Macbook A2289 820-01987 stuck at 5V and 0,25A current draw
  • toniegruszka
    • Aug 2023
    • Polska
    Hello everyone.
    I have a problem finding the problem. MacBook came with a damaged flex usb c, 3 pins were shorted. No water damage.
    Voltages I have:
    pp3v3 g3h rtc
    pp1v5 upc xb ldo core
    pp1v5 upc xa ldo core
    pp3v3 upc xb ldo
    pp3v3 upc xa ldo
    ppbus g3h - 12.2V
    what I found is that there is no nand power supply
    no 1.8v, 2.5v, 0.9v
    Please give me some tips and help.
    Regards​
  • Flasman90
    Macbook Pro A2289 MXK62LL/A (661-14770) - No Startup
    by Flasman90
    Hi everyone - first time poster on here looking to embark on my first repair! Thank you in advance for any help!
    My Macbook only turns on when the charger is plugged in and only the trackpad and fans show signs of life. The display, caps lock light and touchbar do not turn on. There was previous liquid damage to the touchbar but after cleaning and drying the laptop was operational for a year without any issues. There doesn't seem to be any sign of liquid damage to the board, at present.
    What I have done so far:
    - All of the routine diagnostic methods including...
    08-29-2025, 08:38 AM
  • Woodsworth
    MacBook Pro A2289 no signs of life except clicking trackpad and charging
    by Woodsworth
    I hope this is the correct place to post about this device. I originally posted regarding this on iFixit so see the details from that post below:
    "I'm hoping someone can give their opinion on the symptoms I'm seeing before I spend any more time and put money into this. I got this MacBook from a customer and after looking at it they decided they didn't want it.
    It doesn't turn on and there's no visual signs of life. I have tried resetting the NVRAM, SMC, power cycling, unplugging the battery, using the charger with the battery unplugged. Removed the...
    03-15-2024, 04:06 AM
  • modtool
    Macbook Pro A2289 EMC 3456, MLB 820-1987-A, broken U6903, stuck at 5v
    by modtool
    Dear friends,
    a close friend of mine gave me this machine, she told me that the last days the fan was going high and that it was heating up too much for the usual things, and that suddenly one morning it didn't start anymore .
    I opened it and inspected carefully with a high magnifying lens, found no oxydized spots but a short on PPBUS_G3H , then a blown U6903.
    I changed U6903 with a new one, PPBUS_G3H became 558 (measuring with red probe to gnd , and black on F7000) , PP3V3_G3H_RTC 463.
    Now when I plug the usbc cable (original Apple 61W power supply), nothing starts automatically,...
    Yesterday, 05:09 AM
  • Zparts01
    MacBook A2289 820-01987
    by Zparts01
    I have a problem I'm hoping someone can help me with. I have an A2289 MacBook that had some liquid damage. After repairing any areas that had corrosion, I was able to get it to show 20v but only .01a on the multimeter. It was consistent on all ports, however I could not get the MacBook to go into DFU mode. I read that I should refllash U4770 and after grabbing the bin from this site I did just that. After soldering the chip back on the board, now I have DFU mode, but the thing is, it won't revive or restore, giving me the error that the device left the DFU state or something to that effect. The...
    02-04-2024, 02:07 PM
  • Grandoni Manuel
    MacBook a2289 water damage
    by Grandoni Manuel
    Hello to all ! I follow you but this is first time write !!
    your forum is the best !!
    so I’ve a2289 with water damage ! In first time other friend have clean and work ! But after some time stop working !
    now, I open the MacBook and I see a lot of corrosion near backlight circuit (I attach some photos about that ) I think the problem is on backlight maybe bcs do strange boot then reboot (attach video ) I change some thing on the circuit like :
    q8400
    q8401
    D8410
    and the resistor R8431
    if I check PPVIN SOSW LCDBKLT_R I’ve 12,9v
    on...
    04-03-2025, 06:45 PM
