Seeking Dell G15 Motherboard ICs for Embedded LED Controller (UEL1 and UEL2)
  • NotEnough
    • Oct 2024
    • 5
    I'm working on a repair for my Dell G15 motherboard (model GDL5L) and need two specific ICs to restore the functionality of the Embedded LED Controller (ELC). The missing components are labeled as UEL1 and UEL2 in the schematic, and they're both critical for LED control and system signaling. Here are the details:
    1. UEL1
    • Part Number: SA0000AWJ70
    • Model: STM32F070CBT6TR_LQFP48_7X7
    • Function: This microcontroller manages system signaling, power management, and SPI communication. It's responsible for interfacing with the LED control system via multiple SPI lines and 3.3V ELC power.
    2. UEL2
    • Model: GD25Q80CSIGR_SO8-X
    • Function: This is a SPI flash memory chip likely used for storing firmware or configuration data related to the Embedded LED Controller. It's directly tied to the ELC function and connected to the UEL1 microcontroller.
    The schematic shows that UEL1 handles several critical lines, including SPI MOSI, SPI CLK, and 3.3V ELC power, making it essential for the LED control system on the board. I've checked traditional suppliers, but sourcing these specific Dell components has been challenging.
    If anyone has these ICs available or knows where to source them, I'd appreciate any assistance. Used or salvaged parts are welcome as long as they're functional. Feel free to reach out here or via direct message. Thank you for your help!
    Best regards,
    Notenough
  • piernov
    • Jan 2016
    • 4439
    • France
    Finding the parts is easy, any electronics distributor will have them, they are off-the-shelf parts. Finding the firmware may be more difficult, that should be requested in the BIOS request subsection https://www.badcaps.net/forum/troubl...-requests-only .
    • NotEnough
      • Oct 2024
      • 5
      Thanks for the response. I understand that similar ICs might be available through standard distributors, but I'm specifically looking for Dell-compatible components due to potential firmware and compatibility issues. The components I need, UEL1 (SA0000AWJ70) and UEL2 (GD25Q80CSIGR_SO8-X), are not showing up in general listings, possibly due to their OEM configuration. I am trying to see if anyone knows where I can source these. Either scrapped off a dead motherboard or elsewhere.
      • mon2
        • Dec 2019
        • 14720
        The STM32F070CBT6 will have an internal flash to hold its firmware. This device has some level of protection bug believe it has been compromised. With some patience and proper tools you may be able to extract the original firmware.
        • NotEnough
          • Oct 2024
          • 5
          Yeah I know. That’s why I’m looking for any leads of a Dell specific one. Mine went bad and it’s impossible to find one on eBay or anything. I have a CH341A but the firmware is absolutely nowhere online.
          • thinkcentre
            Dell Optiplex 3060 Micro USFF (IPCFL-CG Motherboard) - No LED / Short Circuit
            by thinkcentre
            this is my first post at Badcaps and in general i am new to fixing electronics. I am looking forward to learn a bit more about diagnosing and repairing :-)
            What I have around is a DELL OPTIPLEX 3060 Micro (USFF), which is not powering on, even not showing any signs of life (No amber / white LED).
            I got a original 65W DELL PSU / Power brick (PA-12 / 074VT4) which hopefull should be the correct one. I could get another DELL PSU with the Partnumber 0G6J41 with the same 4.9mm DC Jack connector as the one I already have, but I dont think that would help (maybe...
            11-09-2025, 12:39 PM
          • Geeker007
            9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
            by Geeker007
            Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
            I am new to electronics repair, so my queries could be naive but I am ready to learn.
            So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
            01-28-2025, 03:31 PM
          • Julian Bailey
            Dell Latitude 5350 Ultra 7 Motherboard
            by Julian Bailey
            Hi
            I have a Dell Latitude 5350 Ultra 7 Motherboard I am trying to repair that has a blown chip.
            The chip is marked as eHOLH similar to the one I have pictured.
            Any ideas what it does and what the pin outs are as 3 tracks have gone and need to find out what / where they went / did etc.
            Dell PN of the motherboard is 08DCGW.
            Below is the area I am trying to repair:
            Does anyone have a picture of this motherboard in this area they could take and upload?
            Cheers...
            07-03-2025, 11:25 PM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • Spikeman
            Dell Precision 3440 support for CPU 11th gen
            by Spikeman
            Hi, since both the Dell Precision 3440 and the Precision 3450 have the same chipset W480.
            I ask you if it is possible to add the correct microcodes for the Precision 3440.
            I am adding the list of files that I have extracted from the Bios in order to help you understand if it is feasible.
            Precision_3440_1.31.0.exe_extracted Precision_3450_1.31.0.exe_extracted
            03-11-2025, 09:54 AM
