What is the smartest way ?
+ More Options
Posts
  • Jane
    • Aug 2010
    • 188
    Laptop ACER aspire 1 a114-32 (n17q4 ) has dark screen. If I push On/Off button the laptop seems to start ( including blue led light) but no picture.
    What is the best way how to identify the reason? Whether is a culprit LCD panel or LVDS cable or mainboard ?
  • rogfanther
    • Jul 2006
    • 458
    • Brazil
    Connect it to an external display. Does it show image correctly then ?
    • FriedFred
      • May 2024
      • 137
      Light-in with a torch. If you can see a picture, then the background-light is off.
      • pc_okay
        • May 2022
        • 243
        • FRANCE
        So Many possibility!
        After testing other suggestion you may try:
        Checking caps lock too, does it respond when you press it?
        • Jane
          • Aug 2010
          • 188
          Respond, how?
          • pc_okay
            • May 2022
            • 243
            • FRANCE
            Sorry, if there is no caps lock indicator on this laptop plug an USB keyboard with an indicator.
            The caps lock LED will light ON and light OFF when you press it if laptop is POST.
            If nothing happen it may not be a screen problem.
            • Jane
              • Aug 2010
              • 188
              Thank you for the explanation.
              • Natob82
                Micro Momentary Push Switch?
                by Natob82
                Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                12-21-2022, 05:22 AM
              • cheeky2
                Help with identifying missing resistor from JVC push buttons TV3024-ZC10-01(C)
                by cheeky2
                Someone previously had damaged a couple of the push buttons who has whilst pushing them in pushed off a smd resistor from a JVC 40" LED TV LT-40C550 main board MSDV3255-ZC01.
                The missing resistor off the push control buttons TV3024-ZC10-01(C) pcb is R06 see the pictures.
                I have tried downloading manuals for the Haier manufactured main board however they don't include the schematic for the push buttons!
                So if anyone has the pcb that could measure the resistance or have a schematic diagram for it would be much appreciated.
                Thanks ...
                01-20-2022, 01:35 PM
              • LearningToRepair
                How to read PCB symbol for 6 pin push-pull switch?
                by LearningToRepair
                Hi!
                I am a bit confused how to read PCB markings for 6 pin push pull switch. I had problem with my 6 pin push-pull switch on my UT58A multimeter. It did not lock properly. So I decided to replace it. I forgot the orientation of original button. And now I need some help with understanding PCB.
                I learned from google how to identify orientation of push-pull button:
                But I am a bit confused which way PCB expects it. I expected that PCB would have some kind on intent marked on it. But mine has 3 marked instead. I attached the photo of it where I marked...
                02-24-2021, 04:18 PM
              • repair-it
                Trying to determine a fault, not sure if the culprit is LM2574 pin 7 output is grounded
                by repair-it
                I'm not sure if this is correct, the output pin 7 is grounded or the ic has a short. I'm just trying to rule it out. https://www.ti.com/product/LM2574?qgpn=lm2574
                07-14-2025, 02:03 PM
              • im_trying
                MSI GF65 Thin doesn't turn on, shorted on dc-in, how to find the culprit?
                by im_trying
                Hi, thanks for helping.
                The motherboard is from a gaming laptop, msi gf65 thin 10ue, 16W21/11S.
                For starters, it doesn't power on. I measured a "short" on the second DC-IN mosfet, right around the charging port but I don't know how to find the component that's shorting it.
                I already tried checking the mosfet for internal shortage (by desoldering and measuring) but no short. The drain on the motherboard is the one that's shorted, next to the gate (that's not shorted).
                The photo below shows this better than words.
                Thanks for anyone...
                05-12-2025, 04:16 AM
