MacBook Pro A2251 820-01949-A stuck on 5V
  • mferna14
    • Jun 2018
    • 1010
    Hi Dear friend., I am working MacBook Pro A2251 Logic board 820-01949-A. The history was that there was slight liquid on the LHS CD3217 & was not powering on at all. No 20v or any amps. I replaced with known good CD3217s & then got the power but its stuck on 5V .18amp. I did power measurements which are below:
    PPBUS_G3H=12v
    PP3V3_G3H=3.3v
    PP3V3_UPC_X_LDO=3.3v
    PPDCIN_G3H=5v ????
    PP1V8_SLPS2R=1.8v
    Do you think the other RHS CD3217 have to be replaced to as they might have gone defective????​
  • mon2
    • Dec 2019
    • 13865
    https://logi.wiki/index.php/CD3215_Bootup_Sequence
    • mferna14
      • Jun 2018
      • 1010
      Thanks mon2., the Boot seq' is out dated & for A1706... The "Name of Net" does not match in this model schematics. Now I have to figure out all the rails which has to be present before I get the 20V. Do they have any latest boot sequence for CD3217B12???
      • mon2
        • Dec 2019
        • 13865
        https://logi.wiki/index.php/CD3217_a...er_on_Sequence
        • mferna14
          • Jun 2018
          • 1010
          actually I was checking on Logi Wiki & found it later. I will check all the rails in sequence tomorrow. PPDCIN_G3H=5v should be 20v, there is no shorts & checking YT videos I actually figured out all voltages that should be present on these chips, this is why I was asking should I go ahead & replace the remaining two CD32s. Now before this I will check the CD3217 power seq' first. Thank you very much dear...
          • mon2
            • Dec 2019
            • 13865
            PPDCIN_G3H will be 5v as a power on default with all PD power supplies. Only after the PD controller (CD321x ACE devices) are working properly will the higher voltage be selected and then PPDCIN_G3H = 20v. That is, the ISL controller onboard (buck boost type) will be in boost mode when the input voltage (PPDCIN_G3H) is 5v; will be in buck mode when the input voltage (PPDCIN_G3H) is at 20v.
            The suspects are still the CD321x PD controllers for now. Test each like the original article by piernov and others. Test the CCx lines in diode mode to confirm they are not defective. The CCx lines are used for the 1-wire BMC communication to exchange the PD contracts by the PD power supply and then the CD321x will select the optimum contract to power the board. By default, 5 volts is the PD contract.
            • mferna14
              • Jun 2018
              • 1010
              mon2., after a long trouble shooting, one of the CD3217B12 was defective. Now I get 12V on Fuse F7000, 3.3V on L7660 & 5V on L7030 without any volts fluctuating​ but still it stuck on 5v .19amp. I checked for any short but none. But only on ONE USB-C connector, all the about required voltages are present & then it resets (Blank on the amp meter) & then back again, other 3 USB-C Ports all are perfect, no reset at all. Kindly help me what is the next step I should look for???
              • Stephen
                Meow Meow MEOW!
                • Apr 2020
                • 667
                Did you replace the USBC CD3217 with a new one or a donor?
                sigpic
                MEOWING IN THE IMPOSSIBLE UNIVERSE!
                • mferna14
                  • Jun 2018
                  • 1010
                  Stephen, One side Brand New where it resets always & the other side where the amp volts are stable & taking .19amp both taken for a good working donor board (re-balled both & then soldered to the logic board). Why are you determining that the Brand New ones are not compatible???
                  • mon2
                    • Dec 2019
                    • 13865
                    The PD controllers are still suspects.
                    https://repair.wiki/w/MacBook_Pro_A2...cycling_repair
                    • Stephen
                      Meow Meow MEOW!
                      • Apr 2020
                      • 667
                      A2251 must use the chip from a Donor board. You cannot just replace it with a new chip, depending on the side of the chip, you will need the CD3217 from a Donor A2251 board on the exact location. You may have ruined the board moving forward with a new chip. This particular board needs a DONOR, or you can program the new CD3217 chip based on the location. There is a CD3217 chip reader and programmer for this particular reason.
                      sigpic
                      • mon2
                        • Dec 2019
                        • 13865
                        Where? Can you link it? Is it open sourced?
                        • mferna14
                          • Jun 2018
                          • 1010
                          [QUOTE=Stephen;n3506032]
                          A2251 must use the chip from a Donor board. You cannot just replace it with a new chip, depending on the side of the chip, you will need the CD3217 from a Donor A2251 board on the exact location. You may have ruined the board moving forward with a new chip. This particular board needs a DONOR, or you can program the new CD3217 chip based on the location. There is a CD3217 chip reader and programmer for this particular reason.[/QUOT
                          Dear, now I used all CD3217 chips from Donor boards. The problem was still the same, one side was stuck on 5v .19amps on both ports & the other side on one port it was resetting after been stuck on 5v .19amp & the other port (Same side) just stuck on 5v 0amp..... But during all this operation I was surely getting 12v, 5v & 3.3v when the ports on one side were showed 5v .19amp on the amp meter. So I removed the 12v fuse & every single port got stable. All ports were showing Stable 5v 0amp without any kind of resets. I think the problem is after the fuse. CD3217 seem to be working & now I have to trouble shoot the problem after the fuse. & BTW never heard of a CDs Programmer & does these chips need programming???? Are CD3217B12 Progammable????
                          • Stephen
                            Meow Meow MEOW!
                            • Apr 2020
                            • 667
                            https://www.aliexpress.us/item/32568...2usa4itemAdapt
                            You need this tool for the USB C chips. There is a YouTube video on how to do this. I cannot remember the link but this is the tool that needs to be used.
                            sigpic
                            • mon2
                              • Dec 2019
                              • 13865
                              That tool is just a low cost hardware that provides a USB to SPI bridge based on the WCH controllers. Any flash programming tool can perform the same. This tool is providing a bank of ROM dumps that could be used to reflash the target memory chips.
                              • piernov
                                • Jan 2016
                                • 4435
                                • France
                                I do agree with mon2 . Additionally, I'm pretty sure the related SPI ROM dumps have already been posted before.
                                This does not look like a tool that can deal with the (supposedly) OTP ROM of the CD3217 ICs which causes so many issues with 4-ports boards.
                                • mferna14
                                  • Jun 2018
                                  • 1010
                                  Read all., so what's the solution??? Means that I only have to reprogram the U3060 & UB260 according & where are the dumps to program these chips again & hopefully can be re-programmed on a Univeral Programmer???
                                  • mon2
                                    • Dec 2019
                                    • 13865
                                    https://www.badcaps.net/forum/troubl...iles-requested
                                    • mferna14
                                      • Jun 2018
                                      • 1010
                                      mon2., thank you very much, got all the bins. Now please inform me one thing., should I just put in all 4 new CD3217B12 on this MacBook Pro A2251 Logic board 820-01949-A & program U3060 & UB260??? & I read that a univeral programmer can be used to program these chips & what ID should I use for these chips or it will automatically detect the identity of the chips by itself?? Thanks dear
                                      • mon2
                                        • Dec 2019
                                        • 13865
                                        Personally cringe and my family jewels run for the hills if dealing with any BGA rework so suggest to leave the CD3217 controllers alone at this time. Although, yesterday managed to rework a 1.4*1.4mm FPGA with 16 balls (WLCSP package) to remove a few shorts. Worked out fine. It is the world's smallest FPGA device = Lattice ICE40UL1K (physically). It is a new product we designed for DIY developers.
                                        Yes, the referenced FLASH devices are correct and believe the downloaded dumps should offer the binaries for these targets. Suggest to make a backup of the original devices using your tools. Be sure your programmer can support the target voltage of 3v3 for the flash.
                                        The part # is in the schematic = W25Q80DVUXIE = Winbond. Ideally your programming tool will support Winbond -> search for W25Q80. Based on the schematic labels, the flash device is operating in standard SPI mode (not QSPI = Quad SPI mode).
                                        Summary - test only the external flash dumps.
                                        • Runnerboys
                                          Macbook a2251 Water damage- stuck on Logo
                                          by Runnerboys
                                          Would appreciate your input, we have fixed a water damage motherboard for the a2251, there was mainly corrosion next to the 2 locations, but were able to clean it all
                                          First few times- the Macbook would boot and got to login screen (didn't try to login), day after, when we tested it - it would get stuck on the logo and won't show welcome screen
                                          What would be the best step to take from here to test? should I test Mobo components/ chip / storage? and if so- where do I start?
                                          OR should I try to use the Apple Configurator and connect...
                                          05-17-2023, 11:40 PM
                                        • Adogabriel100
                                          where to get trusted CD3217. Problem with A2337 Macbook Air
                                          by Adogabriel100
                                          Hey! As the title says. i don't know if this is the right place to ask but i need to get trusted USB C Controllers (CD3217-CD3215) For macs and dont know where to get them. i dont know if you guys know where is a good place to get it.
                                          The thing is that i have a Macbook air A2337 M1 and i dont have a donnor board to get the CD3217. So i try the CD3217 from a A2141 Board and at first, whitout his eprom it does not convert 5v to 20v. then i put the original CD3217 eprom from the A2141 and then the macbook A2337 conver the 5v to 20v but still not turning on. i guess that the CD3217 is...
                                          09-06-2024, 12:06 PM
                                        • ronelex
                                          Macbook Pro A2251 Stuck on 5v
                                          by ronelex
                                          Hi everyone, I have this unit A2251 820-01949.
                                          I receive this unit with a shorted PP3V3_G3H and found the culprit C8161 shorted and I remove it but the unit still stuck at 5v 0.04A
                                          This are the readings I got on the unit
                                          PPBUS_G3H -12.33v
                                          PP1V8_SLPS2R -0v
                                          PP3V3_G3H_PMU_VDDMAIN/PP3V3_G3H - 0v
                                          P1V8G3S_EN from u7800 - 0v
                                          U3100_W
                                          PPHV_INT_G3H_W - 5v
                                          PP1.5_UPC_LDO_CORE_W - 1.5
                                          PP3V3_UPC_W_LDO - 3.3V
                                          PP3V3_G3H_RTC - 3.3V
                                          U3100_R
                                          PP1.5_UPC_LDO_CORE_R - 1.5
                                          PP3V3_UPC_R_LDO - 3.3
                                          PP3V3_G3H_RTC...
                                          12-17-2023, 10:28 AM
                                        • Bmet
                                          MacBook Pro 13 inch A2238 M2 stuck on 5V
                                          by Bmet
                                          I have a MacBook Pro 13 inch A2238 M2 and it was stuck 5V with 0 amps. I measured some important lines and I found a short on PP3V8_AON_MPMU_ISNS_VIN, I tried injecting 1v and I saw heat coming from the mPMU so I removed the pmu thinking that was the problem. I don't know why I didn't check the other side of the border but there it was, a shorted cap. I replaced the cap and the short was gone, so I reballed the PMU and put it on again but voltage was still stuck at 5V and the current was fluctuating between 0 and 0.45 amps. I checked under the thermal camera and I saw the mPM...
                                          04-02-2025, 05:02 PM
                                        • TechSplendid
                                          MacBook A2442 not powering on – suspecting CD3217, but replacement didn’t help
                                          by TechSplendid
                                          Hi All,
                                          I'm working on a MacBook Pro A2442 (14", 2021) that's not powering on. On two out of three USB-C ports, I get 5V and the current briefly ramps up to around 0.210A before dropping to 0.036A. On the third port (JF600), I only get 0.0045A and it stays there.
                                          Initially, I suspected a faulty CD3217 on that port, especially since I noticed signs of previous liquid damage near the JF600 USB connector. I replaced the CD3217 with an UF400 (from an A2442 donor board from the same location). According to the supplier, this should be a compatible version, but the behavior...
                                          04-09-2025, 02:13 AM
