Lenovo E14 not working on charger works on battery
  • koby058
    • Jan 2017
    • 382
    • israel
    Hello.
    I have this laptop Lenovo E14 AMD
    when connecting type c power, the amp meter shows 20v, for a second it goes up to 0.5 amp and then back to 0.27amp
    the laptop works on battery.
    pushing 12v on PL3 make PU6 get hot, when removed PU6 and pushing 12v no power is pulled by MOBO
    Resistance on PU6 pin 2 is 4ohm
    Any advise how to continue ? do you think replacing pu6 will make it work?
    attached schematic
  • Mugi
    • Feb 2022
    • 9
    Hello KOby058.
    How did you fix the above issue ?
    • Mugi
      • Feb 2022
      • 9
      The charger is fine and the charger port also is fine. The USB amp meter it showing 19v with 02A. the laptop works with battery power but not main charger .
      Same problem us koby058
      • REpairAT
        • Nov 2020
        • 142
        • Austria
        Just fixed exactly this fault. Replace UT5, NX20P5090UK
        ​Let me know if it worked.
          NVDC charger configuration...
          11-05-2024, 03:28 PM
          ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
          Highly Integrated Narrow VDC Battery Charger for Notebook Computers
          The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
          for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
          Narrow VDC applications where the system power source is
          either the battery pack or the regulated output of the charger.
          This makes the max voltage to the system equal to the max
          battery voltage instead of the max adapter voltage. Operating
          at lower system voltage can improve...
          11-05-2024, 04:43 PM
        • ferah831208
          Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
          by ferah831208
          Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
          03-18-2025, 01:18 AM
        • flat-earther
          how to prevent a connected charger from draining battery when not charging?
          by flat-earther
          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
          So the battery is backfeeding the charger and being drained.
          How can I prevent...
          Yesterday, 01:04 PM
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
