Dell Motherboard LA-K491P no power
  • mferna14
    • Jun 2018
    • 1046
    Dear Friends, I am working on Dell Latitude 5420​ Motherboard LA-K491P Rev: 2.0(A01) ., Absolutely no power at all. I tried to find the schematics but I think it's not available. Upon observation I saw one chip ISL95860 burnt near the CPU, replaced it but still nothing. The Amp meter is totally blacked out, no display at all. When I connect the battery, at least on one of the battery terminal data lines pins there is 3.3v present. This board is using JHL8040R for each USB-C ports. Can anyone help where to start & if anyome can share the schematics, I would appreciate. Thanks in advance
    • 22109
    Read the posts in the LA-K491P schematic request thread https://www.badcaps.net/forum/troubl...ed#post3507736 , the LA-K371P is similar
    • mferna14
      • Jun 2018
      • 1046
      @SMDFlea​, thanks, I have it with me, the layout & component are mostly different, I have no idea why they say that it's similar. Totally 2 different motherboards & this MB has only 1 USB-C port
        SMDFlea commented
        Editing a comment
        Sorry i didn`t check the boards, i just took the comment at face value
    • pc_okay
      • May 2022
      • 244
      • FRANCE
      You Connect a usb-c amp metter and you have no display at all?
      Did the usb-c charger LED stop Lightning too when you plug charger in?
      • mon2
        • Dec 2019
        • 14721
        My schematic for the LA--k491P has the TPS65994 onboard.
        • mferna14
          • Jun 2018
          • 1046
          You Connect a usb-c amp metter and you have no display at all? Like I said before... No Display on the amp meter, TOTALLY Blacked OUT.....
          Did the usb-c charger LED stop Lightning too when you plug charger in? No power at all, this is why no LED activity at all. DEAD
          If any repair tips given to me, I would appreciate.
          • mferna14
            • Jun 2018
            • 1046
            Yes mon2 you are right, TPS65994 is the PD controller on this motherboard. I got the boardview for this model but stil no Schematic, do you have the schematics to share with us.,trouble shooting will be easier. I have already shared the boardview in the schematics for LA-K491P thread.
            • mon2
              • Dec 2019
              • 14721
              Yes I do but in a locked PDF. Let me PM you.
              • pc_okay
                • May 2022
                • 244
                • FRANCE
                You have boardview here, you don't need shematic for now:
                https://www.badcaps.net/forum/troubl...-0-3-boardview
                If amp metter stop working and your charger LED light off, you may have a big short somewhere, that's why I ask you these questions...
                Don't forget to check if your USB-C connector are good too.
                Then with the boardview you can check resistance to ground (without power) on your USB-C lines: CC1, CC2, VBUS .... then post values jere or make some conclusion.
                • mferna14
                  • Jun 2018
                  • 1046
                  @pc_okay​., I checked all the USB-C ports & they look like new, no pins damage. I checked all the caps around TPS65994 & they are good. No Short. There is voltage of 3.3 to power on this chip. I am assuming that this chip is defective. I will replace & then inform you'll, thanks dear.
                  • thinkcentre
                    Dell Optiplex 3060 Micro USFF (IPCFL-CG Motherboard) - No LED / Short Circuit
                    by thinkcentre
                    this is my first post at Badcaps and in general i am new to fixing electronics. I am looking forward to learn a bit more about diagnosing and repairing :-)
                    What I have around is a DELL OPTIPLEX 3060 Micro (USFF), which is not powering on, even not showing any signs of life (No amber / white LED).
                    I got a original 65W DELL PSU / Power brick (PA-12 / 074VT4) which hopefull should be the correct one. I could get another DELL PSU with the Partnumber 0G6J41 with the same 4.9mm DC Jack connector as the one I already have, but I dont think that would help (maybe...
                    11-09-2025, 12:39 PM
                  • Geeker007
                    9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                    by Geeker007
                    Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                    I am new to electronics repair, so my queries could be naive but I am ready to learn.
                    So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                    01-28-2025, 03:31 PM
                  • Julian Bailey
                    Dell Latitude 5350 Ultra 7 Motherboard
                    by Julian Bailey
                    Hi
                    I have a Dell Latitude 5350 Ultra 7 Motherboard I am trying to repair that has a blown chip.
                    The chip is marked as eHOLH similar to the one I have pictured.
                    Any ideas what it does and what the pin outs are as 3 tracks have gone and need to find out what / where they went / did etc.
                    Dell PN of the motherboard is 08DCGW.
                    Below is the area I am trying to repair:
                    Does anyone have a picture of this motherboard in this area they could take and upload?
                    Cheers...
                    07-03-2025, 11:25 PM
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                  • sourceaxe
                    Dell Precision 3650 Tower (Desktop motherboard) - Schematic (and board view) request
                    by sourceaxe
                    Does anyone happen to have the schematic (and if available also: the board view) for the Dell Precision 3650 Tower motherboard please?
                    Manufacturer: Dell
                    Model: Precision 3650 Tower
                    Motherboard markings:
                    • IPRKL-RDT REV: A00
                    • D33D66
                    • CN-0NDYHG-PE100-1AM-05SY-A01
                    • P&Q 2134 CM-4 94V-0 E162264
                    Thank you in advance.
                    11-21-2024, 05:35 PM
