Black Epoxy on bios chip
  • javieromex
    • Apr 2016
    • 83
    • México
    Hi friends, I have a Lenovo E14 Gen 2 Type 20TA laptop with serial number MJ-0GWZSZ TYPE 20TA-002CUS. Intel Core ™ i5-1135G7. It has Winbond 25R256JVEQ BIOS which has black epoxy resin. I have 2 questions. What method do you use to remove the epoxy? and the second, what chip do you use to program it if you have the TL866 II Plus programmer? Thanks in advance.
  • mon2
    • Dec 2019
    • 14659
    I believe you may be referencing the wrong flash onboard. Hunt around for another similar flash device. This pic is of a Winbond W25R256 which is a secure flash device with a replay protection counter feature. Do not believe that you will be able to properly program this device. Wait on others to comment but there should be another standard flash bios onboard.
    For the epoxy, low heat (100-150C) should allow this compound to become brittle and flake off with tweezers.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      This is the worst part of Lenovo. They put this black glue on almost every chip nowadays.Earlier it was only under BGA chips but now even core ic has it.
      This epoxy wont melt at temps suggested by mon2. You can use a glue cutter knife very carefully to remove the glue to some extent and then flux and hot air gun to lift it.
      Be careful not to cut the trace on PCB.
      I managed to remove a thinkengine chip in this way without damaging the PCB pads.
      • rumpumpel1
        • Jul 2019
        • 162
        • germany
        according to the schematics the W25R256JV is the only SPI flash on the board.
        This black glue is called underfill. If you search for "underfill tools" you will get some tools that might help a little bit.
        • rumpumpel1
          • Jul 2019
          • 162
          • germany
          did you mean "what clip do you use"?
          It is advisable to remove the solder balls from the BIOS chip beforehand, otherwise you will bend the pins on the clip.
          • DynaxSC
            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
            by DynaxSC
            Hi
            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
            08-04-2025, 12:20 PM
            by SMDFlea
            Bad...
            09-02-2021, 04:40 PM
          • JoWed
            Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
            by JoWed
            Hello Community,
            I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
            07-01-2025, 09:32 AM
          • BMCappelletti
            Asus Chromebox CN62 - wrong chip put on BIOS reader
            by BMCappelletti
            Long story short:
            - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
            - gave the computer to his son a couple years later
            - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
            - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
            (seems like the story was not that short)
            He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
            01-08-2025, 07:27 PM
          • capoplays
            Help with BIOS update on Dell G15 5515 after chip replacement
            by capoplays
            Hey everyone,
            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
            When I check the BIOS using the F12 menu Flash...
            10-24-2025, 06:53 AM
