macbook A1989 820-00850
  • PITERPENY
    • Jul 2023
    • 461
    • Ukraine
    does not turn on.
    5.060v /0.060-0.310 unstable
    no in DFU
    PPBUS_G3H=12.30v
    PP3V3_G3H=3.3v
    PP5V_G3S=0v
    help plz
  • mon2
    • 14657
    Check the resistance to ground of PP5V_G3S (with no power). Do the same for each inductor on the board. The ace cd321x are also suspects. Check each LDO rail voltage. Study the cd3215 20v wiki page for the power on sequencing to achieve 20v.
    • PITERPENY
      • Jul 2023
      • 461
      • Ukraine
      the strange thing is that it switches to 20v/0.000a if you connect a battery
      PP5V_G3S​=8 kohm
      when removing f7000 consumption 5v/0.000a
      • mon2
        • 14657
        Check the input current sense full path resistance on the isl controller for ppbus_g3h.
        Test the smbus line voltages on the battery connector.
        • PITERPENY
          • Jul 2023
          • 461
          • Ukraine
          replaced isl to no avail! started to carefully examine the board under a microscope and saw that the u7800 had a barely noticeable crack! replaced the u7800, 20v appeared and the macbook started charging (I still don't understand how the u7800 plays a role in the transition from 5v to 20?)! but it still doesn't start and the ssds are getting very hot!
          • MyronViegas
            MacBook Pro 2018 A1989 820-00850-A Stuck at 5.00V and 0.150A
            by MyronViegas
            Hey guys,
            I got a MacBook Pro a1989 820-00850-A dead for repair. The MacBook itself was off for a month or so and it didn't power on. I tested using ammeter and it was stuck on 5v. Opened the machine and found a short on ppbus_g3h, corrosion near the right spkr_amp. removed the spkr_amp and saw short on ppbus_g3h. plugged in to power, boosted to 20v .600A and then back down to .300A. Trackpad was clicking when on .600A but no image etc.
            Later, I tried again but it dropped down to 5v and never boosted back to 20V. checked board again and found ppbus_g3h shorted again....
            10-06-2025, 08:45 AM
          • ErinV
            MacBook Pro A1989 820-00850-A not powering on
            by ErinV
            Hey everyone!
            I have a MacBook Pro A1989 with a 820-00850-A board that recently stopped working. I used it overnight to charge my phone, in the morning it didn't turn on, I assumed flat battery but now won't charge and doesn't start at all.
            I have fully dissassembled it, when disconnected the battery reads at 0.012V. Even with the battery disconnected the laptop doesn't boot.
            The diode voltages around all 4 CD3215's seem fine.
            For all CD3215 (UB300, UB400, U3100 and U3200) I read just above 5V on PP20V_USBC_TA_VBUS, 3.3V on PP3V3UPC_TA_LDO, 1.8V...
            09-30-2024, 10:21 PM
          • Madoy104
            Macbook Pro A1989 - No image, working fine with external monitor
            by Madoy104
            I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
            08-15-2024, 10:01 AM
          • tommy97
            MacBook A1989 No power
            by tommy97
            I’m having an issue with an A1989 board after water damage, it’s stuck at 5V 0.20A. I’ve checked the measurements, and all readings are the same across all four CD3215 chips. I replaced them one by one (using chips from a donor board), but nothing has changed.
            I don’t need a fully functional board, as the repair is only for data recovery purposes.
            • PP3V3_G3H: 3.3V
            • PPBUS_G3H: 12.26V
            • PP20V_USBC_XB_VBUS 5V
            • PP3V3_UPC_XB_LDO 3.3v
            • PP1V8_UPC_XB_LDOA 1.8V
            • PP1V8_UPC_XB_LDOD 1.8V
            • PP1V1_UPC_XB_LDO_BMC 1.1V
            Can the A1989 work with just one master CD3215? What would...
            10-16-2025, 01:57 PM
          • PITERPENY
            Macbook A1989, 820-00850, won't boot. 20V, 0A.
            by PITERPENY
            Today I have a MacBook A1989 at work 820-00850. When assembled, the laptop switches to 20 volts but the consumption is 0.00 ampere. if the motherboard is on the table then the consumption of all ports is 5 volts and0.35 amperes and does not go to 20 volts only if you assemble a MacBook.
            Here are some measurements, maybe someone can tell what the problem is.
            The initial problem was a burnt out induction coil L8504 (replaced).
            When connected to another MacBook, it constantly hangs in dfu and cannot install updates, something is wrong.
            here are some measurementsmotherboard...
            01-16-2024, 02:19 PM
