macbook A1989 820-00850
  • PITERPENY
    • Jul 2023
    • 455
    • Ukraine
    does not turn on.
    5.060v /0.060-0.310 unstable
    no in DFU
    PPBUS_G3H=12.30v
    PP3V3_G3H=3.3v
    PP5V_G3S=0v
    help plz
  • mon2
    • Dec 2019
    • 14220
    Check the resistance to ground of PP5V_G3S (with no power). Do the same for each inductor on the board. The ace cd321x are also suspects. Check each LDO rail voltage. Study the cd3215 20v wiki page for the power on sequencing to achieve 20v.
    • PITERPENY
      • Jul 2023
      • 455
      • Ukraine
      the strange thing is that it switches to 20v/0.000a if you connect a battery
      PP5V_G3S​=8 kohm
      when removing f7000 consumption 5v/0.000a
      • mon2
        • Dec 2019
        • 14220
        Check the input current sense full path resistance on the isl controller for ppbus_g3h.
        Test the smbus line voltages on the battery connector.
        • PITERPENY
          • Jul 2023
          • 455
          • Ukraine
          replaced isl to no avail! started to carefully examine the board under a microscope and saw that the u7800 had a barely noticeable crack! replaced the u7800, 20v appeared and the macbook started charging (I still don't understand how the u7800 plays a role in the transition from 5v to 20?)! but it still doesn't start and the ssds are getting very hot!
          • ErinV
            MacBook Pro A1989 820-00850-A not powering on
            by ErinV
            Hey everyone!
            I have a MacBook Pro A1989 with a 820-00850-A board that recently stopped working. I used it overnight to charge my phone, in the morning it didn't turn on, I assumed flat battery but now won't charge and doesn't start at all.
            I have fully dissassembled it, when disconnected the battery reads at 0.012V. Even with the battery disconnected the laptop doesn't boot.
            The diode voltages around all 4 CD3215's seem fine.
            For all CD3215 (UB300, UB400, U3100 and U3200) I read just above 5V on PP20V_USBC_TA_VBUS, 3.3V on PP3V3UPC_TA_LDO, 1.8V...
            09-30-2024, 10:21 PM
          • Madoy104
            Macbook Pro A1989 - No image, working fine with external monitor
            by Madoy104
            I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
            08-15-2024, 10:01 AM
          • PITERPENY
            Macbook A1989, 820-00850, won't boot. 20V, 0A.
            by PITERPENY
            Today I have a MacBook A1989 at work 820-00850. When assembled, the laptop switches to 20 volts but the consumption is 0.00 ampere. if the motherboard is on the table then the consumption of all ports is 5 volts and0.35 amperes and does not go to 20 volts only if you assemble a MacBook.
            Here are some measurements, maybe someone can tell what the problem is.
            The initial problem was a burnt out induction coil L8504 (replaced).
            When connected to another MacBook, it constantly hangs in dfu and cannot install updates, something is wrong.
            here are some measurementsmotherboard...
            01-16-2024, 02:19 PM
          • Nikan.e
            MacBook A1989 repair / no CPU voltage no boot signs
            by Nikan.e
            Hello everyone.
            I have recently obtained a MacBook Pro A1989 model with a touch bar and Apple ID. Unfortunately, it does not want to start up.
            No CPU Voltage.
            U7800 Does produce voltages.
            T2 Chip warming up very very little.
            I do have voltages like 1.8, 0.9, 3.3, 2.5 volts, etc., present. I did not find any short circuits. Unfortunately, the device has no touch ID/start button. So, I have used the debug jumper to put the device into DFU mode. - It is getting recognized as a Macintosh while not in DFU mode and as Apple (DFU) while in DFU mode....
            11-24-2023, 11:55 PM
          • biosdi
            MacBook Pro A1989 trackpad and keyboard not working
            by biosdi
            Hi guys.
            I Just replaced battery on my MacBook Pro A1989. Unfortunately doing that, I’ve broken the trackpad flex cable (821-01701-a), and I’ve already ordered a spare one. At the same moment I’ve noticed that also the keyboard it’s not working anymore and I’ve found an SMD chip unsoldered and moving freely inside the backplate. I can read L20L on the chip. Is something could explain the keyboard not working or the keyboard doesn’t work due the unconnected trackpad?
            thanks...
            04-17-2025, 09:42 AM
