Alienware M17 R3 M/B LA-J521P charging issues
  • ub6ib969
    • Jul 2010
    • 201
    Alienware m17 R3 which charges using USB-C however it does not charge using PJPDC1 (dc jack)
    • disconnected PJPDC1 and measured voltage on Pins 1-6 19V (19V_ADPIN)
    • once connected into PJPDC1 PIN 1-6 1.20V (19V_ADPIN)
    • Diagnostic tests does not detect charger.
    Has anyone have this issue before?
  • mon2
    • Dec 2019
    • 14677
    What are the details of the dc jack power adapter? Alienware = Dell so most likely using the PSID 1-wire interface to identify the power adapter. Is the BIOS able to detect the power adapter? If not, the PSID is not working.
    Confirm that the DCin jack is not defective.
    Confirm (without power to the board) that the PSID pin of the DCin jack is mating with the PL13 ferrite bead on the logic board.
    Then, attach the power adapter to this logic board and measure the voltage to ground of either side of PL13. What is the voltage?
    There are many threads on this forum on this topic so do review them but often, PQ4 mosfet becomes defective or the DCin connector itself is at fault.
    Be sure that you are using a true Dell brand power adapter and not a DC power supply. Only the original adapter will offer the 1-wire device to identify the power adapter's specifications.
    Click image for larger version  Name:	PSID.png Views:	0 Size:	144.5 KB ID:	3500017
    • ub6ib969
      • Jul 2010
      • 201
      • It is OEM 240W Dell Power adapter
      • I do not have a dc jack to check however i did measure pin1-6 and I am receiving when measure the dc jack connecter unplugged from the board.
      • PSID pin of the DCin jack is mating with the PL13 confirmed.
      • PIN 13 PSID 3.17v
      • 0V on PL13 with the power adapter plugged in and battery unplugged.
      thank you for all the help
      • ub6ib969
        • Jul 2010
        • 201
        replaced pq4 however still does not detect a charger. It does detected a usb c charger though.
        • mon2
          • Dec 2019
          • 14677
          Missed that you lose the adapter voltage on insertion into the dcin jack. This implies a power path issue. Review the sticky above by piernov on battery charge circuits.
          Trace where this adapter voltage travels. Remove all power. Measure the resistance to ground of this output rail.
          With no power, test the resistance across the mosfets in the power path to the charger chip.
          Measure
          source & drain
          source & gate
          gate & drain
          The unit operates ok on the usb C power adapter or when using a charged battery?
          • ub6ib969
            • Jul 2010
            • 201
            The unit does operate fine and charges on usb c power. If usb -c is being used are the same mosfets used to the intersil IC or does it use a different path ?
            • mon2
              • Dec 2019
              • 14677
              Attach the power adapter. Measure the voltage to ground on the mosfets @ PQ12, PQ15. Measure source (1-2-3); gate (4); drain (5-6-7-8) on each mosfet. After PQ15 -> the charger IC follows. This is for the barrel jack power adapter power path.
              When using the Type C adapter, it is PUS02 who passes on the VBUS voltage from this source onto the charger IC which we know works.
              So the suspects are the PQ12 & P15 mosfet cluster and their driving circuits.
              Post each measurement.
              • ub6ib969
                • Jul 2010
                • 201
                thanks again for your help. i measured the following.
                PQ12 1-2-3= 0v 4=0v 5-6-7-8 = 0v
                PQ15 1-2-3=0.5v-0.8v 4=0v 5-6-7-8 =0v
                update: removed PQ12 and receiving 19v on 1-2-3 gate.
                • mon2
                  • Dec 2019
                  • 14677
                  Source pins = 1-2-3
                  gate pin = pin 4
                  drain pins = 5-6-7-8
                  If you remove PQ12, you have 19v present on the removed PQ12 pcb pads - pins 1-2-3?
                  Confirm that you have 19v present on each side of the emi coils @ PL8-PL12.
                  • ub6ib969
                    • Jul 2010
                    • 201
                    don't have the same exact mosfet P-Channel EMB03P03H but can I use PZ0703EK MOSFET? almost same values.
                    • ub6ib969
                      • Jul 2010
                      • 201
                      Originally posted by mon2
                      Source pins = 1-2-3
                      gate pin = pin 4
                      yes when pq12 removed, pins1-2-3 receive 19v
                      PL8-PL12 = 19.9V on each side of the coils.
                      • mon2
                        • Dec 2019
                        • 14677
                        The other P-channel mosfet you have should be ok as a replacement for PQ12. If you solder back PQ12, the voltage on pins 1-2-3 (source) are no longer 19v? If correct, remove all power, meter in resistance mode. Measure the resistance to ground of the drain pins (5-6-7-8) on PQ12.
                        What are the voltage measurements to ground on the comparator @ PUS06A? The issue may be the gate driving logic that is south of the mosfet @ PQ12 in the schematics. Going cross-eyed following this spaghetti schematic.
                        We know that PQ12 is a P-channel. For this mosfet to enable, the gate voltage must be lower than 19v. For this to occur, the 2N7002 @ PQ8 must enable. The gate pin on PQ8 is driven by the comparator @ PUS06A pin # 1.
                        • ub6ib969
                          • Jul 2010
                          • 201
                          - soldered back the "sus" mosfet removed and resistance to ground for pins 5-6-7-8 = 1.479v, i am now getting 19V on 5-6-7-8 Pin 1-2-3 = 19V PIN 4 = 9.4V
                          - PUS06A PIN 4 (GND) = 0V
                          - PUS06A PIN 1 = 3.2
                          - PQ8 PIN 1 D4_DCIN = 0V
                          • ub6ib969
                            • Jul 2010
                            • 201
                            PQ8 without PQ12 mosfet PIN 1 =0v, PIN 2 =3.2V PIN 3 = 0v
                            PQ8 with PQ12 mosfet PIN 1 =0v, PIN 2 =3.2V PIN 3 = 0v
                            is 3.2V the correct value for PIN 2 @ PQ8? seems it is getting the same value from PUS06A pin # 1.
                            • ub6ib969
                              • Jul 2010
                              • 201
                              update: the charger was detected and charged overnight, however but once discharged the charger was no longer detected. There is now a short to ground at PIN 2 on the PQ8 G4_DCIN @ 002.9 OHM in addition PUS801 is very hot.
                              removed PDB11 and PRS892 to see if the short would disappear but it still exists.
                              • mon2
                                • Dec 2019
                                • 14677
                                Remove all power. Meter in resistance mode. Measure the resistance to ground of PUS801, pin # 3 = output of this LDO regulator.
                                Keep in mind that this is a LDO regulator (not a switching type). Due to this design, this part is 'burning' the very high voltage of 19v down to the output of 3v3 so yes it will produce heat in the process. The heat you are measuring may be normal for such a high voltage (input) regulator.
                                • ub6ib969
                                  • Jul 2010
                                  • 201
                                  PUS801, pin # 3 = 0.201V (resistance mode)
                                  • mon2
                                    • Dec 2019
                                    • 14677
                                    Can you share a pic of your meter face when measuring this? If you are truly in resistance mode, then the measurement will be in ohms. If in DC volts mode, then the measurement will be in volts (V).
                                    We need to confirm the meter setting and also the LCD screen display units of measurements.
                                    • ub6ib969
                                      • Jul 2010
                                      • 201
                                      thank you for taking all this time. appreciate all the help.
                                      picture uploaded.
                                      black probe on ground and red probe on pin 3 of pus801
                                      • rogfanther
                                        • Jul 2006
                                        • 458
                                        • Brazil
                                        These measurements are with the suspect PQ12 soldered on the board, right ?
                                        Please, set the meter in Ohms ( about two positions turning clockwise on your meter ) and measure
                                        source to drain
                                        source to gate
                                        gate to drain
                                        as pointed by mon2 above.​
                                        • armands0212@gmail.com
                                          Alienware 13 power/freeze issues
                                          by armands0212@gmail.com
                                          hi guys.i have problem with alienware 13 r1.Basically its running ok as long as it is on power supply and i dont put it on sleep(if put it on sleep it wont wake up just freeze and need to do hard shut down),if running only on battery than it freeze straight away on account login screen.
                                          But if i disable nvidia gpu and running only on intel hd graphics than no problems at all.
                                          Look like laptop previously have been overclocked as base speed is 2.4ghz but should be only 1.7ghz and if i try disable overclocking in bios nothing changes.
                                          i tried to adjust power managment...
                                          12-20-2022, 09:23 AM
                                        • z32KRAzY
                                          Alienware 15 R3 Motherboard Issues Help Plz!
                                          by z32KRAzY
                                          Hi, I have an Alienware 15 R3 that I just bought a new motherboard for from ebay.. I have been trying to figure out this issue for 2 weeks already and I've decided I need help from the pros.
                                          Laptop specifics:
                                          Model : Alienware 15 R3
                                          CPU : i7 6820HK
                                          GPU : Nvidia GTX 1080 Max Q
                                          RAM : 16GB PC4-19200 (8GB x 2)
                                          STOR : 256GB M.2 SSD + 1TB HDD
                                          Motherboard : Compal LA-D753P Rev 1.0
                                          Problem : The laptop runs fine with most things, even GPU/CPU stress tests seem to run without problems for extended periods of time. BUT...
                                          08-07-2022, 06:08 AM
                                        • kain0007
                                          Alienware X15R2 P111F black screen after updating windows.
                                          by kain0007
                                          Hi Masters.
                                          I have an Alienware x15R2 laptop that went black after updating Windows.
                                          Could someone help me repair my bin?
                                          Alienware X15R2
                                          ST: 1CJY6M3
                                          Thank you very much for your support....
                                          10-09-2025, 02:20 PM
                                          Alienware 13 R3 Notebook Specification for Upgrade or Repair
                                          This specification for the Alienware 13 R3 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13 R3 boardview and 13 R3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Alienware 13 R3 Notebook...
                                          09-06-2024, 06:42 AM
