[820-00281] dead!!!! 5v@0,48
  • phantomEVO
    • Mar 2013
    • 507
    hi to all motherboard is perfect. no shorts around usb-controllers
    i've 0V on PP1V1_UPC for each controller. (with cable connected) no shorts on those lines
    reProgrammed u2890, still the same
    3V3_G3H 0v
    on R7020 5v on all 4 pins
    TBA_AUX_DET 1.2v
    TBA_VDDA 4,8v
    TBA_VDDP 4.8v
    SMC_RESET_L 0v
    BUF_SMC_RESET_L. 0v
    on d6902 i've PPBUS_G3H 4,8v, on PPVIN_G3H_P3V3G3H i've 1v​
  • phantomEVO
    • Mar 2013
    • 507
    i've resoldered a new u3200 and now i have 1,1 on u3200 but not on u3100. still 5v @0,46
    i've recheck all lines of u3200
    following this guide
    https://logi.wiki/index.php/CD3215_Bootup_Sequence
    and all are ok until PM_EN_P3V3_G3H where i found 1,9v
    i've also PPVIN_G3H_P3V3G3H with 1v​
    • mon2
      • 14657
      Flux & replace D6902.
      • phantomEVO
        • Mar 2013
        • 507
        hi mon! thank you for the reply! why you think to replace the diode? could i try to remove the diode and make a jumper just for test?
        • mon2
          • 14657
          Remove all power. Meter in resistance mode. Measure the resistance to ground of PPVIN_G3H_P3V3G3H = pin # 3 of D6902. If the resistance is low, there is a short on this rail and it could be from the capacitors C6905 and/or C6906.
          This dual diode is required to pass through the higher of the 2 input voltages being fed onto pins #1 and # 2, respectively. Whomever is higher, that voltage should appear on pin # 3 (less the Vf = forward voltage drop of ~0v6).
          At this time, your voltage on pin # 3 is ~1v. This is because
          a) you have a shorted part in this power path OR
          b) this dual diode is defective
          From our experience, have seen more defective dual diodes but you can test each case. Only after the Vin to U6903 is high enough, then you will have a stable 3v3 @ R6923. This is a critical power rail to the entire logic board.
          You can also validate if the dual diode is defective or not by using the DIODE mode of your meter.
          Red meter probe onto pin #1; black meter probe onto pin # 3 - the meter should conduct and offer a voltage reading.
          Repeat with red meter probe on pin #2; black still on pin # 3.
          Now reverse the meter probes and the diode should block = 'OL' on the meter. Post all measurements.
          • phantomEVO
            • Mar 2013
            • 507
            thank you for all your reply...a lot of things happen...i don't remember all the things i've done...i'm sure i've changed the diode and u7000.
            now it works! and boot without problem. but only without the battery. with the battery it goes to 20 but it stuck at 0,036 amp and nothing happen..
            • phantomEVO
              • Mar 2013
              • 507
              i don't know what to think....i've disconnected and reconnected all together and it has booted with battery and has charged the battery to the max (it was at 1% with service alert). as soon as i have disconnected the cable, it has powered off. now it doesn't boot anymore with battery. i've tried with another battery, same thing
              with power supply and battery connected i have
              PPBUS_G3H is 11.81v
              3V3_G3H is 3,41​
              • mon2
                • 14657
                So much going on and many missed details of information. What are the details of the dual diode?
                Disconnect the battery. Is the laptop stable with only the official power adapter?
                • phantomEVO
                  • Mar 2013
                  • 507
                  you are right! i've mounted the same diode. taken from a donor board (a1466)
                  the macbook boot always from each port with power supply only. and it is super stable. if i connect the battery, it stays at 20v@0.46 amp...
                  • mon2
                    • 14657
                    Measure the resistance of the battery charge circuit @ C7020. Measure across this capacitor. What is the resistance in ohms? We are checking if there is a break or defect in the current sense loop.
                    The full path resistance should be ~2 ohms. Confirm this details.
                    Moving forward...
                    Q7065 may be defective. Test using the resistance checks across this mosfet.
                    source / drain
                    source / gate
                    gate / drain
                    If there is a low resistance; this mosfet may be defective.
                    next..
                    Connect the battery and adapter.
                    Measure the voltage to ground of the following points of interest:
                    R6920 - both sides
                    R6907 - both sides
                    PPVIN_G3H_P3V3G3H ; pin # 3 on D6902
                    SMBUS_SMC_5_G3_SCL ; battery connector
                    SMBUS_SMC_5_G3_SDA ; battery connector
                    • phantomEVO
                      • Mar 2013
                      • 507
                      c7020 3ohm
                      c7023 2,5ohm​
                      • phantomEVO
                        • Mar 2013
                        • 507
                        source / drain 35k
                        source / gate 46k
                        gate / drain 82k​
                        • mon2
                          • 14657
                          Flux and remove Q7065 off the board. Allow it to cool down. Then measure this mosfet again while it remains on your work bench. This mosfet is measuring too low to be ok. Each measurement should be hundreds of k ohms or higher if normal.
                          • phantomEVO
                            • Mar 2013
                            • 507
                            ok, i've reconnected battery and power supply and it booted again. as soon as i removed the cable, it power off. reconnected thecable-> 0,043 -.-'
                            in this situation i have:
                            R6920 PPDCIN_G3H_CHGR_R 8,1v / PPDCIN_G3H_CHGR 3,4v
                            r6907 PPBUS_G3H 12,4/ PPBUS_G3H_R fluctating between 5 and 7,5
                            pin 3 of diode fluctuating from 4 to 7...removing the power supply, pin 3 is stable at 7v
                            about the mosfet: i've measured the same identical mosfet on a donor board and it has the same identical values....i've used the multimeter in resistence mode....
                            • mon2
                              • 14657
                              Remove all power. Measure the resistance of R6907 which appears to be defective. Should be ~2 ohms.
                              • phantomEVO
                                • Mar 2013
                                • 507
                                it measure 26ohm
                                • mon2
                                  • 14657
                                  26 ohms? Too high. Replace this part and test again.
                                  • phantomEVO
                                    • Mar 2013
                                    • 507
                                    it0s a nightmare: changed the resistence, now it doesnt boot anymore even with power supply only..
                                    this video is with power supply only
                                    https://www.dropbox.com/scl/fi/5spoe...=z83f4i0s&dl=0
                                    with power supply only i have 12,6v on both sides of the new resistance and PPVIN_G3H_P3V3G3H 20v on pin 3 of the diode
                                    • mon2
                                      • 14657
                                      These are good measurements.
                                      Do you have a stable voltage for PP3V3_G3H @ R6923 (check both sides of this resistor)?
                                      Suggest to remove the new resistor you have soldered @ R6907. Power up again with the power adapter. Does the logic board power up ok?
                                      • phantomEVO
                                        • Mar 2013
                                        • 507
                                        3,42 stable both sides.
                                        it doesn't boot even without the resistor
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • disorder
                                          ps5 edm-033 dead after hdmi/usb ports destroyed
                                          by disorder
                                          hello guys,
                                          i need help to repair a edm-033 ps2
                                          history : as always hdmi port and usb ports destroyed after unplugged
                                          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                          so i changed it
                                          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                          i don't see any projection of liquid metal on pcb.
                                          01-14-2025, 12:48 PM
                                        • zunasthegreat
                                          Chieftec GPS-450-AA with dead 20N60C3
                                          by zunasthegreat
                                          Hello everyone hope all doing well!
                                          I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                          09-01-2024, 07:12 PM
                                        • Beton
                                          Finding a dead short component
                                          by Beton
                                          Hi guys!
                                          I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                          So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                          I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                          I have a bench PSU and if I try to inject voltage the voltage...
                                          12-10-2021, 01:05 PM
                                        • FiguringITout
                                          MSI Raider GE75 - Not posting, probable dead CPU
                                          by FiguringITout
                                          Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                          Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                          07-25-2024, 07:27 AM
