HP dv5-1225ee (DAQT6GMB8B0) Freez at POST
  • kandyan
    • Mar 2013
    • 53
    • Sri Lanka
    I have HP dv5-1225ee (DAQT6GMB8B0) freezes it self at POST screen.I flashed the BIOS with latest update but nothing changed.If i pressed "Esc" button from the beginning of power up nothing showed but if i do nothing then it shows POST screen and froze.
    01. I changed RAM
    02. Remove all the attached devices
    03. Re flashed BIOS with latest update.
    04. Replaced new RTC battery.
    Someone please tell me where dig for a solution....?
  • samanthban
    • Feb 2014
    • 253
    • Sri lanka
    Re: HP dv5-1225ee (DAQT6GMB8B0) Freez at POST
    might be graphic chip.reballing or changing may help.
    sigpic
    • tomodachi
      • Apr 2012
      • 612
      • Turkey
      tried without keyboard ?
      • kandyan
        • Mar 2013
        • 53
        • Sri Lanka
        Update:
        KB3926QF heat badly when laptop is powering up.
        • kandyan
          • Mar 2013
          • 53
          • Sri Lanka
          I think is not relates to GPU. KB is heating badly. I dont have spare new KB but i have another one on damaged MOBO.
          Shall I try it with this one or do i need to check why is this KB heating?
          • tomodachi
            • Apr 2012
            • 612
            • Turkey
            if its heating without keyboard plugged, change the KBC without a clue
            • kandyan
              • Mar 2013
              • 53
              • Sri Lanka
              Yeap. Its heating without the keyboard.Thanks for the advice. I will change the KB and let you guyz the results.
              • Jhos
                • May 2017
                • 4
                • peru
                Placa DAQT6GMB8B0
                • mkdj
                  What should I do after having flashed a BIOS?
                  by mkdj
                  Dear all,
                  I did my first laptop repair related to a BIOS issue. Laptop is a Lenovo ThinkPad T480, and was not booting. With my brand new programmer, I did a back-up of the current not working BIOS, erased the BIOS chip, and flashed this dump: https://www.badcaps.net/forum/troubl...83#post3686683
                  Now the laptop works fine, I can access BIOS and boot on a USB drive. But I read stuff about DMI, and...
                  09-09-2025, 09:45 AM
                • Loli Popu
                  DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
                  by Loli Popu
                  Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                  12-13-2024, 03:28 AM
                • Artem2009-16
                  Intel DQ965GF — Need latest BIOS for Core 2 Quad upgrade
                  by Artem2009-16
                  I’m currently working with an Intel DQ965GF motherboard and would like to upgrade the CPU.
                  However, I can’t find the latest BIOS version or a working download link for it — the official Intel website no longer provides this file.
                  Could someone please share a copy of the latest BIOS update (preferably the final release version)?
                  My goal is to upgrade the processor from a Core 2 Duo E6700 to a Core 2 Quad Q6700, so I’d like to make sure the BIOS fully supports...
                  10-26-2025, 08:33 AM
                • spoti hakai
                  HP 15t-dh100 BIOS recovery help needed
                  by spoti hakai
                  Hi, thank you for taking time to read this.
                  I need help with EC firmware files extraction.
                  OMEN Laptop - 15t-dh100 CTO
                  Product ID: for more specific accurate search
                  8VM74AV
                  Can you kindly mention files which should be flashed in 16 MB bios chip? and files which should be flashed in 1 mb chips.
                  Bios version: F.44 bricked my laptop.
                  F.38 or F.39 were last working files.
                  5 capslock long blinks 3 short.
                  First, when bios updated started from windows update, it broke the laptop. Second, when i tried Win +V key,...
                  11-13-2024, 11:21 AM
                • yotoprules
                  Fujitsu Amilo Pro V2030D BIOS DUMP
                  by yotoprules
                  I am looking for Fujitsu Amilo Pro V2030D BIOS DUMP.
                  I downloaded latest BIOS from Fujitsu (for V2030) and flashed it as per instructions. After doing so the laptop has become unstable, I'm getting lots of BSODs, CRC errors, etc, and I didn't make a backup.
                  I am unsure what difference, if any is between the V2030 and V2030D, but mine is the V2030D.
                  The BIOS I flashed was 1.0H.
                  Thank you
                  09-29-2025, 11:43 PM
