I'm looking for CD firmware
ipad a2435 not charging
by badboyzzzI have a strange problem with my iPad Pro 12.9 4Gen / A2229. When I start the device, it stays on the Apple logo, but when I heat the back of the device with a hair dryer, the device boots, but this time there is an interesting problem. The iPad is charging, but there is no USB data on the computer. The USB charging port has been changed and the chips seem normal, but I have given it to 2 different Apple services in Latvia, but the repair could not be done. Is there anyone who can help with this? Can someone support the repair by sending only the motherboard within Europe? Thank you.
by AimbitI purchased some broken iPads (non-charging), trying to repair something a little trickier than retro consoles... I have all the necessary tools.
A1430 - Draws 930mA consistent, screen is black with red/empty battery icon, no charging symbol.
A1403 and A1416 - Draw 930mA, wait 3 seconds, dip to 0, repeat.
A1566 - Similar to the previous issue, it draws some power for a few seconds, then resets my ammeter, and repeats. Waiting for my lightning port tester to come to check the tristar.
Seeing as these are old, and likely have been dead for ages, is a battery... -
by waterchillHey folks, I have this iPad Pro 12,9" 4Gen A2232 here with no charging issue. The main fault was a crossed pins / faulty USB charging port due a bad cable.
So I started to replace this parts:
- replaced usb-c port -> no result
- replaced battery -> no result
- replaced usb-c chip CD3217B12A -> no result
- replaced 343S00326 -> no result
- replaced 343S00327 -> no result
- replaced 343S00328 -> no result
I have no more ideas for this issue. There is no short on the whole board, and the iPad is working fine... -
by ThomasraudHello,
i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
QUOTED
-It works on charger (without battery connected-only charger)
-It works on battery (without charger connected-only battery)
-& it also works when plugged in battery & charger, but it's not charging the battery
//Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
and..
QUOTE
The IC cannot maintain the input current level... -
by GeirAndersenI tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
IPAD COLLECTION 1
+---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
+---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
+---iPad mini3 820-00008(A1599) 820-00002(A1600)
+---iPad mini4 820-00180(A1538) 820-00177(A1550)
+---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
+---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...-
Channel: Schematic Requests ONLY!
- Loading...
