MacBook Pro A1990 EMC 3359 820-01814-01 no power
  • bpcmr
    • Dec 2024
    • 4
    When plugged in it stays at 5v
    I don’t know what caused the issue but on removing the mobo I saw some corrosion (pictured). This picture was taken after I tried to clean it but it’s still hazy looking.
    I checked for shorts in the nearby area
    C3501 pin1: 58Kohm
    CC749, CC797, and CC796 pin one read about .8ohm
    pin 2 on F7000 and F7001 read about 2.2ohm
    still very much a newbie so any advice on common faults I should check for would be helpful, thanks
  • mon2
    • Dec 2019
    • 14518
ID:	3526670 Use ipa (alcohol) - Costco pharmacy grade is excellent to clean up this area.
    • reformatt
      • Feb 2020
      • 1444
      Dead A1990/A2141 I immediately check for simultaneous shorts on PPBUS_G3H and either of the PP2V5 NAND power rails. TPS61280 failure is pretty common (U9080/U9580). This TI IC has killed many a Macbook over the years by pumping 12V straight into their SSD's. In true Apple fashion, they repeat the same Engineering mistakes over and over again, and they are still using this IC on the latest M4 Mac Mini removable SSD's. Built in obsolescence at it's finest.
      With any luck, you just have a PPBUS short, and it's a decoupling cap on one of the chicken wings. Most common on A1990 is C9081.
      I did have one recently where C9081 was corroded and shorted but it had created a high resistance connection on the pad to PPBUS_G3H_SSD0_SNS. As a result, the few extra ohms of this bad connection were not enough to shut down the main power rail and it sat there burning away until carbonised the PCB underneath and shorted PPBUS_G3H directly in the PCB itself. Had to write that one off as all the SSD rails were shorted to ground in the PCB just because of this stupid cap.
      • bpcmr
        • Dec 2024
        • 4
        So I’ve checked components leading into and out of U9080
        C9081 pin one showing 2.2 ohms and C9091 pin 1 is 4ohm
        pp2v5_nand_ssd1 seems empty. Mostly just pads
        PP2v5_nand_ssd0 I’ve checked a lot of components on this line and which have this as an output and nothing has shown under 0.3ohm
        I’ve also checked components that have ppbus_g3h as an output and no shorts, closest I found was C6470 pin one reading about .8ohm.
        should I be more thorough in checking PPBUS_G3H or is there another rail I should be looking
        i did clean the area mon2 pointed out.
        I will try putting it back in and seeing if cleaning the corrosion fixed anything
        • reformatt
          • Feb 2020
          • 1444
          4 ohms on C9091 isn't good, that's your SSD 2.5V power rail. Usually if it's one of the decoupling caps (C9089 etc), it will read dead short. Non zero is often a NAND that's failed due to the overvoltage from the failed TPS61280 (can be one or more, or all of them). Remove U9080 and see if your PPBUS_G3H short is removed. Alternatively, use 1V voltage injection and thermal camera if you have one to pinpoint the issue.
          BTW, the NAND's are combined in a RAID 0 stripe by the T2, so data definitely gone when this happens.
          • alfredodinolfo
            MacBook Pro 2019 (A1990)
            by alfredodinolfo
            mb code:820-01827-A;
            sn:C02Z349ALVDR;
            i9 32GB Ram 1TB
            Hi, I found short on one of 6 black nand (total 1TB).
            i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
            I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
            macbook with A2141 configuration run on recovery but don't complete it.​
            anyone can help me?
            05-26-2025, 09:27 AM
          • robka
            MacBook Pro 2018 - A1990 Dead - not charging - only 5V
            by robka
            my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
            I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
            The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
            After that the Macbook was dead. It isn't charging anymore.
            The USB-C Port where the charger was plugged is burned. Also The Cable and the...
            03-02-2024, 02:58 PM
          • DATATECH85
            Macbook Pro A1990 - 820-01041 Stuck at 5V / 0.02A
            by DATATECH85
            I am currently working on a Macbook Pro A1990 (motherboard 820-01041) which is not charging.
            The Macbook consumes 5V and 0.019A at USB-C. There seems to be a partial short-circuit on the PPBUS_G3H rail as I have 0V on this rail.
            I've physically separated (by removing F7000 and F7001) PPBUS_G3H and the ISL9240 charging chip to see which side the short is coming from. Removing these fuses gives me 12.6V at the output of the ISL chip (PPVBAT_G3H_CHGR_REG).
            However, I can't work out exactly why I don't have the PPBUS_G3H rail.
            Here are the values...
            07-24-2024, 06:34 AM
          • Cameron Kajohn
            A1990 MacBook no power help
            by Cameron Kajohn
            I have a a1990 2018 15 inch MacBook Pro that will not power on.
            I have replaced the pch bga chip because it was heating up under my thermal camera.
            I have replaced the battery, and replaced the small ic between the gpu and cpu as it had a direct short to ground.
            the MacBook now pulls 20v 2.4amps the trackpad clicks but it does not ever attempt to power on not even fan spin. After PCH replacement I was able to get it in dfu mode 1 time and restore bridge OS, but now the MacBook will no longer go into DFU mode.
            I have also noticed L7030 gets extremely hot yet...
            01-24-2024, 12:00 AM
          • Strolch
            MacBook A1990 26 Pin Connector
            by Strolch
            Hello, can anyone tell me where I can get this 26-pin FPC connector? What is the connector for?So that one's also for the Touch Bar. I thought only the FPC at the top was for the Touch Bar. But where can I get it? I can't find the connector online. I only found the 22nd pin. Thank you....
            09-03-2025, 01:11 AM
