MacBook A2442 exclamation mark after oxydation
  • Enzo150i
    Enzo
    • May 2021
    • 10
    • Italy
    I have a MacBook Pro A2442 with board 820-02098-A very highly oxydated (water) by an accident.
    The customer just need to recover the data (no backups, heh), so we cleaned fully to make it power on.
    Fortunately the Mac is still alive but it shows an exclamation mark in a circle (!) (Apple T2 fw issue?) with the text "support.apple.com/mac/restore" and doesn't go further.
    We tried to interface with another Mac, but can't get in DFU. Very likely the keyboard is gone too because the water, so we're planning to buy a cheap compatible one just to.
    Before we do this I would ask if there's something we could check before (maybe a faulty data line?) and if the recovery will delete any data on it to restore the Mac.
    We need to extract data, other stuff is not important.
    Thank you!
  • Enzo150i
    Enzo
    • May 2021
    • 10
    • Italy
    Anyone, please? We're afraid to do a bad move because of data
    • mon2
      • Dec 2019
      • 14191
      Are these pics before or after the cleaning? Can you share the pics after the cleaning? Do you have the proper power rails for these SSD devices? Personally have not performed data recovery at this level yet. If possible, try to work with the board in front of you. Plan B is to move these devices + T2 onto another working good board. Believe that is the alternate procedure.
      The '!' symbol usually equates to the SSD not being detected. This could be due to the lack of power to the SSD rails or the SSD is defective. Cannot recall if A2442 is one of the models with the nasty TI regulator voltage overshoot fault. Will investigate.
      • Enzo150i
        Enzo
        • May 2021
        • 10
        • Italy
        Hi! Sorry for the delay. The pics posted before are before the cleaning, just to show you all which parts were oxydated. Attached the pics of the cleaned board and the "!" simbol on screen.
        I've not checked any power rail yet, to be honest, since it powers on. I've seen online that this kind of error is about the T2 so I've not checked anything. The Mac does not go into recovery and/or boot option, but again it could be a bad keyboard.
        Unfortunately we don't have right now a donor board to swap stuffs on, we should buy it in case, but if we can try to just start this would be better.
        Thanks!
        • Enzo150i
          Enzo
          • May 2021
          • 10
          • Italy
          mon2 any suggestion, please? 🥺
          • mon2
            • Dec 2019
            • 14191
            A globe with an exclamation mark on a Mac startup screen indicates that the computer is unable to locate a valid startup disk. This often occurs after failed attempts to recover macOS. To address this, you can try booting into Internet Recovery (Command + Option + R) to reinstall macOS. If that doesn't work, check the internal SSD connection or use Disk Utility to repair the drive.
            Share the voltages to ground of the SSD power rails.
            • reformatt
              • Feb 2020
              • 1410
              Are the NAND's underfilled? If not, highly likely they're contaminated. See if the SSD is visible in recovery mode.
              NAND's are encrypted by the T2. You'd have to move the NAND's (to the exact same locations) and T2 to another board to get data if the board is U/S. This best done by some who is experienced (like iBoff, those kind of guys).
              • dbuergi
                Macbook A2442 no display board 820-02098
                by dbuergi
                i got a Macbook A2442 which statrts normal but is not showing any picture. Using an external monitor works fine. After opening the Macbook i found a dried up line of liquid damage around CN979, RD503, and UP730. I cleaned up everything and also unsoldered the chips to clean the pads. There were no shorts before but i still don't have any picture. Sometimes you can see a glimpse of light in the middle of the display.
                So before i change the whole display i want to make sure that it's not any issue with the logicboard. So any ideas what i can check next?...
                05-25-2025, 10:58 AM
              • TechSplendid
                MacBook A2442 not powering on – suspecting CD3217, but replacement didn’t help
                by TechSplendid
                Hi All,
                I'm working on a MacBook Pro A2442 (14", 2021) that's not powering on. On two out of three USB-C ports, I get 5V and the current briefly ramps up to around 0.210A before dropping to 0.036A. On the third port (JF600), I only get 0.0045A and it stays there.
                Initially, I suspected a faulty CD3217 on that port, especially since I noticed signs of previous liquid damage near the JF600 USB connector. I replaced the CD3217 with an UF400 (from an A2442 donor board from the same location). According to the supplier, this should be a compatible version, but the behavior...
                04-09-2025, 02:13 AM
              • Constantinos
                Macbook Pro A2442 820-02098 No image but has backlight
                by Constantinos
                Hi all
                I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
                He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
                Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
                Obviously, he decided against this and gave it to me so that I could have a crack at it.
                From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
                08-24-2024, 09:48 AM
              • sjsul
                Macbook M1s exclamation mark not seen in DFU
                by sjsul
                Hi colleagues,
                I have a situation with 2 Macbooks M1, 1x A2337 and 1x A2338. I will post below the symptoms and what I have tried until now
                - They both power on and display the exclamation mark 1 second after displaying the Apple Logo
                - They both try to enter Recovery but after restart they loop in the step above, showing the exclamation mark
                - They both enter DFU but are not recognized by the other computer. Also tried force DFU, bot have voltage on SOC_DFU_STATUS. Still not found by other computer in Apple Configurator or Finder, used more cables, TBT3 and...
                04-11-2025, 01:01 AM
              • veedo
                Macbook A2442 820-02098 boot and display issue
                by veedo
                Hi All
                I have MacBook A2442 which had keyboard replaced and now it doesn't turn on correctly, it have sound chime from time to time and Apple logo shows on the display and there is no backlight on, apple logo appear and stuck on kind of boot loop. But if one of the display flexes is disconnected from the motherboard then MacBook turns of fine with the external monitor and it keeps working fine.
                Without keyboard its still have same issue, I don't have second display to replace it and compare but does display can make issues with boot?
                I found component UD290 ( SF0101-I2C) little...
                04-01-2024, 06:06 AM
