 5V.
                                      When the adapter is connected for the first time, I have approximately no +19VB and an almost steady 20.6V on +19V_VIN. After a while, +19VB starts increasing, and +19V_VIN begins to fluctuate as well. However, these two events don't appear to be directly correlated, as at the moment, I have 20.5V on the diode's output and almost 0V on +19VB.
                                      I wonder why I'm observing random voltage spikes on pin 2 of the diode, where +19VB is not supposed to exist under this condition?
                                      • mon2
                                        • 13992
                                        I wonder why I'm having +19VB kicking in on pin 2 of that diode?
                                        If using only the adapter and yet you are observing this voltage on pin #2 of this dual diode = this diode is defective and leaking. Flux & replace this dual diode. Test again after this replacement.
                                        • ResoluteHawk
                                          Quanta 0P5 (DA0P5HMB8E0-Rev E) Missing ACDRV
                                          by ResoluteHawk
                                          I have an HP 15-DY laptop in because the battery is not charging.
                                          If I use a charged battery, the laptop powers on but the battery will not charge, however the orange charge light does turn on. The laptop loses power as soon as I disconnect the battery.
                                          I've replaced the BQ247 chip with a known working one and I get the same issue and the same measurements.
                                          Measurements are as follows:
                                          BQ728 IC
                                          VCC (Pin 20) => 19V
                                          CMSRC (Pin 3) => 0.8V (This is a problem but I can't figure out what's causing the low voltage)
                                          ACDRV (Pin...
                                          04-10-2025, 11:36 AM
                                        • AleX.dans.les.nuages
                                          Lenovo Ideapad Gaming 3 15ACH6 doesn't charge
                                          by AleX.dans.les.nuages
                                          Hello from France
                                          My daughter spill some water on her laptop... Lenovo Ideapad Gaming 3 15ACH6, and she doesn't seen anything wrong after just remove the water with towel.
                                          Then, later the laptop won't start anymore.
                                          I've made a basic troubleshoot with my own laptop (same series)
                                          So, the computer battery is totaly out. With my battery, the computer works !
                                          But, with PSU connected, the latptop detect the power.. the harware led white is on, the amber one too and on the screen there is a 'batt charging' message.
                                          But...
                                          04-13-2025, 12:38 PM
                                        • zaurus81
                                          Asus TUF Gaming F16 (2024) FX607J no power no ACDRV
                                          by zaurus81
                                          Hi all, I have a Asus TUF Gaming F16 (2024) FX607J motherboard with liquid damage. The oxide on the board was removed before giving it to me. This made it more difficult to repair. Also they did not give me the power supply.
                                          When I connect the 20 volts with the bench power supply I get 4.3 volts on the main power line. If I remove the power sensing resistor I get 20 volts on one side (first 2 mosfets are ok) and 4.3 volts on the main power line (see photo). How is this possible?? I thought the 4.3 volts was coming from the battery mosfet so I unsoldered it and tested it. It is ok too. I...
                                          11-21-2024, 05:04 AM
                                        • elsomer
                                          Acer nitro 5 bq24781 no acdrv
                                          by elsomer
                                          Hi people, i have an acer nitro 5 with motherboard model gh51m la-k861p , it came with the resistor pr103 blow up, i repaced that resistor, i check the coils plb2, pl301, pl501 and has no short to ground, i conect the charger and it doesnt power at all, i check pqb3 on pin 5 to 8 and its 19v, pin 1 to 4 its 0
                                          so i repaced, pqb3, pqb4, and makes no change, still no acdrv, i replaced bq24781 and makes no change, still no acdrv, if someone can help pls, thanks, this are the schematic and boardview
                                          [MOD EDIT] LINK to schematic & boardview -> https://www.badcaps.net/forum...
                                          04-22-2024, 11:30 AM
                                        • husnu16
                                          Lenovo LOQ - LA-N221P Rev 1.0 Schematics or PU301 ic code?
                                          by husnu16
                                          Hello my precious masters;
                                          Lenovo LOQ - LA-N221P Rev 1.0 I need the code/model number of the PU301 integrated circuit on this mb. The integrated circuit is burnt and cannot be read. Can you help me with this?
                                          12-21-2024, 04:29 AM
