HP Pavilion No Video on Display
  • blu
    • Sep 2013
    • 11
    • US
    Hp Pavillion dv6-3225DX
    Backstory:
    The original screen was stepped on and the laptop still powered and showed images on the display just the portion that had the most pressure applied to it was distorted.
    The orginal panel was an led samsung which I replaced with a LG of similar specs.
    After replacing the display the laptop powers on but there is no video.
    I was careful in removing the flex cable from the old panel to the new one.
    tried reseating cmos/booting with one memory/ with/without hdd.
    I was thinking it might be flex cable for the display
    What should I be testing first before I order a replacement?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3610
    • slovakia
    Re: HP Pavilion No Video on Display
    connect to external monitor to see if chip is ok
    • trebo
      • 514
      • Wales, UK
      did you remove battery when you fitted new screen???
      • lefos
        • Nov 2013
        • 321
        • Greece
        Can you see in the panel if there is picture? There might be dark picture (no backlight) if so then you have to check if there is any fuse for the backlight on the mainboard.
        • blu
          • Sep 2013
          • 11
          • US
          So I tried connecting to external monitor no video as well
          • blu
            • Sep 2013
            • 11
            • US
            No I left the battery in when replacing the screen
            • trebo
              • 514
              • Wales, UK
              as lefos suggested, check for tiny fuse on motherboard around the screen connector
              on the led screens, you need to remove battery when replacing a screen
                Connected the old panel back in and see if you can get back to the original problem.
                "The orginal panel was an led samsung which I replaced with a LG of similar specs." They have the same pin out?
                • blu
                  • Sep 2013
                  • 11
                  • US
                  I did shine a flashlight and there was no picture. The only thing that looks remotely like a fuse that I can see might be on the dc jack pictures attached
                  • blu
                    • Sep 2013
                    • 11
                    • US
                    Yes they are both 40 pin
                    ill try the old panel again
                      The number of pin and the connector can be the same, but the pin assignment may not be the same, and if the ground pin and power supply voltage pins are not at the same location, then you really cause damage to the main board/ or the panel. The only way to verify is to get the spec sheet of the panels.
                      • blu
                        • Sep 2013
                        • 11
                        • US
                        update the old panel does not display any video either
                          Do you have panel model numbers for the both of them?
                          • blu
                            • Sep 2013
                            • 11
                            • US
                            Finally got attachments working again.
                            models #s in pictures
                            I also have another laptop thats having display issues should i post it here or on a separate thread?
                            • joshbose
                              • Jun 2014
                              • 3
                              • uae
                              I have asony vaio vpcea36fa lap (mother board mbx-224) not power on
                              any remedies pls help
                              • dj_ricoh
                                • 2073
                                my teachers in electronics did this and he ended up changing the motherboard
                                be prepare.
                                until you search we need a schematic so we can pinpoint what to check.
                                post the mobo code so we can find it.
                                • trebo
                                  • 514
                                  • Wales, UK
                                  post a picture of the screen connector on m/board and the surrounding components
                                  • blu
                                    • Sep 2013
                                    • 11
                                    • US
                                    I cannot upload any more attachments I continue to get http 500 errors so I am linking the Pictures from Dropbox
                                    • trebo
                                      • 514
                                      • Wales, UK
                                      the pics are not loading up for me/ is it just me???
                                      • dj_ricoh
                                        • 2073
                                        yeee! its you.
                                        if you wanna upload big pictures you need to do it one by one!
                                        if you got cellphone or table photos you can do more the one.
                                        From my nikon i have to do it one by one
                                        Maybe this helps.
                                        Cheers.
