Satellite L505D MB 6050A2302901-MB-A02
  • mazloum
    • Sep 2012
    • 499
    • Lebanon
    dead with no leds when inserting power. voltage of battery connectors charger is only one pin with 4.2 v
    no voltage on bios
    no voltage on power switch
    thnaks
  • dj_ricoh
    • 2073
    Re: Satellite L505D MB 6050A2302901-MB-A02
    first you need the schematic.
    • mazloum
      • Sep 2012
      • 499
      • Lebanon
      i already have the schematic, but how to determine if BQ24721C is bad??
      • dj_ricoh
        • 2073
        attach it here!
        do you think that we have some JEDI MIND tricks that we can see that schematic and know whats wrong?
        May the force be with YOU
        • mazloum
          • Sep 2012
          • 499
          • Lebanon
          here is the schematic
          • dj_ricoh
            • 2073
            post the values of the BQ24721C then we can see whats going on
            • mazloum
              • Sep 2012
              • 499
              • Lebanon
              already changed it with same problem
              • dj_ricoh
                • 2073
                then why you ask us if its bad and you already change it.
                again.
                what values you got on that BQ
                • loser18
                  • Nov 2013
                  • 274
                  If you don't have any voltages on BIOS, first check 3.3V & 5V regulator (U6100)...
                  In order to help you need to post voltages of all pins...
                  • mazloum
                    • Sep 2012
                    • 499
                    • Lebanon
                    sorry for the delay but the customer insist to take it as it is, thanks very much
                    • rddube
                      Lenovo L490 Ram voltage circuit malfunction
                      by rddube
                      Hello friends,
                      Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                      I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                      07-15-2025, 04:41 PM
                    • Fernon@Repair
                      Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                      by Fernon@Repair
                      i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                      VCCIO voltage ok
                      VCCSA Voltage OK
                      VCCPLL Voltage OK
                      Ram Voltage ok
                      RamVTT OK
                      VPP 2.5 OK
                      But No Core Voltage
                      and i want to this vrm ic datasheet or pinout (ISL69269)
                      anyone have this ic pinout voltages?...
                      06-25-2025, 07:19 AM
                    • electron_jj
                      Panasonic TH-L42D25A checking the PSU output voltage
                      by electron_jj
                      Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                      I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                      08-29-2021, 08:13 AM
                      Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                      by sam_sam_sam
                      I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                      The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                      Now...
                      06-09-2024, 10:57 AM
                      ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                      3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                      Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                      core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                      configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                      serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                      Based on Intersil's Robust Ripple Regulator...
                      11-05-2024, 03:24 PM
