MacBook A1707 820-00928
  • PITERPENY
    • Jul 2023
    • 455
    • Ukraine
    I need help. There is no image on either the internal or external display. The MacBook is charging and the fans are spinning. The touchpad is clicking but the caps lock is not lit. I suspect the U1100 or UA000, tell me what to check?
  • PITERPENY
    • Jul 2023
    • 455
    • Ukraine
    no ideas?
    • mon2
      • Dec 2019
      • 14201
      Check if PPBUS_G3H and 3V42 are stable.
      • PITERPENY
        • Jul 2023
        • 455
        • Ukraine
        3V42 ​?
        PPBUS_G3H =12.63V
        PP3V3_G3H=3.3v
        • mon2
          • Dec 2019
          • 14201
          Have you attempted a DFU?
          • PITERPENY
            • Jul 2023
            • 455
            • Ukraine
            dfu? on 1707?! unfortunately T1 is not compatible with this technology (mon2 is overworked))
            • mon2
              • Dec 2019
              • 14201
              Yup, indeed. Trying to convince my wife of the same. Just wasted 3 days debugging a fleet of Tapo security cameras at the office that just 'died' but only for streaming. The issue...drumroll..a corrupt SanDisk SD card. The so called professional grade SD card is not being detected at all and blocked the hub from streaming. Life sucker. Now TP-Link wishes to see a log from the SD card. Exactly how? The SD card is dead.
              In the end, it is the same ole..check if your bios is corrupted.
              Can you pram reset and hear a chime? Do you see the USB mouse light on if using an external?
              Do you have a touchbar on this unit?
              What is the voltage to ground of ALL_SYS_PWRGD?
              What is the voltage and current draw on the USB C meter?
              • PITERPENY
                • Jul 2023
                • 455
                • Ukraine
                ALL_SYS_PWRGD=3,218V
                USB C meter= 20V/ 1.047A (no battery)
                • mon2
                  • Dec 2019
                  • 14201
                  That is a nice current draw. Try to boot from an external drive and OS.
                  You did not answer if you hear a chime during boot. PRAM reset works?
                  • PITERPENY
                    • Jul 2023
                    • 455
                    • Ukraine
                    no sound,
                    PRAM does not work
                    touchpad clicks but caps lock does not work,
                    SMC bypass and reset do not work,
                    BIOS from another MacBook does not change the situation
                    external disk with OS turns on but the indicator does not blink, it just lights up​
                    • saisoni20
                      • Feb 2022
                      • 111
                      Originally posted by PITERPENY
                      no sound,
                      PRAM does not work
                      PITERPENY Did you fins any solution. I have mac with same problem.
                      • mon2
                        • Dec 2019
                        • 14201
                        The pull-up voltage may be a hint here and appears to be low. This should be @ ~3v3.
                        Also, is the current draw an immediate spike to this value or does it climb up to this measurement? If immediate, there is a short on the board.
                        Remove all power. Meter in resistance mode. Measure the resistance to ground of:
                        PP3V3_S0_LEFT
                        PP3V3_TBT_X_S0
                        ; should be the same measurement as above
                        Confirmed..see attached.
                        • saisoni20
                          • Feb 2022
                          • 111
                          mon2 Do you have power sequence as posted above for A1708?
                          • mon2
                            • Dec 2019
                            • 14201
                            See attached for the A1708 power sequence.
                            • saisoni20
                              • Feb 2022
                              • 111
                              mon2 Thank you so much
                              • leonemax81
                                Macbook a1707 820-00281 Battery no Power
                                by leonemax81
                                Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
                                08-23-2024, 09:24 AM
                              • sofles
                                Macbook a1707 2017 model 820-00928 GPU issue
                                by sofles
                                Hello there
                                I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                                I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                                11-21-2024, 05:25 AM
                              • tommy97
                                Apple MacBook A1707 No Audio/Sound
                                by tommy97
                                I'm having an issue with an A1707 MacBook Pro—there's no audio output. Initially, the MacBook came in with a no-power problem, and I found a faulty U6400, which I've now replaced. The laptop now powers on, but there's still no sound.
                                I've also replaced U6300, but the problem persists.
                                Here are the current voltage readings:
                                • PPV18_S0: 1.8V
                                • R6402: 1V
                                • R6405: 1V
                                • R6403: 1V
                                • AUD_SPKRAMP_RESET_L: 1.3V
                                • PPBUS: 12.6V
                                03-10-2025, 11:22 AM
                              • Cemal Odabasioglu
                                MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                by Cemal Odabasioglu
                                I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                Observations...
                                01-14-2025, 03:54 PM
                              • zaler808
                                Macbook Pro 15" Late 2013 A1398 Turn off randomly but after workload it shows black screen with fans spinning
                                by zaler808
                                Hi guys, this my first post but i want to be brief about it, i recently got a MBP L2013, the problem was that after some use the macbook shutted down randomly, at first i suspected to be the battery, and after connecting it with the charger i noticed that i didn´t shut, but after an hour or so it shutdown, after that i started searching a solution to my problem, but my brother tried to help me to find the problem and it that process to replicate the problem he reproduced a 4k video in multiple tabs and not much time after the macbook shutdown to never power again, what i noticed was that the...
                                05-23-2024, 05:17 PM
