[820-00281] dead!!!! 5v@0,48
  • mon2
    • 14659
    What is the voltage to ground of PPBUS_G3H? Is it stable?
    Measure @ fuse F7000 (both sides).
    What is the voltage to ground of ALL_SYS_PWRGD?
    Voltage of the following?
    SMBUS_SMC_5_G3_SCL ; battery connector
    SMBUS_SMC_5_G3_SDA ; battery connector​
    • phantomEVO
      • Mar 2013
      • 509
      PPBUS_G3H 12,6 stable
      f7000 12,6 both sides
      ALL_SYS_PWRGD 0v
      SMBUS_SMC_5_G3_SCL ; 3,4
      SMBUS_SMC_5_G3_SDA 3,4​
      • mon2
        • 14659
        ALL_SYS_PWRGD 0v
        Means that at least one of the power rails is missing. This is a power good status signal which will be 0v if there is a defective power rail that is being monitored by this circuit.
        Measure the voltage to ground on each inductor on the board while powered on. Report any suspects. If you find an inductor with a wrong voltage (off or too low) -> then remove all power. Measure the resistance to ground. Most likely there is a shorted part on that rail - hoping it will be a capacitor.
        • phantomEVO
          • Mar 2013
          • 509
          Where can i find "a list" of the power rails? because i've checked for short on each coil without luck....
          a lot of coil have no voltage but i don't know if it is normal...
          • mon2
            • 14659
            Let us do this in reverse. Remove all power. Meter in resistance mode. Measure the resistance to ground of each and every inductor. Checking for a lower than normal measurement of the inductor. If found, check the schematic for the rail voltage. If the voltage is a low voltage rail then it is normal to have a low resistance. List any suspects.
            • phantomEVO
              • Mar 2013
              • 509
              ok l7900 is shorted, i've lifted one side, and PP1V2_S3_REG_R is full shorted
              • mon2
                • 14659
                Ok. These are dangerous regions and linked to the CPU. Using an adjustable power supply, dial up 1 volt (not higher) and inject onto this rail and point where you are measuring the full short. Which part is heating up? Hoping it is a bulk cap. Keep the voltage low and the current on your power supply as high as possible. Hunting for the part that is shorted.
                • phantomEVO
                  • Mar 2013
                  • 509
                  ok found c423 shorted! removed and mac is alive, now i check with battery!
                  • mon2
                    • 14659
                    Crossing my fingers and other parts of the body in anticipation.
                    Do not forget to place back the resistor "we" removed.
                    • phantomEVO
                      • Mar 2013
                      • 509
                      you are the best!!!!!! THE BEST OF THE BEST! IT WORKSSSSSS FLAWLESSLYYYYYY EVEN WITH THE BATTERYYYY!! THANK YOU!!!
                      • mon2
                        • 14659
                        Good job!! Hope this thread can help future readers as well.
                        • double_DD
                          How can I be sure that my EC chip is dead?
                          by double_DD
                          As the title suggests, how can I be sure that my EC chip is really dead?
                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                          03-12-2025, 07:47 AM
                        • disorder
                          ps5 edm-033 dead after hdmi/usb ports destroyed
                          by disorder
                          hello guys,
                          i need help to repair a edm-033 ps2
                          history : as always hdmi port and usb ports destroyed after unplugged
                          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                          so i changed it
                          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                          i don't see any projection of liquid metal on pcb.
                          01-14-2025, 12:48 PM
                        • zunasthegreat
                          Chieftec GPS-450-AA with dead 20N60C3
                          by zunasthegreat
                          Hello everyone hope all doing well!
                          I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                          09-01-2024, 07:12 PM
                        • Beton
                          Finding a dead short component
                          by Beton
                          Hi guys!
                          I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                          So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                          I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                          I have a bench PSU and if I try to inject voltage the voltage...
                          12-10-2021, 01:05 PM
                        • FiguringITout
                          MSI Raider GE75 - Not posting, probable dead CPU
                          by FiguringITout
                          Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                          Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                          07-25-2024, 07:27 AM
