macbook a1707 no power
  • Arshad alam4659
    • Aug 2020
    • 157
    • India
    i have a mb a1707 820-00928-a u8605 is heating in this board and 300ma what is this ic
  • SarcasticOP
    General question about MacBook power rails for repair.
    by SarcasticOP
    I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
    • PPBUS_G3H (12.6V-12.8V)
      • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
    • PP3V42_G3H (3.42V)
      • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
    • PPVRTC_G3H (3.3V)
      • This
    12-12-2024, 05:50 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • PantherDave
    by PantherDave
    Hi all!
    05-29-2024, 02:01 PM
  • GLISIT
    by GLISIT
    01-16-2025, 02:29 PM
  • TimScrawn
    MacBook Pro A1707 820-00928-A No power not turning on or charging
    by TimScrawn
    Got a very strange one here. Got an A1707 that came in dead no power. Plugged into amp meter and get 5v and then power cycles. After removing the board from the housing, I get 5v on all 4 ports with no amp draw, but it stays at 5v. I then check all rails:
    PPBUS_G3H - 2.3v - Not shorted (1.8 megaohms)
    PP3V3_G3H - 3.3v
    PP1V8_UPC - 1.8v
    PP3V3_UPC - 3v3v
    D6902 - 3.3v on pin 1 & 3
    I then saw these readings and thought, classic ISL9239 issue
    Removed ISL and replaced with donor board. Mac powered up to 20v and drew around 300mah
    10-04-2025, 04:59 AM
