As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
I wonder if re-flashing the BIOS might be of any use here.
As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM, remove everything including the RTC battery and so on.
Nothing helped.
Do 820, 840 Elitebooks require a battery to be attached? I dont have batteries.
I also read that "some of these (hp) battery-connectors require a "physical connection", so they thinks there is a battery attached?
I have a Elitebook 820 (Gen1) here, with these flashing LEDs.
BIOS "Crisis Recovery" Win+V or Win+B wouldnt do anything, just the flashing LEDs
Also, which chip would be the BIOS here?
After reading some more into it, I purchased the "standard black" CH341A USB with a clamp and adapters.
Which adapter would I need to use toghether with the clamp and how? I read the clamp wont work on some "feet".
And would there a additional way to tell if it is the CPU/GPU or Motherboard?
For desktops I used PCI cards back then, that showed an additional "error codes" in red numbers for example.
Thank you in advance.
Nothing helped.
