Thinkpad T490s No battery recognize
  • Spider28
    • Aug 2023
    I just bought a new T490s battery. The Lenovo Diagnostic said no battery. Open check the battery socket from motherboard it shows no voltage should be 11-12V. The usb-c power adapter had 20v and the laptop came up with ac adapter plug in. What should I check next?
  • mon2
    • 14317
    1) confirm the battery is properly seated in the connector.
    2) the battery may be a dud
    3) confirm you have the latest device driver for the battery support:
    • Lenovo Power Management Driver for Windows 11 (Version 21H2 or later) 10 (Version 1607 or later) - ThinkPad
    ​4) what is the history of this laptop? Did the last battery work ok? Do you still have it for testing? Check if it is detected.
    • Spider28
      • Aug 2023
      I did update all latest drivers. 2 batteries purchased are brand new. I measured the voltage on the battery socket pin 1 for ground pin 6 for vcc show no voltage so the battery Mosfet may be dead.
      • mon2
        • 14317
        Does either battery show a voltage when it is on your work table?
        measure the voltage to ground of each pin on the battery connector while it is attached to the logic board.
        Locate the mosfets nearby this battery connector. Meter in resistance mode. Check each mosfet by reviewing the resistance. No power/no battery in resistance mode checks.
        check:
        source (1-2-3) & drain (5-6-7-8)
        source (1-2-3) & gate (4)
        gate (4) & drain (5-6-7-8)
        post each measurement. A low resistance = leaky mosfet.
        • Spider28
          • Aug 2023
          Source 123&5678 0.81volt
          Source 123&4 3.35volt
          Source 4&56 0.16volt
          Source 4&78 3.09volt
          MOSFET 1 measure 0.81volt
          MOSFET 2 measure 9.21volt
          Time for me to replace leaked MOSFET.
          • mon2
            • 14317
            No. Interested in the resistance measurements (ohms) not voltage measurements. Select a high K ohms scale and measure as noted above. Post a pic of your meter face for a confirmation of the settings.
            • rumpumpel1
              ThinkPad T490s only starts with battery
              by rumpumpel1
              I am testing a ThinkPad T490s with this setup: only the bare mainboard NM-B891 with a fan and the small Power-On daughterboard as well as with a USB-C monitor (no BIOS battery!).
              If I connect a battery, the mainboard starts up normally. After about 50 seconds the logo appears and after another 30 seconds the final message “... System configuration is invalid. Press Esc to continue or F1 to enter setup”.
              If I connect the power supply unit instead of the battery, a USB meter shows the usual fluctuating power consumption for approx. 30 seconds, then the mainboard switches off...
              12-02-2024, 01:42 PM
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • bykanovm
              Thinkpad W541 Works from the mains and charges the battery only when it is turned off
              by bykanovm
              Lenovo Thinkpad W541 Wistron LKM-1 WS MB 12291-2 Works from the network and charges the battery only when it is turned off.
              If you press the power button, the laptop turns on and works from the battery, but does not take power from the power supply.
              If you boot into Windows and close the lid while working, thereby putting the laptop into sleep mode, the laptop begins to charge the battery.
              even checked it this way: I bring a neodymium magnet to the Hall sensor during operation - the screen goes out and the battery starts charging.
              Also, the laptop does not turn on without...
              04-02-2025, 02:45 AM
            • Grafnus
              Lenovo ThinkPad P15 Gen2 Battery Mosfet Replacement
              by Grafnus
              Hey there,
              first time posting here. I have been lurking a bit trying to find a solution but with little to no avail.
              So I have a Lenovo ThinkPad P15 Gen2. When I got it (for free) it was turning on but not charging because the battery was unplugged. When I plug the battery in, the Laptop won't boot at all.
              Specs:
              • Type: Lenovo ThinkPad P15 Gen2 20YQ-001KGE
              • CPU, GPU, RAM work fine (not involved in the Problem)
              So the first thought was to toss the battery and get a new one, as clearly the BMS is throwing errors or something.
              Now I noticed...
              08-06-2025, 11:54 AM
            • mkdj
              by mkdj
              Mark and model: ASUS X571
              Tests already made:
              - I have removed...
              07-14-2025, 09:16 AM
