dell n5110 no charger detect
  • abbas_govani
    • Jul 2013
    • 89
    • India
    Re: dell n5110 no charger detect
    shall i update the bios ?????
    • loser18
      • Nov 2013
      • 274
      Originally posted by abbas_govani
      hi sir
      there is no Confusing
      laptop is not charging the battery that is the problem
      What confused me was that 2.8V from DC jack...
      I thought it's shorted, either the board,jack or something in charger circuit...
      Also thought that you tested laptop with battery & charger connected at the same time...
      Anyway...
      Could you check resistance @ PL4001 & post all voltages of PU4001?
      • abbas_govani
        • Jul 2013
        • 89
        • India
        what should be the current on pq4001 pin 4 and 5 no current
        • loser18
          • Nov 2013
          • 274
          I'm not 100% sure, but in this design the pq4001 is a kind of charging switch...
          It will push voltage to PU4002 gate if there's something wrong(or if it's not getting PWR_CHG_ACOK)...
          PU4002 is P channel, so it will switch off when gate voltage is similar to S & G voltage...Maybe I'm talking shit, but it does make sense, therefore these 2 should be OK...
          • loser18
            • Nov 2013
            • 274
            I would move the attention to PU4001...
            There are many of pwrchrg voltages in this regulator...
            Ok...
            Digged a little bit in datasheet...
            This regulator is also Enabling & Disabling charging...
            First you need to check:
            -PIN7
            -PIN2
            -COMPARE PIN 22 & PIN 15
            -PIN21
            -PIN3
            • abbas_govani
              • Jul 2013
              • 89
              • India
              #26
              610 ohm @ pl4001 and pu4001
              1 19v
              2 2.6
              3 2.6
              4 5.8
              5 6
              6 0
              7 0
              8 2.5
              9 2.5
              10 0
              11 1.1
              12 3.3
              13 3.3
              14 0
              15 2.5
              16 0
              17 0
              18 0
              19 19
              20 19
              • abbas_govani
                • Jul 2013
                • 89
                • India
                #27
                Ok...
                -PIN7
                -PIN2
                -PIN21
                -PIN3
                sir pu4001 is 20 pin ic
                • abbas_govani
                  • Jul 2013
                  • 89
                  • India
                  #28
                  pu4001
                  • loser18
                    • Nov 2013
                    • 274
                    Are you sure you've checked the right IC???
                    According to schematics it should be BQ24745...
                    • loser18
                      • Nov 2013
                      • 274
                      Think the schematic is not right...
                      What's the mobo part number?
                      • abbas_govani
                        • Jul 2013
                        • 89
                        • India
                        #31
                        10245-2
                        48.4ie01.021
                        dq15 intel mb
                        • loser18
                          • Nov 2013
                          • 274
                          And what's the PU4001 number?
                          • abbas_govani
                            • Jul 2013
                            • 89
                            • India
                            #33
                            • abbas_govani
                              • Jul 2013
                              • 89
                              • India
                              #34
                              cant read properly its like bq....
                              • loser18
                                • Nov 2013
                                • 274
                                I've found 48.4ie01.021 schematics, but's an AMD...
                                • abbas_govani
                                  • Jul 2013
                                  • 89
                                  • India
                                  #36
                                  cant read properly its like bq074ti..
                                  • abbas_govani
                                    • Jul 2013
                                    • 89
                                    • India
                                    #37
                                    sorry it is bq07a
                                    • abbas_govani
                                      • Jul 2013
                                      • 89
                                      • India
                                      #38
                                      bq07a pin current
                                      1 19v
                                      2 19
                                      3 0
                                      4 0
                                      5 0
                                      6 2.5
                                      7 0
                                      8 3.3
                                      9 3.3
                                      10 1.1
                                      11 0
                                      12 2.5
                                      13 2.5
                                      14 0
                                      15 0
                                      16 6
                                      17 5.8
                                      18 2.6
                                      19 2.6
                                      20 19
                                      • loser18
                                        • Nov 2013
                                        • 274
                                        Why are the voltages different now???
                                        It's BQ24707A...
                                        Leave it on charger for 2 minutes & I think you'll get the same voltages as in your 1st post...
                                        I think it's in Over Current Protection and therefore charging is disabled...
                                        • loser18
                                          • Nov 2013
                                          • 274
                                          The IC cannot maintain the input current level if the charge current has been already reduced to zero. After the
                                          system current continues increasing to the 1.66X of input current DAC set point (with 2.5ms blank out time),
                                          IFAULT is pulled to low and the charge is disabled for 1.3s and will soft start again for charge if ACOC condition
                                          goes away. If such failure is detected seven times in 90 seconds, charge will be latched off and an adapter
                                          removal and system shut down (make ACDET < 0.6V to reset IC) is required to start charge again. After 90
                                          seconds, the failure counter will be reset to zero to prevent latch off.
                                          Think the IC is dead / shorted...Or some cap around shorted...
                                          It's a hardcore case without schematics...
                                          • toniu-massa
                                            Dell 15-5570, CAL50/DAL50 LA-F115p - Does not detect original charger
                                            by toniu-massa
                                            Hello, everyone!!! Happy New Year to all!!!
                                            When I turn on the laptop, the warning appears: You have attached an undersized 0W adapter and blah, blah, blah... The bios says that the adapter is not connected and the battery status is excellent.
                                            This laptop has all the voltages at the input, and the charger IC is also normal. There is 3.3V at the PS_ID and I have already tested it with another adapter, also original. The adapter detector also seems to work normally. I am suspecting the SIO. What do you think?
                                            On my portable oscilloscope there is a PS_ID signal....
                                            01-02-2025, 02:02 PM
                                          • BTubbs200
                                            Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                                            by BTubbs200
                                            Dell Latitude 5420 P137G
                                            Board: LA-K491P REV A01
                                            I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                                            Board seems to have no shorts, all power rails are fine and show high resistance.
                                            When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                                            01-24-2025, 08:15 PM
                                          • Johndill
                                            Dell Inspiron 7567 LA-D993P odd charger issue
                                            by Johndill
                                            Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                                            There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                                            I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                                            Here are the tested scenarios:
                                            1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                                            2. With the laptop off, plug in charger (LED says on) & the front charging...
                                            11-16-2022, 10:55 PM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • PowerAmpFreak
                                            Dell Latitude 7280 does not recognize charger
                                            by PowerAmpFreak
                                            I have a Dell Latitude 7280 which complains during boot-up that the charger wattage cannot be determined. Tested with two different chargers.
                                            Any common faults that could be fixed?
                                            I replaced the DC jack, the original DELL LATITUDE 7280 DC30100Z300 0DP4VC.
                                            How does the communication between the charger and the PC work?...
                                            Yesterday, 07:18 AM
