Beginner question. Did I find a short?? HP dax31mb1aa0 REV A motherboard
  • Mess
    • Sep 2024
    • 9
    • Uk
ID:	3461879 Click image for larger version
    Hi beginner here, so I'm not sure of I've done this right ๐Ÿ˜… trying to diagnose my laptop's motherboard (dax31mb1aa0 rev a). I don't quite know how to read the schematic, so I'm attaching the pictures of the motherboard and the measurements.
    I was attempting to measure resistance to GND on inductors. I disconnected motherboard and used "continuity testing" setting on my multimeter. I put black probe to Ground & red probe on an inductor. Did I measure this right? Am I correct to think that 0.3 ohm measurement indicates a short circuit? Thank you for your help!
  • mon2
    • Dec 2019
    • 14664
    Yes, this is considered to be short circuit but the PCB pad that you are testing is very likely the GROUND pad of a bulk capacitor. So this is ok - not a short. Best to study, if available, the boardview file for this logic board to confirm. Also, touch your meter probes together and you should measure 0R3 ohms as well. That is, like our meter in the lab (Fluke), the lowest resistance is @ 0R3 ohms.
    • Mess
      • Sep 2024
      • 9
      • Uk
      Oh I thought I learnt something ๐Ÿ˜” unfortunately I don't have the boardview file only schematic. And there's very little writing on the board itself - i.e. not many things are labeled like I've seen on other motherboards that people use to teach on (e.g. on educational YouTube vidoes), so it's difficult no know what's where.
      When I touch my meter probes, it reads 0.1ohms. it's a cheap meter though, unlike fluke, so it might not be accurate I guess.:/
      • mon2
        • Dec 2019
        • 14664
        Hold that thought. After another glance of the posted pic - can you share a zoomed up picture of this area?
        Is the pad that you measured going to pins 1-2-3 (cluster to the right side of this pad you measured) of the missing mosfet? (SOURCE pins)
        Pin 4 is the next pin by itself.
        • Mess
          • Sep 2024
          • 9
          • Uk
          Sorry, I'm not sure which pins you're talking about.๐Ÿค” Here are the closeups :
          and i think this is the schematics of it + the mosfet on its right:
          โ€‹โ€‹โ€‹โ€‹โ€‹Click image for larger version
          • mon2
            • Dec 2019
            • 14664
            This inductor is switching the power rail for the large BGA device on the left side of your posted pic. Is that the GPU? By design, low voltage rails, like the CPU and GPU will have a low resistance to ground and 0R3 is not considered to be a short. Confirm if the device is the GPU and if yes, which brand / top side markings.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              The inductor showing 0.3 Ohms is very likely VCORE or VCCGT coil. However, in both the cases it should'nt read that low. I beleive its 7th/8th gen SOC-so reading should be 2-6 ohms range. Seems SOC is shorted or the dual mosfet is shorted. Worth trying de soldering the dual mosfet coonected with this coil.
              • Mess
                • Sep 2024
                • 9
                • Uk
                Yes, to the left there's a kaby lake platform with Intelยฎ Coreโ„ข i7-7500U CPU and Intelยฎ HD Graphics 620 GPU. Should I rather use resistance mode (than continuity testing) to test these? There are some inductors on the other other side of the motherboard that can't test (no beep & infinity measurement).
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Your board dont have a dedicated GPU and its iGPU only(part of SOC).
                  Resistance to GND measurement is always preferred but going by the diode mode readings on the coil which reads 0.3 ,i doubt whether the SOC is alive.
                  Have you de soldered the dual mosfet?
                  • DeXXter
                    • Aug 2023
                    • 112
                    • Chile
                    Yes pal, that's a short, also when you're measuring CPU/GPU coils use ohms mode (not coninuity nor diode). Also find the datasheet from that mosfet and measure from drain to source and vice versa (this on diode mode), you can also lift one side of the coil to check on which side of it is the short
                    • aaronkatrini
                      Help me find the short circuit on this WORKING Nvidia GTX1650
                      by aaronkatrini
                      Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
                      Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
                      04-18-2024, 03:15 PM
                    • Prott
                      PCB Layer to layer short on a low voltage power plane - how to find it?
                      by Prott
                      Hello!
                      Recently I have a problem finding a dead short (as far as my cheap multimeter is concerned) on a multilayered (12 layer) PCB. It is caused due to mechanical stress (warping the board and, I assume, cracking inner layers). Injecting voltage of 0.9 V (operational voltage of that part of the circuit) and drawing 0.5 W doesn't cause any visible hotspot on a thermal camera.
                      Does anybody have any tips & tricks in order to locate the short more or less precisely? The area has a lot of powerplanes, so it's both blessing and a curse.
                      Silly idea no. 1: Can I...
                      08-01-2024, 12:09 PM
                    • Mess
                      Motherboard diagnostic beginner advice
                      by Mess
                      To save you some time: the most important bits are in bold.
                      Some further examples/explanations or to the side & in grey - you can probs skip them if it's TLDR for you. Sorry, I've got ADHD & tend to over-explain stuff - just like I'm doing right now ๐Ÿ˜… Briefness is for poets not me ๐Ÿ™ˆ
                      Please help!! ๐ŸŽถI'm just a girl in a world that wants to scam me out of lots of money for any tech stuff/repairs ๐ŸŽต Seriously tho, I'm poor&I can't afford to get laptop diagnosis, especially if it ends up needing a new motherboard. Where I live, all the tech shops are run by very...
                      09-12-2024, 07:02 PM
                    • playit
                      laptop 19v short circuit dell vostro 1400 motherboard ,need help in repair .
                      by playit
                      the comon problem they say , the charger will shut off power once plugged to laptop , i dont have battery, its long gone ago , i use it for backup with adapter and vga port to external monitor(yes no screen lcd) in case my desktop needs fix . one thing for sure i could say the clr resistor - r010 beeps ,short at both sides , the checked all the coils , the 3 coils together gives all of them beeps short along with their respective capacitors . i dont have voltage ampere injection dc machine as in videos i have seen they see where its getting hot and they remove the short and replace components...
                      02-25-2025, 08:15 AM
                    • shuky
                      motherboard short - lenovo thinkbook 13s-iml model name 20rr
                      by shuky
                      hi , my motherboard is short after ram change. here is some pics. i think this component is short. thank you...
                      02-19-2024, 06:46 AM
