T15g Bricked BIOS - Which chip has the BIOS?
  • h3ct0r
    • Oct 2024
    • 3
    Hello, after what is seems like a bad BIOS firmware upgrade, the machine had extrange visual glitches and froze.
    The laptop now does not turn on as normal, and does not make post or show the BIOS page: It will stay at a blank page with beeping sounds: https://youtu.be/OC2o9_b1RQ0
    I'm planning to flash the bios chip with a CH341A, but it seems that they are three chip candidates:
    1. Winbond 25Q80DVSIG (3V 8M-bit) Located on the GPU board
    2. MXIC 25U8035F (1.8V 8M-bit) Located on the GPU board
    3. Winbond 25Q80DVNIG (3V 8M-bit) Located on the CPU board
    4. Winbond W25Q256JV (3V 256M-bit) Located on the CPU board
    Which one is more probable of being the BIOS chip? I have attached a picture of the mainboard where the chips are located.
    Laptop details:
    • Model: Lenovo T15g Gen 1
    • Type: 20UR-0038UK
    • Board: GP540/GP740
    • Proc: i7 10750H
    Thanks!!
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3622
    • slovakia
    th biggest is main bios
    • studdy05
      Bricked HP Probook 450 G7 Bios questions
      by studdy05
      Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
      Ive got...
      07-08-2025, 09:24 PM
    • macabook
      by macabook
      🧩 Initial Issue
      07-24-2025, 02:17 PM
    • DavidChunco
      Dell G15 5515 Ryzen Edition Apparently Bricked BIOS Request
      by DavidChunco
      Hi, I hope someone can help me with this, my Dell G15 Ryzen Edition does not post anymore (black screen, no Windows boot, no BIOS screen) after Windows Update pushed what appears to be a buggy bios image, I've tried the following with no success:
      - Receive help from Dell Support (it is out of warranty).
      - Disconnect machine from AC power and battery overnight.
      - BIOS recovery process
      - Connected external display via HDMI
      - Disassembled machine and found bios chip, its a Gigadevice 25LR128DSIG (GD25LR128DSIG), at first I tried to get it detected by CH341A (with...
      03-15-2025, 11:00 AM
    • Vesko356
      by Vesko356
      08-11-2023, 03:27 AM
    • Fr33man
      BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
      by Fr33man
      I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
      *Novo button power on
      *Disconnected internal battery...
      09-23-2024, 01:16 PM
