Variable DC Power Supply cannot boot motherboard
  • Bonaventure Vigil
    • Sep 2024
    • 37
    • Malaysia
    Hi there,
    Guys anyone here can help me. During troubleshoot the motherboard, my 1st and new psu unable to boot the motherboard. Even though i set the 20V, my old Compaq CQ42 motherboard had the led white light at charging port. When press on button, the led blinking to red and gone back to white state. But i change the oem hp compaq adapter which is i measure 19.45V. Using that can boot the motherboard and fan spinning. Then i reconnect psu and tried set the 19.45V, still blinking red. Anyone know what happen? Is it psu not compatible? All is check and voltage is there.
  • mon2
    • Dec 2019
    • 14662
    Your (nice) power supply is OK. What is missing is the required resistor used by HP power adapters to identify the power rating. Google for articles on HP power adapter resistors. Do not proceed till you post the details of the resistor and hookup. In summary, the EC on the logic board will sample this analog safe voltage using an analog to digital controller. Then it will understand the power rating of the power supply and power up. If wired wrong, the high voltage can kill the EC controller.
    Here is the main article on this topic (must read):
    HP Thin Clients PSU (parkytowers.me.uk)
    Secondary reading:
    Bypassing this HP dc in plug? : r/AskElectronics (reddit.com)
    • Bonaventure Vigil
      • Sep 2024
      • 37
      • Malaysia
      Million thanks to you mon2. Now i know why. Still a lot things to learn about motherboard repairing. I will try make the hook up and resistor, and post it here.
      • fluzocapacitor
        ACER Aspire 5542 does not boot. Can not read BIOS on the motherboard
        by fluzocapacitor
        I am trying to fix an Acer Aspire 5542. Upon turning it on, the fan starts to spin for a few seconds and then it stops. I hear no beeps from the speaker. I have no image both on the laptop screen and through VGA and HDMI connectors.
        I measured voltages, and it seems all power supplies are OK. There are 5V, 3.3V (BIOS), 1.8V (RAM), and 1.1V (VCORE).
        I tried to read the BIOS using a CH341A programmer, but it did not detect the chip. I took the BIOS chip away from the motherboard, and then the CH341A detected the chip, and I was able to read the code. However,...
        02-01-2024, 01:24 PM
      • vallllliiii
        Gigabyte motherboard GA-H110M-S2PH (rev. 1.0) DDR3 | Boot loop and 5 beeps
        by vallllliiii
        Hi, last month i bought a broken pc that i tought i can fix for myself but it turned out to be time consuming. The pc turn on and shows no display and beeps 5 times and restarts again and again, i think it s the motherboard because i tested/replaced all the parts except the motherboard. The pc was used mostly for light gaming and i think it wasnt overclocked or something. I tried all the basic fixes(cleaning the ram slots, removing the cmos battery, reseat the GPU/CPU/RAM). I think the last thing to do is to replace or repair the mobo but i prefer to try to repair because i don t want to spent...
        08-18-2024, 09:21 AM
      • FixItBill
        Acer Aspire Vero N20C5 Motherboard FH5AT LA-K092P No Boot
        by FixItBill
        Going over the pictures attached. I have an open circuit between ground and 19V at charger port. I have 5V and 3.3V at their respective inductors. The other three inductors near the CPU measure 1.8V except PLG1 which measures 0V. When the battery is plugged in I get around 9V on pins 7 and 8 at PJP201 but I believe it should be closer to 12~13V. I have the motherboard fully removed and disconnected from peripherals. Please let me know if you need additional information/next steps guidance. Thanks!
        Here's the link to the schematic: https://www.badcaps.net/forum/troubleshooting-har...
        07-21-2025, 12:26 PM
      • Docus
        Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
        by Docus
        Hi everyone 😀,
        I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
        To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
        Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
        1. I already own the exact same model, but its plastic chassis is badly damaged.
        06-10-2025, 04:24 PM
      • Luke Anders
        Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
        by Luke Anders
        A few details about the laptop itself:
        Name: Lenovo Legion 5
        Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
        BIOS Version: GKCN60WW
        EC Version: GKEC65WW
        Serial Number: PF39AQ7Z
        Board Model: NM-D562 Rev 3.0
        RAM: 16GB Installed, DDR4 (brand new)
        NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
        I bought this laptop recently from eBay as a faulty device....
        10-12-2024, 05:13 AM
